WSP4805
Dual P-Ch MOSFET
General Description
Product Summery
The WSP4805 is the highest performance
trench Dual P-Ch MOSFET with extreme high
cell density , which provide excellent
RDSON and gate charge for most of the
synchronous buck converter applications .
BVDSS
RDSON
ID
-30V
16mΩ
-8.0A
Applications
The WSP4805 meet the RoHS and Green
Product requirement , 100% EAS
guaranteed with full function reliability
approved.
z High Frequency Point-of-Load Synchronous
Buck Converter for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
SOP-8 Pin Configuration
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z 100% EAS Guaranteed
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
VDS
VGS
ID@Tc=25℃
ID@Tc=70℃
IDM
Rating
Units
Drain-Source Voltage
-30
V
Gate-Source Voltage
±20
V
1
-8.0
A
1
-7.1
A
-40
A
mJ
Continuous Drain Current, VGS @ -10V
Pulsed Drain Current
2
EAS
Single Pulse Avalanche Energy
49
IAS
Avalanche Current
-24
A
3
4
PD@TA=25℃
Total Power Dissipation
2.5
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
1
www.winsok.tw
Thermal Resistance Junction-Case
Page 1
1
Max.
90
Unit
℃/W
℃/W
Dec.2014
WSP4805
Dual P-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
Reference to 25℃ , ID=-1mA
-0.022
V/℃
VGS=-10V , ID=-8.0A
16
22
VGS=-4.5V , ID=-5.6A
18.5
28
-1.2
-1.4
-2.0
V
4.6
mV/℃
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
VGS=VDS , ID =-250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-3A
21.7
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
3.6
5.0
Ω
Qg
Total Gate Charge (-4.5V)
12
Qgs
Gate-Source Charge
5.9
Qgd
Gate-Drain Charge
4.7
VDS=-15V , VGS=-4.5V , ID=-8.9A
uA
nC
8.9
Rise Time
VDD=-15V , VGS=-10V , RG=6Ω,
10.8
Turn-Off Delay Time
ID=-1A, RL=15Ω,
35.5
Fall Time
46.9
Ciss
Input Capacitance
1025
Coss
Output Capacitance
209
Crss
Reverse Transfer Capacitance
158
Min.
Typ.
Max.
Unit
42
mJ
Min.
Typ.
Max.
Unit
-8
A
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=-25V , L=0.5mH , IAS=-24A
Diode Characteristics
Symbol
IS
Parameter
Conditions
1,6
Continuous Source Current
2,6
VG=VD=0V , Force Current
ISM
Pulsed Source Current
-40
A
VSD
Diode Forward Voltage
VGS=0V , IS=-1A , TJ=25℃
-1.2
V
trr
Reverse Recovery Time
16.5
nS
Qrr
Reverse Recovery Charge
IF=-8.9A,dI/dt=100A/µs,TJ=25℃
6.2
nC
2
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSP4805”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.41750
- 10+1.33650
- 30+1.17450
- 100+1.05300
- 500+0.97200
- 1000+0.91530
