WSP4953
Dual P-Ch MOSFET
General Description
Product Summery
The WSP4953 is the highest performance
trench P-ch MOSFET with extreme high
cell density , which provide excellent
RDSON and gate charge for most of the
synchronous buck converter applications .
BVDSS
RDSON
-30V
60mΩ
ID
-5.3A
Applications
The WSP4953 meet the RoHS and Green
Product requirement with full function
reliability approved.
z High Frequency Point-of-Load Synchronous
Buck Converter for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
SOP8 Pin Configuration
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
VDS
VGS
ID@TC=25℃
ID@TC=100℃
IDM
Rating
Units
Drain-Source Voltage
-30
V
Gate-Source Voltage
±20
V
1
-5.3
A
1
-4.6
A
-12
A
Continuous Drain Current, -VGS @ -10V
Pulsed Drain Current
2
3
PD@TC=25℃
Total Power Dissipation
1.5
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-Ambient
RθJC
1
www.winsok.tw
Thermal Resistance Junction-Case
Page 1
1
Max.
Unit
85
℃/W
36
℃/W
Dec.2014
WSP4953
Dual P-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
Reference to 25℃ , ID=-1mA
-0.02
V/℃
VGS=-10V , ID=-3A
60
90
VGS=-4.5V , ID=-1.5A
90
120
-1.0
-1.5
-2.5
V
4.32
mV/℃
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
VGS=VDS , ID =-250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-3A
5.5
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
24
48
Ω
Qg
Total Gate Charge (-4.5V)
5.22
Qgs
Gate-Source Charge
1.25
Qgd
Gate-Drain Charge
2.3
Td(on)
VDS=-20V , VGS=-4.5V , ID=-5A
nC
18.4
Rise Time
VDD=-15V , VGS=-10V , RG=3.3Ω
11.4
Turn-Off Delay Time
ID=-1A
39.4
Fall Time
5.2
Ciss
Input Capacitance
463
Coss
Output Capacitance
82
Crss
Reverse Transfer Capacitance
68
Min.
Typ.
Max.
A
Tr
Td(off)
Tf
Turn-On Delay Time
uA
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
Conditions
1,4
IS
Continuous Source Current
ISM
Pulsed Source Current2,4
VSD
Diode Forward Voltage2
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
Unit
-5.3
-12
A
-1
V
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSP4953”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.62000
- 100+0.58000
- 500+0.54000
- 2000+0.48000
- 5000+0.46000
- 10000+0.44800
- 国内价格
- 10+0.62000
- 50+0.57200
- 200+0.53200
- 600+0.49200
- 1500+0.46000
- 3000+0.44000
