WST2333
P-Ch MOSFET
General Description
Product Summery
The WST2333 is the highest performance trench
P-Ch MOSFET with extreme high cell density ,
which provide excellent RDSON and gate charge
for most of the small power switching and load
switch applications.
BVDSS
RDSON
ID
-12V
23mΩ
-6A
Applications
The WST2333 meet the RoHS and Green
Product requirement with full function reliability
approved.
z High Frequency Point-of-Load Synchronous
Small power switching for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
SOT-23N Pin Configuration
z Super Low Gate Charge
z Excellent Cdv/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-12
V
VGS
Gate-Source Voltage
±8
V
-6
A
ID@Tc=25℃
1
Continuous Drain Current, VGS @ -4.5V
1
ID@Tc=70℃
IDM
Pulsed Drain Current
2
-3.9
A
-18.8
A
3
PD@TA=25℃
Total Power Dissipation
1
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient
RθJC
Thermal Resistance Junction-Case
www.winsok.tw
1
Page 1
1
Typ.
Max.
Unit
125
℃/W
80
℃/W
Dec.2014
WST2333
P-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
2
Static Drain-Source On-Resistance
Min.
Gate Threshold Voltage
Max.
Unit
VGS=0V , ID=-250uA
-12
V
Reference to 25℃ , ID=-1mA
-0.01
V/℃
VGS=-4.5V , ID=-4A
23
32
VGS=-2.5V , ID=-2A
32
40
42
52
-0.3
-0.5
-1.0
V
2.96
mV/℃
VDS=-12V , VGS=0V , TJ=25℃
-1
VDS=-12V , VGS=0V , TJ=55℃
-5
VGS=-1.8V , ID=-1.5A
VGS(th)
Typ.
VGS=VDS , ID =-250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±8V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-4A
21
S
Qg
Total Gate Charge (-4.5V)
27.3
38.2
Qgs
Gate-Source Charge
3.6
5.0
Qgd
Gate-Drain Charge
6.5
9.1
Turn-On Delay Time
9.2
18.4
Td(on)
Tr
Td(off)
Tf
Ciss
VDS=-15V , VGS=-4.5V , ID=-4A
uA
nC
Rise Time
VDD=-10V , VGS=-4.5V , RG=3.3Ω
59
106
Turn-Off Delay Time
ID=-4A
99
198
71
142
1025
220
187
Min.
Typ.
Max.
Unit
-4.7
A
-18.8
A
-1
V
52
nS
28
nC
Fall Time
Input Capacitance
VDS=-12V , VGS=0V , f=1MHz
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
ns
pF
Diode Characteristics
Symbol
IS
ISM
Parameter
Continuous Source Current
2,4
Pulsed Source Current
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Conditions
1,4
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
IF=-4A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WST2333”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.59859
- 50+0.47547
- 600+0.46834
- 1200+0.45429
- 3000+0.43385
- 国内价格
- 5+0.53695
- 50+0.42651
- 150+0.37124
- 500+0.32984
- 3000+0.29074
- 6000+0.27412
