WST3401
P-Ch MOSFET
General Description
Product Summery
The WST3401 is the highest performance trench
P-Ch MOSFET with extreme high cell density ,
which provide excellent RDSON and gate charge
for most of the small power switching and load
switch applications .
BVDSS
RDSON
ID
-30V
44mΩ
-5.5A
Applications
The WST3401 meet the RoHS and Green
Product requirement , with full function reliability
approved.
z High Frequency Point-of-Load Synchronous
Buck Converter for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z Green Device Available
SOT-23-3L Pin Configuration
Absolute Maximum Ratings
Rating
Symbol
Parameter
VDS
Drain-Source Voltage
-30
V
VGS
Gate-Source Voltage
±12
V
ID@TC=25℃
ID@TC=70℃
IDM
PD@TA=25℃
10s
Units
1
-6.0
-5.5
A
1
-4.9
-4.3
A
Continuous Drain Current, VGS @ -10V
Pulsed Drain Current
Steady State
2
-17
A
3
1.32
1
W
3
0.84
0.64
W
Total Power Dissipation
PD@TA=70℃
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
RθJA
RθJA
RθJC
www.winsok.tw
Parameter
Thermal Resistance Junction-Ambient
1
1
Thermal Resistance Junction-Ambient (t ≤10s)
1
Thermal Resistance Junction-Case
Page 1
Typ.
Max.
Unit
125
℃/W
95
℃/W
80
℃/W
Dec.2014
WST3401
P-Ch MOSFET
Electrical Characteristics (TJ=25℃unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-30
V
Reference to 25℃ , ID=-1mA
-0.023
V/℃
VGS=-10V , ID=-3A
44
50
58
-0.6
-1.2
V
4
mV/℃
VDS=-24V , VGS=0V , TJ=25℃
-1
VDS=-24V , VGS=0V , TJ=55℃
-5
VGS=-4.5V , ID=-2A
VGS=VDS , ID =-250uA
52
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-5V , ID=-3A
11
S
Qg
Total Gate Charge (-4.5V)
6.4
9.0
Qgs
Gate-Source Charge
2.3
3.2
Qgd
Gate-Drain Charge
1.9
2.7
Td(on)
VDS=-15V , VGS=-4.5V , ID=-3A
nC
2.8
5.6
Rise Time
VDD=-15V , VGS=-10V , RG=3.3Ω,
8.4
15.1
Turn-Off Delay Time
ID=-3A
39
78.0
Fall Time
6
12.0
Ciss
Input Capacitance
583
Coss
Output Capacitance
100
Crss
Reverse Transfer Capacitance
80
Min.
Typ.
Max.
Unit
-4.3
A
-17
A
-1
V
7.8
nS
2.5
nC
Tr
Td(off)
Tf
Turn-On Delay Time
uA
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
Conditions
1,4
IS
Continuous Source Current
ISM
Pulsed Source Current2,4
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=-1A , TJ=25℃
IF=-3A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WST3401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.44330
- 200+0.28600
- 1500+0.24860
- 3000+0.22000
- 国内价格
- 5+0.42120
- 50+0.38006
- 150+0.33038
- 500+0.29312
- 3000+0.26331
- 6000+0.24840
- 国内价格
- 10+0.23400
- 100+0.22140
- 1000+0.21240
