WST3408
N-Ch MOSFET
General Description
Product Summery
The WST3408 is the highest performance
trench N-Ch MOSFET with extreme high cell
density , which provide excellent RDSON and
gate charge for most of the synchronous
buck converter applications .
BVDSS
RDSON
ID
30V
26mΩ
5.5A
Applications
The WST3408 meet the RoHS and
Green Product requirement with full
function reliability approved.
z High Frequency Point-of-Load Synchronous s
Small power switching for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
SOT-23-3L Pin Configuration
z Super Low Gate Charge
z Excellent Cdv/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
30
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V1
5.5
A
ID@TC=70℃
1
4.5
A
A
IDM
Pulsed Drain Current
2
3
EAS
Single Pulse Avalanche Energy
24
mJ
IAS
Avalanche Current
8
A
4
PD@TA=25℃
Total Power Dissipation
1.5
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-ambient
RθJC
Thermal Resistance Junction-Case1
www.winsok.tw
Page 1
1
Max.
Unit
90
℃/W
75
℃/W
Dec.2014
WST3408
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.023
V/℃
26
32
37
44
1.0
1.4
2.0
V
-4.2
mV/℃
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
VGS=10V , ID=5.8A
VGS=4.5V , ID=5A
VGS=VDS , ID =250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=6A
15
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.4
2.0
Ω
Qg
Total Gate Charge (4.5V)
7.6
9.9
Qgs
Gate-Source Charge
1.3
1.7
1.7
2.2
20.3
Qgd
VDS=15V , VGS=4.5V , ID5.8A
Gate-Drain Charge
uA
nC
10.1
Rise Time
VDD=15V , VGS=10V , RG=6Ω,
3.2
6.3
Turn-Off Delay Time
ID=1A, RL=15Ω.
22.2
44.4
Fall Time
3
6
Ciss
Input Capacitance
391
Coss
Output Capacitance
86.2
Crss
Reverse Transfer Capacitance
59.4
Min.
Typ.
Max.
Unit
mJ
Min.
Typ.
Max.
Unit
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=15V , VGS=0V , f=1MHz
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=25V , L=0.1mH , IAS=8A
Diode Characteristics
Symbol
Parameter
Conditions
1,6
IS
Continuous Source Current
ISM
Pulsed Source Current2,6
VSD
Diode Forward Voltage2
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=8A , dI/dt=100A/µs , TJ=25℃
3
A
15
A
1.2
V
7.8
nS
2.1
nC
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WST3408”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.52022
- 50+0.41291
- 150+0.35926
- 500+0.31901
- 3000+0.27887
- 6000+0.26274
- 国内价格
- 10+0.38400
- 50+0.35520
- 200+0.33120
- 600+0.30720
- 1500+0.28800
- 3000+0.27600
