SDCW2012C-2-900TF
SDCW2012C-2-900TF
    SUNLORD(顺络)
    CHOKE_2X1.3MM_SM
    共模电感 330mA ±25% 350mΩ 90Ω CHOKE_2X1.3MM_SM
SDCW2012C-2-900TF 数据手册
Wire Wound Chip Common Mode Choke Coil – SDCW-C Series Operating Temp. : -40℃~+85℃ FEATURES ● ● ● Winding type and low profile Prevention of common mode noise at high frequency 67Ω~180Ω are optional for different noise level and signal frequency APPLICATIONS ● ● USB2.0 of PC, peripheral equipments, small LVDS lines of Note PC, LCD PRODUCT IDENTIFICATION SDCW ① 2012 C -2 -900 T F ② ③ ④ ⑤ ⑥ ⑦ ① Type SDCW ③ ② Winding Type Common Mode Choke Coil Code (L×W) (mm) External Dimensions (L×W) (mm) 2012 [0805] 2.0×1.3 C Coating ④ Number of Lines 2 ⑦ ⑤ Example 900 Impedance Nominal Value 90Ω ⑥ Packing T Tape & Reel Hazardous Substance Free Products F SHAPE AND DIMENSIONS SDCW2012C TYPE Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2017/04/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS SDCW2012-C TYPE Part Number Common Mode Impedance @100MHz Max. DC Resistance Max. Rated Current Rated Voltage Min. Insulation Resistance Units Symbol SDCW2012C-2-670TF SDCW2012C-2-900TF SDCW2012C-2-121TF SDCW2012C-2-181TF Ω Z 67±25% 90±25% 120±25% 180±25% Ω DCR 0.35 0.35 0.45 0.50 mA Ir 330 330 280 250 Volts VDC 50 50 50 50 MΩ IR 10 10 10 10 ※Products with other electrical characteristics can be provided upon customer’s request. Please contact your local sales. EQUIVALENT CIRCUIT TYPICAL ELECTRICAL CHARACTERISTICS Impedance vs. Frequency Frequency(MHz) Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2017/04/15 Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832660 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
SDCW2012C-2-900TF
物料型号:SDCW2012C-2-670TF、SDCW2012C-2-900TF、SDCW2012C-2-121TF、SDCW2012C-2-181TF。
器件简介:这是一个线绕型共模扼流圈,具有低剖面设计,用于高频共模噪声的抑制。
引脚分配:文档未明确提供引脚分配信息。
参数特性:提供了不同型号的共模阻抗、最大直流电阻、最大额定电流、额定电压和最小绝缘电阻。
功能详解:文档描述了共模扼流圈的等效电路和典型电气特性,展示了不同频率下的阻抗变化。
应用信息:适用于PC及其外围设备的USB2.0、笔记本电脑、LCD的LVDS线路等。
封装信息:提供了SDCW2012C类型的外形和尺寸图。
SDCW2012C-2-900TF 价格&库存
很抱歉,暂时无法提供与“SDCW2012C-2-900TF”相匹配的价格&库存,您可以联系我们找货
SDCW2012C-2-900TF
库存:5062
SDCW2012C-2-900TF
库存:451
SDCW2012C-2-900TF
  • 10+0.60093
  • 100+0.50827
  • 400+0.50319
  • 800+0.49313
  • 2000+0.47834
库存:1195
SDCW2012C-2-900TF
  • 1+2.728821+0.35348
  • 10+2.2267610+0.28845
  • 100+1.82810100+0.23681
  • 1000+1.503321000+0.19474
库存:1811
MCASU32MAB7106KPNA01
    • 1000+2.01600
    库存:1000
    SDCW2012C-2-900TF
    • 1+0.75130
    • 50+0.49940
    • 2000+0.45210
    库存:2565
