MEX223K275A05
MEX223K275A05
    TENTA(天泰)
    CAP_13X6MM_TM
    安规电容 CAP_13X6MM_TM 22nF ±10% 275V
MEX223K275A05 数据手册
版 本 描 述 日 期 客户 CUSTOMER 品名 PART NAME 天泰料号 TENTA Material Number 客户料号 CUSTOMER Material Number 编制/Edition 检查/Checked 确认/Confirmed 陆伟 徐志钦 杨再军 承认/Admit 审核/Auditing 批准/Approved 天泰電機工業有限公司 TENTA ELECTRIC INDUSTRIAL CO., LTD. 台中縣梧棲区自強二街 86 巷 61 號 NO.61, Lane 86, Tzchiang 2st St. Wu-Chi Township, Taichung County 435, TAIWAN R.O.C TEL:(886-04)26398618 FAX:(886-04)26392549 深圳天泰電器元件有限公司 SHEN ZHEN TENTA ELECTRICAL APPLIANCE LTD. 公司:深圳市南山區白石洲中國原子能第二工業區第二棟六樓 6/F NO.2, Pirector Atom 2th Industry, Baishizhou , Shenzhen, CHINA TEL:(0755)86327963、26921158 FAX:(0755)86297411 工厂:深圳市寶安區福永街道橋頭社區富橋第四工業區 A5 棟 No.A5,FU Qiao 4th Industrial area,Qiaotou Community,Fuyong Street,Bao An District,Shen Zhen TEL:(0755)29604898 FAX:(0755)29604891 TENTA ELECTRIC INDUSTRIAL CO., LTD. MAIN INTERFERENCE SUPRESSION CAPACITOR CLASS X2……MEX--X2 SPECIFICATION: 1. REFERENCE STANDARDS: VDE EN 60384-14, ENEC IEC 60384-14, KC APPLIED STANDARD: K60384-14 (CAPACITANCE AREA 0.1 to2.2uF) CQC THE STANDARDS FOR THE PRODUCTS TO BE TESTED: GBIT14472-1998 UL UL60384-14 (250V/275V AC) USED FOR ACROSS-THE-LINE CAPACITORS, ANDTENNA-COUPLINE, LINE-BY-PASS COMPONENTS, RADIO INTERFERENCE SUPPRESSION, ELECTRONMAGNETIC INTERFERENCE FILTERS. 2. RATED VOLTAGE: 275V AC 50/ 60 Hz 3. CAPACITANCE RANGE: 0.001µF to 2.2 µF 4. CAPACITANCE TOLERANCE: ± 5% (J) ± 10% (K) ± 20% (M) 5. DIELECTRIC: METALLIZED POLYPROPYLENE 6. DISSIPATION FACTOR Tan δ: LESS THAN 0.1% AT 1 kHz AND FLIM 20℃ 7. INSULATION RESISTANCE: BETWEEN ELECTRODES (1) LESS THAN OR EAUAL TO 0.33μF≧ 15000 MΩ (2) GREATER THAN 0.33μF≧ 5000s/uF MEASURED AT 100VDC, 60 SEC. AND 20℃ 8. WITHSTAND VOLTAGE: APPLIED 1183V.DC FOR 60 SEC. OR 2000V.DC FOR 1 SEC 9. CLIMATE CATEGORY: IN ACCORDANCE WITH DIN40040 GMF G (MINIMUM LIMIT TEMPERATURE)= -40℃ M (MAXIMUM LIMIT TEMPERATURE)= +100℃ F (HUMIDITY CATEGORY)=AVERAGE RELATEIVE HVMIDITY ≦75%, 95% FOR 30 DAYS PER YEAR, CONTINUOUSLY; 85% FOR THE REMATINING DAYS, OCCASIONALLY 10. HUMIDITY TEST: TEST CONDIDITON TEST TEMPER ATURE RELATIVE HUMIDITY TEST DURATION : 40±2℃ : 90 TO 95% : 500 HRS TEST CRITERIA (1) CAPACITANCE DRIFT : ≦ 5% OF THE INITIAL VALUE (2) INSULATION RESISTANCE : ≦ 50% OF SPECIFIED VALUE 11. LIFE TEST: TEST CONDITION TEST TEMPERATURE TEST VOLTAGE TEST DURATION : 100±3℃ : 343VAC AND 1000VDC 60HZ FOR A PERIOD OF 0.1 SEC. ONCE EACH HOUR : 1008 HRS TEST CRITERIA (1) CAPACITANCE DRIFT : ≦10% OF THE INITIAL VALUE (2) INSULATION RESISTANCE : ≧50% OF SPECIFIED VALUE (3) VISUAL INSPECTION : NO DETECTABLE DAMAGE 12. SOLDERABILITY: TEST CONDITIONS SOLDER BATH TEMPERATURE : 260±5℃ SOLDER SOLDER TIME TEST CRITERIA 75% OF THE SURFACE TINNING : sn/cu=99.3%/0.7% : 3±0.5 SEC 13. VIBRATION RESISTANCE: (JIS 5115) TEST CONDITIONS FREQUENCY CYCLE : 1 MINUTE PER CYCLE 10-55-10 HZ TEST DURATION : PERPENDICULAR DIRECTION WITH THE SAME METHOD FOR 45 MINUTES EACH, TOTAL 90 MINUTES TEST CRITERIA (1) APPERANCE : NO VISUAL DAMAGE (2) CONTACT : NORMAL 14. TENSILE STRENGTH OF ELECTRODES: TEST CONDITIONS LOAD CONDITIONS : 1.0KGS HOLDING TIME : 10±1 SEC TEST CRITERIA NO WIRE BROKEN AND NO DAMAGE OF THE CAPACITOR 15. MARKING: CAPACITORS ARE MARKED WITH TYPE IDENTIFICATION, CAPACITANCE, CAPACITANCE TOLERANCE, VOLTAGE AND APPROVED CERTIFICATION MARK 16. APPROVED BY: VDE;ENEC16,EK,CQC; UL; VDE ENEC KC CQC UL FILE NO. 119119 FILE NO. 2014032 A1 FILE NO. SU03019-5001B-5002B-8001B FILE NO. CQC03001003039 FILE NO. E222911 W ±0.5 ±0.5 H ±0.5 MARKING d ± 0.05 L0 L0 20 min MARKING T H ±0.5 W ±0.5 P ±0.5 P ±0.5 Pediform.E#( 短脚 ) Pediform.A#( 长脚 ) Normal Size CAP W H T P dØ CAP W H T P dØ 0.001 13.0 9.0 4.0 10.0 0.6 0.068 18.0 12.0 6.0 15.0 0.8 0.0012 13.0 9.0 4.0 10.0 0.6 0.082 18.0 12.0 6.0 15.0 0.8 0.0015 13.0 9.0 4.0 10.0 0.6 0.1 18.0 13.5 6.0 15.0 0.8 0.0018 13.0 9.0 4.0 10.0 0.6 0.12 18.0 13.5 7.5 15.0 0.8 0.0022 13.0 9.0 4.0 10.0 0.6 0.15 18.0 14.5 8.5 15.0 0.8 0.0027 13.0 9.0 4.0 10.0 0.6 0.15 26.5 15.0 6.0 22.5 0.8 0.0033 13.0 9.0 4.0 10.0 0.6 0.18 26.5 16.5 7.0 22.5 0.8 0.0039 13.0 9.0 4.0 10.0 0.6 0.22 26.5 16.5 7.0 22.5 0.8 0.0047 13.0 11.0 5.0 10.0 0.6 0.27 26.5 17.0 8.5 22.5 0.8 0.0056 13.0 11.0 5.0 10.0 0.6 0.33 26.5 17.0 8.5 22.5 0.8 0.0068 13.0 11.0 5.0 10.0 0.6 0.39 26.5 19.0 10.0 22.5 0.8 0.0082 13.0 11.0 5.0 10.0 0.6 0.47 26.5 19.0 10.0 22.5 0.8 0.01 13.0 11.0 5.0 10.0 0.6 0.47 32.0 20.0 11.0 27.5 0.8 0.012 13.0 11.0 5.0 10.0 0.6 0.56 32.0 20.0 11.0 27.5 0.8 0.015 13.0 11.0 5.0 10.0 0.6 0.68 32.0 20.0 11.0 27.5 0.8 0.018 13.0 12.0 6.0 10.0 0.6 0.82 32.0 22.0 13.0 27.5 0.8 0.022 13.0 12.0 6.0 10.0 0.6 1.0 32.0 22.0 13.0 27.5 0.8 0.027 13.0 12.0 6.0 10.0 0.6 1.0 37.0 25.0 13.5 31.5 0.8 0.033 18.0 11.0 5.0 15.0 0.8 1.2 37.0 25.0 13.5 31.5 0.8 0.039 18.0 11.0 5.0 15.0 0.8 1.5 37.0 26.0 15.0 31.5 0.8 0.047 18.0 11.0 5.0 15.0 0.8 1.8 38.0 26.0 17.0 31.5 0.8 0.056 18.0 12.0 6.0 15.0 0.8 2.2 37.0 29.0 19.0 31.5 0.8 Compact Size 0.1 18.0 12.0 6.0 15.0 0.8 0.33 26.5 16.5 7.0 22.5 0.8 0.15 18.0 13.5 7.5 15.0 0.8 0.47 26.5 17.0 8.5 22.5 0.8 0.18 18.0 14.5 8.5 15.0 0.8 0.47 18.0 19.0 11.0 15.0 0.8 0.22 18.0 14.5 8.5 15.0 0.8 0.56 26.5 19.0 10.0 22.5 0.8 0.33 0.8 18.0 16.0 10.0 15.0 0.8 1.0 32.0 20.0 11.0 27.5 *Please contact us for special item or size not listed * 当 W 大 于 2 6 . 5 m m 时 其 外 壳 尺 寸 误 差 为 ± 1 . 0 m m µF / V Tolerance W H T Pediform P L0 dØ C Q C 17.印字說明: MEX/TENTA MKP 0.33uF K X2 275VAC 40/100/21 V DE EN 60384-14 xx-xx 250VAC TENTA:天泰商標 MEX:产品类型 X2:产品名稱 MKP:材质 0.33uF:標準容量 K:標準容量允差值±10% 275VAC:額定電壓 40/100/21: 40: 表示电容能承受的下限类别温度为-40Ċ 100:表示电容能承受的上限类别温度为 100Ċ 21:表示穩態濕熱的持續時間 21 天 : :德国安规认证 :欧盟安规认证 :韩国安规认证 C Q C :中国安规认证 :美國證符號及電壓 EN60384-14:行业标准编号 XX-XX:月期-年期 备注:以此为例,不同规格随着容量不同,其测试后标准容量与标准容量部分(划线部位)也随着改变 容量大于或等于 0.1UF 的有 KC 认证,小于 0.1UF 的没有 KC 认证。
MEX223K275A05
1. 物料型号:MEX系列X2型干扰抑制电容器。 2. 器件简介:这些电容器用于跨线电容器、天线耦合线、线路旁路组件、无线电干扰抑制、电磁干扰滤波器等。 3. 引脚分配:文档中未明确提供引脚分配信息。 4. 参数特性: - 额定电压:275V AC 50/60 Hz - 电容范围:0.001µF至2.2µF - 电容公差:±5% (J), ±10% (K), ±20% (M) - 介质:金属化聚丙烯薄膜 - 损耗角正切:在1kHz和20℃时小于0.1% - 绝缘电阻:0.33μF以下≥15000 MΩ,0.33μF以上≥5000s/uF(在100VDC、60秒和20℃下测量) 5. 功能详解:电容器设计用于抑制无线电干扰和电磁干扰,适用于多种电子设备和系统。 6. 应用信息:适用于ACROSS-THE-LINE CAPACITORS, ANTENNA-COUPLING LINE, LINE-BY-PASS COMPONENTS, RADIO INTERFERENCE SUPPRESSION, ELECTROMAGNETIC INTERFERENCE FILTERS。 7. 封装信息:提供了不同容量电容器的尺寸数据,包括宽度(W)、高度(H)、厚度(T)、引脚直径(P)和外壳直径(dØ)。
MEX223K275A05 价格&库存
很抱歉,暂时无法提供与“MEX223K275A05”相匹配的价格&库存,您可以联系我们找货
