ZV Series
ZV Series
Features
SMD
◆ Low impedence 100 KHz
◆ Reflow soldering is available
◆ Available for high density mounting
◆ Load life 2000 hrs at 105℃
◆ For detail specifications, please refer to Engineering Bulletin No.E135
◆ RoHS Compliant
Specifications
Item
Operating Temperature Range
Rated Voltage Range
Capacitance Range
Capacitance Tolerance
Leakage Current (+20℃,max.)
Dissipation Factor
(tanδ,at 20℃,120Hz)
Performance Characteristics
-55~ +105℃
6.3~50 VDC
1 to 1500μF
±20%(120Hz,+20℃)
0.01CV or 3(μA) After 2 minutes, whichever is greater measured with rated working voltage applied
Working voltage(VDC)
D.F. (%) max.
6.3
26
10
19
16
16
25
14
35
14
50
12
6.3
2
8
10
3
6
16
2
4
25
2
4
35
2
3
50
2
3
Impedance ratio max
Low Temperature Characteristics
(at 120Hz)
Load Life
Shelf Life
Z-25℃ Z+20℃
Z-55℃ Z+20℃
Test conditions
Duration time
Ambient temperature
Applied voltage
:2000 Hrs
:+105℃
:Rated DC working voltage
After test requirement at +105℃ :
Capacitance change
:≦±25% of the initial measured value
Dissipation factor
:≦200% of the initial specified value
Leakage current
:≦The initial specified value
Test conditions
Duration time
:1000 Hrs
Ambient temperature
:+105℃
Applied voltage
:None
After test requirement at +20℃ : Same limits as Load life.
Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes.
The capacitors shall be kept on the hot plate maintained at 250℃for 30 seconds. After removing form the
hot plate and restored at room temperature, they meet the characteristic requirements listed under.
Resistance to soldering heat
Leakage current
Less than specified value
Capacitance change
Within ±10% of initial value
tanδ
Multiplier for Ripple Current vs. Frequency
CAP(μF) Frequency(Hz) 60(50) 120
0.47 0.59
CAP≦10
0.52 0.65
10<CAP≦100
400
0.76
0.80
1K
0.85
0.89
10K 50K-100K
0.97
1.0
0.97
1.0
Diagram of Dimensions:(unit:mm)
φD
4
5
6.3
6.3
8
8
10
69
L
A
B
C
5.5 4.3 4.3 4.9
5.5 5.3 5.3 5.9
5.5 6.6 6.6 7.2
7.7 6.6 6.6 7.2
6.5 8.3 8.3 9.0
10.5 8.3 8.3 9.0
10.5 10.3 10.3 11.0
W
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.7~1.1
0.7~1.1
P
1.0
1.4
2.2
2.2
2.3
3.1
4.5
ZV Series
Case Size
φDxL(mm)
WV
6.3
(8)
(SV)
Cap
(µF)
1.0
2.2
3.3
4.7
Size
10
(13)
Ripple Impedance
Size
16
(20)
Ripple Impedance
Size
25
(32)
Ripple Impedance
6.8
10
4X5.5
15
65
5
Size
35
(44)
Ripple Impedance
4X5.5
53
5
4X5.5
58
4.5
4X5.5
74
3.7
5X5.5
80
2.6
100
115
128
140
145
2.2
1.8
1.7
1.5
1.4
4X5.5
70
4.6
83
110
135
3.0
2.6
1.9
5X5.5
6.3X5.5
5X5.5
6.3X5.5
6.3X5.5
22
4X5.5
53
3.5
4X5.5
80
2.6
27
4X5.5
65
3.2
5X5.5
85
2.4
4X5.5
5X5.5
5X5.5
4X5.5
80
2.8
4X5.5
85
2.3
5X5.5
160
2.2
5X5.5
145
1.4
5X5.5
82
2.6
5X5.5
110
2.1
6.3X5.5
170
1.5
6.3X5.5
175
1.3
4X5.5
82
2.4
5X5.5
130
2.0
5X5.5
170
2.0
5X5.5
5X5.5
85
94
2.2
1.70
6.3X5.5
6.3X5.5
160
180
1.5
1.45
6.3X5.5
6.3X5.5
6.3X5.5
6.3X7.7
8X6.5
6.3X5.5
6.3X7.7
6.3X7.7
8X6.5
6.3X7.7
8X6.5
185
195
205
210
220
210
220
225
240
250
260
1.5
1.3
1.2
1.1
1.0
1.1
0.9
0.8
0.7
0.75
0.66
6.3X5.5
6.3X7.7
8X6.5
6.3X5.5
6.3X5.5
6.3X7.7
8X6.5
6.3X7.7
8X6.5
180
195
220
195
200
210
230
220
250
1.2
0.8
0.75
1.15
1.1
0.75
0.7
0.75
0.7
8X10.5
420
8X10.5
10X10.5
480
500
33
47
56
5X5.5
100
1.6
6.3X5.5
195
1.4
6.3X5.5
120
1.3
6.3X7.7
210
1.3
5X5.5
6.3X5.5
6.3X5.5
150
6.3X7.7
6.3X5.5
220
6.3X7.7
6.3X7.7
330
8X6.5
470 8X10.5
680 8X10.5
8X10.5
1000
10X10.5
1200 10X10.5
1500 10X10.5
110
160
170
195
195
210
230
250
380
420
470
500
530
570
1.5
1.1
0.95
0.85
0.6
0.57
0.51
0.49
0.45
0.42
0.28
0.25
0.20
0.17
6.3X5.5
6.3X7.7
6.3X5.5
8X6.5
6.3X7.7
8X6.5
210
230
220
240
245
255
1.3
1.2
1.0
0.8
0.6
0.55
68
100
Size
4X5.5
4X5.5
4X5.5
4X5.5
4X5.5
5X5.5
4X5.5
5X5.5
6.3X5.5
5X5.5
6.3X5.5
5X5.5
6.3X5.5
6.3X5.5
6.3X5.5
6.3X7.7
8X6.5
6.3X5.5
6.3X7.7
8X6.5
6.3X7.7
50
(63)
Ripple Impedance
53
53
53
53
65
85
90
98
110
120
140
140
150
165
185
210
230
200
220
240
230
5
5
5
5
4.0
2.8
3.5
2.5
2.4
1.8
1.5
1.4
1.3
1.2
1.2
0.9
0.8
1.0
0.75
0.7
0.73
Size
4X5.5
4X5.5
4X5.5
4X5.5
Ripple Impedance
53
53
53
53
5
5
5
5
5X5.5
65
4
5X5.5
90
3.5
6.3X5.5
100
2.5
6.3X5.5
130
1.8
6.3X5.5
140
1.5
1.35
6.3X7.7
160
6.3X7.7
170
0.8
8X6.5
180
0.75
6.3X7.7
200
0.79
8X6.5
8X10.5
220
260
0.72
0.68
8X10.5
300
0.6
6.3X7.7
240
0.7
8X6.5
250
0.68
6.3X7.7
8X10.5
270
350
0.67
0.5
8X10.5
310
0.55
0.5
8X10.5
430
0.45
10X10.5
540
0.28
0.3
0.28
8X10.5
450
0.25
10X10.5
570
0.26
10X10.5
570
0.23
8X10.5
400
0.36
8X10.5
470
0.34
8X10.5
510
0.26
8X10.5
10X10.5
470
620
0.32
0.29
8X10.5
10X10.5
520
600
0.3
0.26
10X10.5
570
0.18
10X10.5
670
0.25
Ripple Current ( mA, rms ) at 105℃ 100KHz
Max Impedance (Ω) at 20℃ 100 KHz
70
很抱歉,暂时无法提供与“ZV100M025B055R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.17549
- 100+0.15914
- 500+0.14279
- 1000+0.12644
- 2000+0.11554
- 4000+0.11227
