KM Series
KM Series
Standard 105℃
Features
◆ Used in communication equipments, switching power supply, etc.
◆ Safety vent construction design.
◆ For detail specifications, please refer to Engineering Bulletin No. E102
◆ RoHS Compliant
Specifications
Item
Performance Characteristics
Operating Temperature Range
Rated Voltage Range
Capacitance Range
Capacitance Tolerance
Leakage Current (+20℃,max.)
Dissipation Factor
(tanδ,at 20℃,120Hz)
-40 to +105℃
6.3 to 100 VDC
0.1 to 22000 μF
-25 to +105℃
160 to 450 VDC
0.47 to 470 μF
±20% (120Hz, +20℃)
I≦0.01 CV or 3 (μA)
I≦0.03 CV (μA)
After 1 minute whichever is greater measured with rated
working voltage applied.
Working Voltage(VDC)
D.F. (%)max.
6.3
22
10
17
16
15
25
14
After 1 minute with rated working voltage applied.
35
12
50
10
63
9
100
8
63
2
3
100
2
3
Working Voltage(VDC) 160 200 250 350 400 450
D.F. (%)max.
12 12 12 15 15 17
For capacitance >1000φF, add 2% per another 1000μF.
Low Temperature Characteristics
(at 120Hz)
Z-25℃ Z+20℃
Z-40℃ Z+20℃
6.3
4
8
10
3
6
16
2
4
25
2
3
35
2
3
50
2
3
Z-25℃ Z+20℃
2
2
3
5
6
6
Radial
Impedance ratio max
For Capacitance >1000 μF, add 0.5 per another 1000 μF for -25℃ +20℃
add 1 per another 1000 μF for -40℃ +20℃
Load Life
Test conditions
Duration time
:2000Hrs
Ambient temperature
:+105℃
Applied voltage
:Rated DC working voltage
After test requirement at +20℃
Capacitance change
:≦ ±20% of the initial measured value
Dissipation factor
:≦ 200% of the initial specified value
Leakage current
:≦ The initial specified value
Shelf Life
Test conditions
Duration time
:1000Hrs
Ambient temperature
:+105℃
Applied voltage
:None
After test requirement at +20℃:Same limits as Load life.
Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes.
Multiplier for Ripple Current vs. Frequency
CAP(μF) Frequency(Hz) 50(60) 120
CAP≦10
0.8
1
10<CAP≦100
0.8
1
100<CAP≦1000
0.8
1
1000<CAP
0.8
1
400
1.30
1.23
1.16
1.11
1K
1.45
1.36
1.25
1.17
10K 50K-100K
1.65
1.70
1.48
1.53
1.35
1.38
1.25
1.28
Diagram of Dimensions:(unit:mm)
Dφ
F
dφ
α
5
2.0
6.3
2.5
0.5
D<18
1.5
109
8
3.5
L<20
0.5
L≧20
0.6
10
5.0
D=18
L<35.5 L≧35.5
1.5
2.0
13
5.0
0.6
D>18
2.0
16
7.5
18
7.5
0.8
22
10
KM Series
Case Size
φDxL(mm)
WV (SV)
Cap(μF)
4.7
6.8
10
22
33
47
68
100
120
150
180
220
330
470
560
680
820
1000
1200
1500
1800
2200
2700
3300
3900
4700
5600
6800
8200
10000
12000
15000
18000
22000
6.3
(8)
Size
10
(13)
16
(20)
Ripple
Size
Ripple
5X11
5X11
5X11
5X11
54
65
75
96
5X11
5X11
5X11
5X11
5X11
45
60
70
80
105
5X11
110
5X11
6.3X11
6.3X11
120
130
140
5X11
6.3X11
5X11
6.3X11
6.3X11
110
120
120
145
160
6.3X11
160
6.3X11
6.3X11
195
6.3X11
8X11.5
8X11.5
220
270
310
8X11.5
360
8X11.5
10X12.5
25
(32)
Size
Ripple
5X11
5X11
5X11
5X11
5X11
5X11
6.3X11
6.3X11
35
54
64
100
105
115
130
155
6.3X11
170
6.3X11
175
390
430
6.3X11
8X11.5
6.3X11
8X11.5
8X11.5
10X12.5
8X11.5
8X16
10X12.5
10X12.5
205
255
235
290
330
340
365
410
480
520
10X12.5
550
10X16
630
10X16
625
10X16
10X16
10X20
10X20
710
750
775
850
8X20
10X16
10X20
10X20
13X20
13X20
13X20
13X25
13X25
16X25
16X25
16X31.5
16X35.5
18X31.5
18X41
960
1000
1150
1300
1480
1520
1680
1750
2075
2150
2300
10X25
13X20
13X20
13X20
13X25
16X25
16X25
16X31.5
16X35.5
16X35.5
18X35.5
18X35.5
35
(44)
Size
5X11
5X11
5X11
5X11
5X11
5X11
6.3X11
6.3X11
Ripple
26
32
38
58
69
105
120
145
6.3X11
175
190
6.3X11
8X11.5
8X11.5
180
200
210
6.3X11
215
8X11.5
235
6.3X11
8X11.5
8X11.5
8X16
225
265
370
400
10X12.5
8X16
10X12.5
10X16
10X12.5
10X16
10X20
410
470
480
550
540
600
700
8X11.5
10X12.5
8X11.5
10X12.5
10X16
310
335
410
440
460
10X16
10X20
10X20
520
640
710
13X20
810
715
770
820
860
10X20
820
13X20
900
13X20
13X20
920
1000
13X25
13X25
1050
1200
880
920
1100
1280
1350
1490
1670
1840
1900
2050
2180
2205
13X20
1080
16X25
1320
13X25
16X25
16X25
16X31.5
16X31.5
16X35.5
18X35.5
18X35.5
1200
1490
1600
1720
1900
2020
2060
2150
16X25
16X31.5
16X35.5
16X35.5
18X35.5
18X35.5
1460
1670
1780
1890
2050
2090
Size
5X11
5X11
5X11
5X11
5X11
5X11
6.3X11
6.3X11
8X11.5
8X11.5
Ripple
28
36
46
61
75
110
140
160
175
185
8X11.5
215
8X11.5
10X12.5
8X11.5
10X12.5
10X12.5
225
265
255
300
400
10X16
520
10X20
540
10X20
13X20
13X20
13X20
560
650
760
830
13X20
13X25
13X25
900
930
960
16X25
16X25
16X31.5
16X31.5
1150
1290
1350
1480
16X35.5
18X31.5
18X35.5
18X35.5
1650
1820
1900
2000
Ripple Current ( mA, rms ) at 105℃ 120Hz
110
KM Series
φDxL(mm)
Cap(μF)
0.1
0.22
0.33
0.47
1
2.2
3.3
4.7
6.8
10
22
33
47
68
100
120
150
180
220
330
470
560
680
820
1000
1200
1500
1800
2200
2700
3300
50
(63)
63
(79)
100
(125)
160
(200)
Size
5X11
5X11
5X11
5X11
5X11
Ripple
1.3
2.9
4
7
13
Size
5X11
5X11
5X11
5X11
5X11
Ripple
1.3
2.9
4.5
7
13
Size
5X11
5X11
5X11
5X11
5X11
Ripple
1.9
3.4
5
10
15
5X11
5X11
5X11
5X11
5X11
5X11
21
30
5X11
32
5X11
32
5X11
35
5X11
40
5X11
40
6.3X11
47
5X11
48
5X11
60
5X11
6.3X11
6.3X11
42
48
82
6.3X11
8X11.5
6.3X11
56
60
75
6.3X11
5X11
70
75
6.3X11
100
8X11.5
8X11.5
90
140
6.3X11
6.3X11
90
115
6.3X11
8X11.5
8X11.5
130
155
200
6.3X11
8X11.5
8X11.5
10X12.5
10X12.5
125
140
155
185
230
10X12.5
8X16
10X12.5
10X16
155
165
170
240
10X20
280
8X16
10X12.5
10X12.5
220
225
245
10X16
255
10X20
295
10X16
270
10X12.5
10X16
10X12.5
10X16
10X16
10X20
10X20
13X20
13X20
13X20
13X25
13X25
13X25
16X25
16X25
16X31.5
16X35.5
16X35.5
18X35.5
18X35.5
260
280
345
360
450
470
600
650
660
700
770
850
890
1000
1150
1300
1480
1530
1590
1750
10X16
310
10X16
10X20
13X20
375
400
580
13X20
13X25
13X20
13X25
13X25
340
360
410
480
520
16X25
690
13X20
690
13X25
16X25
770
880
16X25
16X31.5
920
1185
16X25
16X31.5
16X35.5
16X35.5
18X31.5
18X35.5
18X41
820
860
900
920
950
1020
1200
16X35.5
18X31.5
1200
1350
200
(250)
Size
Ripple
Size
Ripple
5X11
5X11
6.3X11
6.3X11
6.3X11
11
17
19
25
32
5X11
6.3X11
12
17
6.3X11
8X11.5
8X11.5
38
42
56
8X11.5
10X12.5
10X12.5
10X16
10X20
10X16
63
75
95
105
120
155
6.3X11
6.3X11
8X11.5
6.3X11
8X11.5
8X11.5
10X12.5
8X11.5
10X12.5
10X16
25
33
35
42
50
60
63
78
85
125
10X20
10X20
13X20
13X20
13X25
13X25
16X25
13X25
16X25
16X25
170
180
210
260
280
310
330
320
350
470
10X20
10X16
10X20
13X20
13X20
130
160
180
190
220
16X25
550
16X31.5
16X35.5
18X31.5
18X35.5
18X35.5
18X41
560
580
660
700
810
860
13X20
13X25
13X25
16X25
16X25
16X31.5
16X25
16X31.5
16X31.5
16X35.5
16X35.5
18X31.5
18X35.5
18X41
18X41
22X41
18X51
270
300
320
345
360
390
440
480
550
560
670
690
750
810
840
925
940
111
Radial
WV (SV)
KM Series
φDxL(mm)
WV (SV)
Cap(μF)
0.47
1
250
(300)
350
(400)
Size
6.3X11
6.3X11
8X11.5
Ripple
13
16
31
8X11.5
34
46
10X12.5
8X11.5
38
47
10X12.5
50
10X12.5
52
8X11.5
10X12.5
60
70
10X12.5
79
8X11.5
10X12.5
10X16
10X20
13X20
13X20
68
80
110
125
150
190
10X16
10X20
13X20
47
13X20
13X25
230
240
56
13X20
13X25
2.2
3.3
4.7
6.8
10
22
33
68
82
100
120
150
180
220
330
Size
5X11
6.3X11
6.3X11
8X11.5
8X11.5
Ripple
8
16
33
8X11.5
400
(450)
420
(470)
Size
6.3X11
6.3X11
6.3X15
8X11.5
6.3X15
8X11.5
10X12.5
8X11.5
10X12.5
10X16
Ripple
14
17
34
35
35
36
41
48
55
65
87
92
160
8X14
8X16
10X16
10X16
10X20
13X20
13X25
13X20
13X25
16X25
16X31.5
170
180
200
245
260
255
280
16X25
13X25
310
16X25
16X25
355
370
16X25
16X31.5
16X31.5
16X35.5
16X35.5
18X31.5
18X31.5
18X35.5
18X35.5
18X41
18X45
22X41
450
(500)
Size
6.3X11
8X11.5
8X11.5
Ripple
14
Size
6.3X11
8X11.5
10X12.5
Ripple
14
10X12.5
42
10X12.5
58
8X11.5
10X12.5
10X16
8X16
32
38
42
44
10X16
61
75
80
90
110
125
170
10X16
84
10X12.5
10X16
10X16
10X20
45
50
65
72
10X20
10X20
96
112
10X20
13X20
13X20
92
98
165
13X25
13X20
13X25
16X25
16X31.5
190
235
260
300
360
13X25
185
16X25
16X31.5
230
310
13X25
16X25
180
210
330
16X25
16X31.5
360
400
16X35.5
390
16X31.5
370
470
385
18X35.5
500
375
395
420
18X31.5
390
18X35.5
555
16X41
400
430
460
460
465
470
650
700
720
780
18X35.5
18X41
400
420
18X41
18X41
630
660
340
380
350
370
400
370
450
460
470
465
480
525
560
580
650
18X45
690
18X41
430
440
480
500
470
520
530
550
550
580
580
610
650
700
18X31.5
16X35.5
18X25
16X35.5
18X31.5
18X25
18X31.5
18X31.5
18X35.5
18X31.5
18X35.5
18X35.5
18X35.5
18X41
18X45
16X31.5
16X35.5
18X25
16X31.5
16X35.5
18X25
16X35.5
18X31.5
18X35.5
18X31.5
18X35.5
18X35.5
18X41
18X41
22X41
18X45
680
22X41
500
112
很抱歉,暂时无法提供与“KM101M400K250A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.21320
- 10+5.09600
- 30+4.52760
