MV101M016E077A
MV101M016E077A
    CAPXON(台湾丰宾)
    SMD,D6.3xL7.7mm
    贴片铝电解电容 SMD,D6.3xL7.7mm 100µF ±20% 16V 5000Hrs@105℃
MV101M016E077A 数据手册
MV Series MV Series Chip type ,Long Life, High CV Features SMD ◆ Chip type long life capacitance in large case sizes ◆ Chip type with load life of 5000 hours at +105℃ ◆ Designed for surface mounting on high density PC board ◆ Applicable to automatic insertion machine using carrier tape ◆ Complied to the RoHS directive ◆ For detail specifications, please refer to Engineering Bulletin NO. E156 ◆ RoHS Compliant Specifications Item Operating Temperature Range Rated Voltage Range Capacitance Range Capacitance Tolerance Leakage Current (+20℃,max.) Performance Characteristics -40~+105℃ 6.3~50 VDC 0.1 to 1000μF ±20%(120Hz,+20℃) I≦0.01 CV or 3 (μA)After 2 minutes whichever is greater measured with rated working voltage applied. Dissipation Factor (tanδ,at 20℃,120Hz) Working Voltage(VDC) 6.3 10 16 25 35 50 D.F.(%)max. 32 28 22 16 13 12 Impedance ratio max (at: 120Hz) Low Temperature Characteristics (at 120Hz) Load Life Shelf Life 6.3 10 16 25 35 50 Z-25℃ / Z+20℃ Working voltage(VDC) 4 3 2 2 2 2 Z-40℃ / Z+20℃ 10 7 5 3 3 3 Test condition Duration time Ambient temperature Applied voltage : 5000 Hrs :+105℃ :Rated DC working voltage After test requirement at +20℃ Capacitance change : Within ±30% of initial value Dissipation factor : Less than 300% of specified value Leakage current : Less than specified value Test condition Duration time :1000 Hrs :+105℃ Ambient temperature Applied voltage :None After test requirement at +20℃ :Same limits as Load life. Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes. The following specifications shall be satisfied when the capacitors are restored to20℃ after exposing them at 250℃ for 30 seconds. Resistance to soldering heat Leakage current Capacitance change Less than specified value Within ±10% of initial value tanδ Less than specified value Multiplier for Ripple Current vs. Frequency CAP(μF) Frequency(Hz) 0.1≦CAP≦100μF 100<CAP≦1000μF 60(50) 0.8 0.8 120 1.0 1.0 500 1.20 1.10 1K 1.30 1.15 ≧10K 1.50 1.20 Diagram of Dimensions:(unit:mm) φD 4 5 6.3 6.3 8 8 10 Cathode 63 L A B C 5.5 4.3 4.3 4.9 5.5 5.3 5.3 5.9 5.5 6.6 6.6 7.2 7.7 6.6 6.6 7.2 6.5 8.3 8.3 9.0 10.5 8.3 8.3 9.0 10.5 10.3 10.3 11.0 W 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.7~1.1 0.7~1.1 P 1.0 1.4 2.2 2.2 2.3 3.1 4.5 MV Series Case Size φDxL(mm) 6.3 (8) WV(SV) Cap(μF) Size 10 (13) Ripple Size 16 (20) Ripple Size 25 (32) Ripple Ripple 0.1 4X5.5 1.0 0.22 4X5.5 2.6 0.33 4X5.5 3.2 0.47 4X5.5 3.8 1.0 4X5.5 6.2 2.2 4X5.5 11 3.3 4X5.5 14 10 Ripple Size 50 (63) Size 4.7 Size 35 (44) Ripple 4X5.5 13 4X5.5 15 5X5.5 19 4X5.5 17 4X5.5 23 5X5.5 25 6.3X5.5 30 22 4X5.5 22 5X5.5 28 5X5.5 30 6.3X5.5 40 6.3X5.5 42 6.3X7.7 52 33 5X5.5 32 5X5.5 34 6.3X5.5 44 6.3X5.5 48 6.3X7.7 57 8X10.5 80 47 5X5.5 36 6.3X5.5 48 6.3X5.5 50 6.3X7.7 63 8X10.5 92 8X10.5 95 100 6.3X5.5 60 6.3X7.7 79 6.3X7.7 81 8X10.5 116 10X10.5 150 10X10.5 160 220 6.3X7.7 110 8X10.5 140 10X10.5 216 10X10.5 240 10X10.5 280 330 8X10.5 160 10X10.5 240 10X10.5 300 10X10.5 375 470 10X10.5 260 10X10.5 280 10X10.5 320 1000 10X10.5 340 Ripple Current ( mA, rms ) at 105℃ 120Hz 64
MV101M016E077A 价格&库存
很抱歉,暂时无法提供与“MV101M016E077A”相匹配的价格&库存,您可以联系我们找货
