ZV101M050F105R
ZV101M050F105R
    CAPXON(台湾丰宾)
    SMD,D8xL10.5mm
    贴片铝电解电容 SMD,D8xL10.5mm 100µF ±20% 50V 2000Hrs@105℃
ZV101M050F105R 数据手册
ZV Series ZV Series Features SMD ◆ Low impedence 100 KHz ◆ Reflow soldering is available ◆ Available for high density mounting ◆ Load life 2000 hrs at 105℃ ◆ For detail specifications, please refer to Engineering Bulletin No.E135 ◆ RoHS Compliant Specifications Item Operating Temperature Range Rated Voltage Range Capacitance Range Capacitance Tolerance Leakage Current (+20℃,max.) Dissipation Factor (tanδ,at 20℃,120Hz) Performance Characteristics -55~ +105℃ 6.3~50 VDC 1 to 1500μF ±20%(120Hz,+20℃) 0.01CV or 3(μA) After 2 minutes, whichever is greater measured with rated working voltage applied Working voltage(VDC) D.F. (%) max. 6.3 26 10 19 16 16 25 14 35 14 50 12 6.3 2 8 10 3 6 16 2 4 25 2 4 35 2 3 50 2 3 Impedance ratio max Low Temperature Characteristics (at 120Hz) Load Life Shelf Life Working voltage(VDC) Z-25℃ Z+20℃ Z-55℃ Z+20℃ Test conditions Duration time Ambient temperature Applied voltage :2000 Hrs :+105℃ :Rated DC working voltage After test requirement at +105℃ : Capacitance change :≦±25% of the initial measured value Dissipation factor :≦200% of the initial specified value Leakage current :≦The initial specified value Test conditions Duration time :1000 Hrs Ambient temperature :+105℃ Applied voltage :None After test requirement at +20℃ : Same limits as Load life. Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes. The capacitors shall be kept on the hot plate maintained at 250℃for 30 seconds. After removing form the hot plate and restored at room temperature, they meet the characteristic requirements listed under. Resistance to soldering heat Leakage current Less than specified value Capacitance change Within ±10% of initial value tanδ Less than specified value Multiplier for Ripple Current vs. Frequency CAP(μF) Frequency(Hz) 60(50) 120 0.47 0.59 CAP≦10 0.52 0.65 10<CAP≦100 400 0.76 0.80 1K 0.85 0.89 10K 50K-100K 0.97 1.0 0.97 1.0 Diagram of Dimensions:(unit:mm) φD 4 5 6.3 6.3 8 8 10 69 L A B C 5.5 4.3 4.3 4.9 5.5 5.3 5.3 5.9 5.5 6.6 6.6 7.2 7.7 6.6 6.6 7.2 6.5 8.3 8.3 9.0 10.5 8.3 8.3 9.0 10.5 10.3 10.3 11.0 W 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.5~0.8 0.7~1.1 0.7~1.1 P 1.0 1.4 2.2 2.2 2.3 3.1 4.5 ZV Series Case Size φDxL(mm) WV 6.3 (8) (SV) Cap (µF) 1.0 2.2 3.3 4.7 Size 10 (13) Ripple Impedance Size 16 (20) Ripple Impedance Size 25 (32) Ripple Impedance 6.8 10 4X5.5 15 65 5 Size 35 (44) Ripple Impedance 4X5.5 53 5 4X5.5 58 4.5 4X5.5 74 3.7 5X5.5 80 2.6 100 115 128 140 145 2.2 1.8 1.7 1.5 1.4 4X5.5 70 4.6 83 110 135 3.0 2.6 1.9 5X5.5 6.3X5.5 5X5.5 6.3X5.5 6.3X5.5 22 4X5.5 53 3.5 4X5.5 80 2.6 27 4X5.5 65 3.2 5X5.5 85 2.4 4X5.5 5X5.5 5X5.5 4X5.5 80 2.8 4X5.5 85 2.3 5X5.5 160 2.2 5X5.5 145 1.4 5X5.5 82 2.6 5X5.5 110 2.1 6.3X5.5 170 1.5 6.3X5.5 175 1.3 4X5.5 82 2.4 5X5.5 130 2.0 5X5.5 170 2.0 5X5.5 5X5.5 85 94 2.2 1.70 6.3X5.5 6.3X5.5 160 180 1.5 1.45 6.3X5.5 6.3X5.5 6.3X5.5 6.3X7.7 8X6.5 6.3X5.5 6.3X7.7 6.3X7.7 8X6.5 6.3X7.7 8X6.5 185 195 205 210 220 210 220 225 240 250 260 1.5 1.3 1.2 1.1 1.0 1.1 0.9 0.8 0.7 0.75 0.66 6.3X5.5 6.3X7.7 8X6.5 6.3X5.5 6.3X5.5 6.3X7.7 8X6.5 6.3X7.7 8X6.5 180 195 220 195 200 210 230 220 250 1.2 0.8 0.75 1.15 1.1 0.75 0.7 0.75 0.7 8X10.5 420 8X10.5 10X10.5 480 500 33 47 56 5X5.5 100 1.6 6.3X5.5 195 1.4 6.3X5.5 120 1.3 6.3X7.7 210 1.3 5X5.5 6.3X5.5 6.3X5.5 150 6.3X7.7 6.3X5.5 220 6.3X7.7 6.3X7.7 330 8X6.5 470 8X10.5 680 8X10.5 8X10.5 1000 10X10.5 1200 10X10.5 1500 10X10.5 110 160 170 195 195 210 230 250 380 420 470 500 530 570 1.5 1.1 0.95 0.85 0.6 0.57 0.51 0.49 0.45 0.42 0.28 0.25 0.20 0.17 6.3X5.5 6.3X7.7 6.3X5.5 8X6.5 6.3X7.7 8X6.5 210 230 220 240 245 255 1.3 1.2 1.0 0.8 0.6 0.55 68 100 Size 4X5.5 4X5.5 4X5.5 4X5.5 4X5.5 5X5.5 4X5.5 5X5.5 6.3X5.5 5X5.5 6.3X5.5 5X5.5 6.3X5.5 6.3X5.5 6.3X5.5 6.3X7.7 8X6.5 6.3X5.5 6.3X7.7 8X6.5 6.3X7.7 50 (63) Ripple Impedance 53 53 53 53 65 85 90 98 110 120 140 140 150 165 185 210 230 200 220 240 230 5 5 5 5 4.0 2.8 3.5 2.5 2.4 1.8 1.5 1.4 1.3 1.2 1.2 0.9 0.8 1.0 0.75 0.7 0.73 Size 4X5.5 4X5.5 4X5.5 4X5.5 Ripple Impedance 53 53 53 53 5 5 5 5 5X5.5 65 4 5X5.5 90 3.5 6.3X5.5 100 2.5 6.3X5.5 130 1.8 6.3X5.5 140 1.5 1.35 6.3X7.7 160 6.3X7.7 170 0.8 8X6.5 180 0.75 6.3X7.7 200 0.79 8X6.5 8X10.5 220 260 0.72 0.68 8X10.5 300 0.6 6.3X7.7 240 0.7 8X6.5 250 0.68 6.3X7.7 8X10.5 270 350 0.67 0.5 8X10.5 310 0.55 0.5 8X10.5 430 0.45 10X10.5 540 0.28 0.3 0.28 8X10.5 450 0.25 10X10.5 570 0.26 10X10.5 570 0.23 8X10.5 400 0.36 8X10.5 470 0.34 8X10.5 510 0.26 8X10.5 10X10.5 470 620 0.32 0.29 8X10.5 10X10.5 520 600 0.3 0.26 10X10.5 570 0.18 10X10.5 670 0.25 Ripple Current ( mA, rms ) at 105℃ 100KHz Max Impedance (Ω) at 20℃ 100 KHz 70
ZV101M050F105R 价格&库存
很抱歉,暂时无法提供与“ZV101M050F105R”相匹配的价格&库存,您可以联系我们找货
