HG82C51N
HG82C51N
    HGSEMI(华冠)
    DIP28
    通用同步异步收发信机
HG82C51N 数据手册
HG82C51 UNIVERSAL SYNCHRONOUS ASYNCHRONOUS RECEIVER TRANSMITTER GENERAL DESCRIPTION The HG82C51 is a USART (Universal Synchronous Asynchronous Receiver Transmitter) for serial data communication. As a peripheral device of a microcomputer system, the HG82C51 receives parallel data from the CPU and transmits serial data after conversion. This device also receives serial data from the outside and transmits parallel data to the CPU after conversion. The HG82C51 configures a fully static circuit using silicon gate CMOS technology. Therefore, it operates on extremely low power at 100 mA (max) of standby current by suspending all operations. FEATURES • Wide power supply voltage range from 3 V to 6 V • Wide temperature range from –40°C to 85°C • Synchronous communication upto 64 Kbaud • Asynchronous communication upto 38.4 Kbaud • Transmitting/receiving operations under double buffered configuration. • Error detection (parity, overrun and framing) •28-pin Plastic DIP (DIP28-P-600-2.54) PIN CONFIGURATION (TOP VIEW) 28 pin Plastic DIP D2 1 28 D1 D3 2 27 D0 RXD 3 26 VCC GND 4 25 RXC D4 5 24 DTR D5 6 23 RTS D6 7 22 DSR D7 8 21 RESET TXC 9 20 CLK WR 10 19 TXD 18 TXEMPTY CS 11 C/D 12 17 CTS RD 13 16 SYNDET/BD 15 TXRDY RXRDY 14 http://www.hgsemi.com.cn 1 2018 AUG HG82C51 D7 - D0 Data Bus Buffer RESET CLK C/D RD WR CS Read/Write Control Logic DSR DTR CTS RTS http://www.hgsemi.com.cn Modem Control Internal Bus Line FUNCTIONAL BLOCK DIAGRAM 2 Transmit Buffer (P - S) TXD Transmit Control TXRDY TXE TXC Recieve Buffer (S - P) RXD Recieve Control RXRDY RXC SYNDET/BD 2018 AUG HG82C51 FUNCTION Outline The HG82C51's functional configuration is programed by software. Operation between the HG82C51 and a CPU is executed by program control. Table 1 shows the operation between a CPU and the device. Table 1 Operation between HG82C51 and CPU CS C/D RD WR 1 ¥ ¥ ¥ Data Bus 3-State 0 ¥ 1 1 Data Bus 3-State 0 1 0 1 Status Æ CPU 0 1 1 0 Control Word ¨ CPU 0 0 0 1 Data Æ CPU 0 0 1 0 Data ¨ CPU It is necessary to execute a function-setting sequence after resetting the HG82C51. Fig. 1 shows the function-setting sequence. If the function was set, the device is ready to receive a command, thus enabling the transfer of data by setting a necessary command, reading a status and reading/writing data. External Reset Internal Reset Write Mode Instruction Asynchronous yes no Write First Sync Charactor Single Sync Mode yes no Write Second Sync Charactor End of Mode Setting Fig. 1 Function-setting Sequence (Mode Instruction Sequence) http://www.hgsemi.com.cn 3 2018 AUG HG82C51 Control Words There are two types of control word. 1. Mode instruction (setting of function) 2. Command (setting of operation) 1) Mode Instruction Mode instruction is used for setting the function of the HG82C51. Mode instruction will be in “wait for write” at either internal reset or external reset. That is, the writing of a control word after resetting will be recognized as a “mode instruction.” Items set by mode instruction are as follows: • • • • • • • Synchronous/asynchronous mode Stop bit length (asynchronous mode) Character length Parity bit Baud rate factor (asynchronous mode) Internal/external synchronization (synchronous mode) Number of synchronous characters (Synchronous mode) The bit configuration of mode instruction is shown in Figures 2 and 3. In the case of synchronous mode, it is necessary to write one-or two byte sync characters. If sync characters were written, a function will be set because the writing of sync characters constitutes part of mode instruction. D7 D6 D5 D4 D3 D2 D1 D0 S1 S1 EP PEN L2 L1 B2 B1 Baud Rate Factor 0 1 0 1 0 Refer to Fig. 3 SYNC 0 1 1 1 ¥ 16 ¥ 64 ¥ Charactor Length 0 1 0 1 0 0 1 1 5 bits 6 bits 7 bits 8 bits Parity Check 0 1 0 1 0 0 Odd Parity 1 1 Even Parity Disable Disable Stop bit Length 0 1 0 0 0 1 1 1 Inhabit 1 bit 1.5 bits 2 bits Fig. 2 Bit Configuration of Mode Instruction (Asynchronous) http://www.hgsemi.com.cn 4 2018 AUG HG82C51 D7 D6 D5 D4 D3 D2 D1 D0 SCS ESD EP PEN L2 L1 0 0 Charactor Length 0 1 0 1 0 0 1 1 5 bits 6 bits 7 bits 8 bits 0 1 0 1 0 0 Odd Parity 1 1 Even Parity Parity Disable Disable Synchronous Mode 0 1 Internal Synchronization External Synchronization Number of Synchronous Charactors 0 1 2 Charactors 1 Charactor Fig. 3 Bit Configuration of Mode Instruction (Synchronous) http://www.hgsemi.com.cn 5 2018 AUG HG82C51 2) Command Command is used for setting the operation of the HG82C51. It is possible to write a command whenever necessary after writing a mode instruction and sync characters. Items to be set by command are as follows: • Transmit Enable/Disable • Receive Enable/Disable • DTR, RTS Output of data. • Resetting of error flag. • Sending to break characters • Internal resetting • Hunt mode (synchronous mode) The bit configuration of a command is shown in Fig. 4. D7 D6 D5 D4 D3 D2 D1 D0 EH IR RTS ER SBRK RXE DTR TXEN 1ºTransmit Enable 0ºDisable DTR 1 Æ DTR = 0 0 Æ DTR = 1 1ºRecieve Enable 0ºDisable 1ºSent Break Charactor 0ºNormal Operation 1ºReset Error Flag 0ºNormal Operation RTS 1 Æ RTS = 0 0 Æ RTS = 1 1ºInternal Reset 0ºNormal Operation 1ºHunt Mode (Note) 0ºNormal Operation Note: Seach mode for synchronous charactors in synchronous mode. Fig. 4 Bit Configuration of Command http://www.hgsemi.com.cn 6 2018 AUG HG82C51 Status Word It is possible to see the internal status of HG82C51 by reading a status word. The bit configuration of status word is shown in Fig. 5. D7 D6 D5 D4 D3 D2 D1 D0 DSR SYNDET /BD FE OE PE TXEMPTY RXRDY TXRDY Parity Different from TXRDY Terminal. Refer to "Explanation" of TXRDY Terminals. Same as terminal. Refer to "Explanation" of Terminals. 1ºParity Error 1ºOverrun Error 1ºFraming Error Note: Only asynchronous mode. Stop bit cannot be detected. Shows Terminal DSR 1ºDSR = 0 0ºDSR = 1 Fig. 5 Bit Configuration of Status Word Standby Status It is possible to put the HG82C51 in Ústandby statusÛ When the following conditions have been satisfied the HG82C51 is in Ústandby status.Û (1) CS terminal is fixed at Vcc level. (2) Input pins other CS , D0 to D7, RD, WR and C/D are fixed at Vcc or GND level (including SYNDET in external synchronous mode). Note: When all output currents are 0, ICCS specification is applied. http://www.hgsemi.com.cn 7 2018 AUG HG82C51 Pin Description D0 to D7 (l/O terminal) This is bidirectional data bus which receive control words and transmits data from the CPU and sends status words and received data to CPU. RESET (Input terminal) A ÚHighÛ on this input forces the HG82C51 into Úreset status.Û The device waits for the writing of “mode instruction.” The min. reset width is six clock inputs during the operating status of CLK. CLK (Input terminal) CLK signal is used to generate internal device timing. CLK signal is independent of RXC or TXC. However, the frequency of CLK must be greater than 30 times the RXC and TXC at Synchronous mode and Asynchronous “x1” mode, and must be greater than 5 times at Asynchronous “x16” and “x64” mode. WR (Input terminal) This is the “active low” input terminal which receives a signal for writing transmit data and control words from the CPU into the HG82C51. RD (Input terminal) This is the “active low” input terminal which receives a signal for reading receive data and status words from the HG82C51. C/D (Input terminal) This is an input terminal which receives a signal for selecting data or command words and status words when the HG82C51 is accessed by the CPU. If C/D = low, data will be accessed. If C/D = high, command word or status word will be accessed. CS (Input terminal) This is the Úactive lowÛ input terminal which selects the HG82C51 at low level when the CPU accesses. Note: The device won’t be in “standby status”; only setting CS = High. Refer to “Explanation of Standby Status.” TXD (output terminal) This is an output terminal for transmitting data from which serial-converted data is sent out. The device is in “mark status” (high level) after resetting or during a status when transmit is disabled. It is also possible to set the device in “break status” (low level) by a command. http://www.hgsemi.com.cn 8 2018 AUG HG82C51 TXRDY (output terminal) This is an output terminal which indicates that the HG82C51 is ready to accept a transmitted data character. But the terminal is always at low level if CTS = high or the device was set in “TX disable status” by a command. Note: TXRDY status word indicates that transmit data character is receivable, regardless of CTS or command. If the CPU writes a data character, TXRDY will be reset by the leading edge or WR signal. TXEMPTY (Output terminal) This is an output terminal which indicates that the HG82C51 has transmitted all the characters and had no data character. In “synchronous mode,” the terminal is at high level, if transmit data characters are no longer remaining and sync characters are automatically transmitted. If the CPU writes a data character, TXEMPTY will be reset by the leading edge of WR signal. Note : As the transmitter is disabled by setting CTS “High” or command, data written before disable will be sent out. Then TXD and TXEMPTY will be “High”. Even if a data is written after disable, that data is not sent out and TXE will be “High”.After the transmitter is enabled, it sent out. (Refer to Timing Chart of Transmitter Control and Flag Timing) TXC (Input terminal) This is a clock input signal which determines the transfer speed of transmitted data. In “synchronous mode,” the baud rate will be the same as the frequency of TXC. In “asynchronous mode”, it is possible to select the baud rate factor by mode instruction. It can be 1, 1/16 or 1/64 the TXC. The falling edge of TXC sifts the serial data out of the HG82C51. RXD (input terminal) This is a terminal which receives serial data. RXRDY (Output terminal) This is a terminal which indicates that the HG82C51 contains a character that is ready to READ. If the CPU reads a data character, RXRDY will be reset by the leading edge of RD signal. Unless the CPU reads a data character before the next one is received completely, the preceding data will be lost. In such a case, an overrun error flag status word will be set. RXC (Input terminal) This is a clock input signal which determines the transfer speed of received data. In “synchronous mode,” the baud rate is the same as the frequency of RXC. In “asynchronous mode,” it is possible to select the baud rate factor by mode instruction. It can be 1, 1/16, 1/64 the RXC. http://www.hgsemi.com.cn 9 2018 AUG HG82C51 SYNDET/BD (Input or output terminal) This is a terminal whose function changes according to mode. In “internal synchronous mode.” this terminal is at high level, if sync characters are received and synchronized. If a status word is read, the terminal will be reset. In “external synchronous mode, “this is an input terminal. A ÚHighÛ on this input forces the HG82C51 to start receiving data characters. In “asynchronous mode,” this is an output terminal which generates “high level”output upon the detection of a “break” character if receiver data contains a “low-level” space between the stop bits of two continuous characters. The terminal will be reset, if RXD is at high level. After Reset is active, the terminal will be output at low level. DSR (Input terminal) This is an input port for MODEM interface. The input status of the terminal can be recognized by the CPU reading status words. DTR (Output terminal) This is an output port for MODEM interface. It is possible to set the status of DTR by a command. CTS (Input terminal) This is an input terminal for MODEM interface which is used for controlling a transmit circuit. The terminal controls data transmission if the device is set in “TX Enable” status by a command. Data is transmitable if the terminal is at low level. RTS (Output terminal) This is an output port for MODEM interface. It is possible to set the status RTS by a command. http://www.hgsemi.com.cn 10 2018 AUG HG82C51 ABSOLUTE MAXIMUM RATING Parameter Symbol Rating Unit Power Supply Voltage VCC –0.5 to +7 V Input Voltage VIN –0.5 to VCC +0.5 V VOUT TSTG –0.5 to VCC +0.5 V –55 to +150 °C — W Ta = 25°C Output Voltage Storage Temperature Power Dissipation 0.9 PD Conditions With respect to GND OPERATING RANGE Symbol Range Unit Power Supply Voltage Parameter VCC 3-6 V Operating Temperature Top °C –40 to 85 RECOMMENDED OPERATING CONDITIONS Parameter Symbol Min. Typ. Max. Unit Power Supply Voltage VCC 4.5 5 5.5 V Operating Temperature Top –40 +25 +85 °C "L" Input Voltage VIL –0.3 — +0.8 V "H" Input Voltage VIH 2.2 — VCC +0.3 V DC CHARACTERISTICS (VCC = 4.5 to 5.5 V Ta = –40°C to +85°C) Parameter Symbol Min. — Typ. — Max. 0.45 VOH 3.7 — ILI –10 — Output Leak Current ILO –10 Operating Supply Current ICCO Standby Supply Current ICCS "L" Output Voltage VOL "H" Output Voltage Input Leak Current http://www.hgsemi.com.cn Unit Measurement Conditions V IOL = 2.5 mA — V IOH = –2.5 mA 10 mA 0 £ VIN £ VCC — 10 mA 0 £ VOUT £ VCC — — 5 mA Asynchronous X64 during Transmitting/ Receiving — — 100 mA All Input voltage shall be fixed at VCC or GND level. 11 2018 AUG HG82C51 AC CHARACTERISTICS CPU Bus Interface Part (VCC = 4.5 to 5.5 V, Ta = –40 to 85°C) Parameter Address Stable before RD Symbol tAR Min. 20 Max. — Unit ns Remarks Note 2 Address Hold Time for RD tRA 20 — ns Note 2 RD Pulse Width tRR 130 — ns — Data Delay from RD tRD — 100 ns — RD to Data Float tDF 10 75 ns Recovery Time between RD tRVR 6 — tCY — Note 5 Address Stable before WR tAW 20 — ns Note 2 Address Hold Time for WR tWA 20 — ns Note 2 WR Pulse Width tWW 100 — ns Data Set-up Time for WR tDW 100 — ns — — Data Hold Time for WR tWD 0 — ns — Recovery Time between WR tRVW 6 — tCY Note 4 RESET Pulse Width tRESW 6 — tCY — http://www.hgsemi.com.cn 12 2018 AUG HG82C51 Serial Interface Part (VCC = 4.5 to 5.5 V, Ta = –40 to 85°C) Parameter Symbol Max. — Unit Remarks Main Clock Period tCY Min. 160 ns Note 3 Clock Low Tme tf 50 — ns — Clock High Time tf 70 tCY –50 ns — Clock Rise/Fall Time tr, tf — 20 ns — TXD Delay from Falling Edge of TXC tDTX — 1 mS — fTX DC 64 kHz 16 ¥ Baud fTX DC 615 kHz 64 ¥ Baud fTX DC 615 kHz 1 ¥ Baud tTPW 13 — tCY 16 ¥, 64 ¥ Baud tTPW 2 — tCY — — 1 ¥ Baud tTPD 15 — tCY — — 1 ¥ Baud Transmitter Clock Frequency Transmitter Clock Low Time Transmitter Clock High Time Receiver Clock Frequency Receiver Clock Low Time Receiver Clock High Time Note 3 16 ¥, 64 ¥ Baud tTPD 3 — tCY 1 ¥ Baud fRX DC 64 kHz 16 ¥ Baud fRX DC 615 kHz 64 ¥ Baud fRX DC 615 kHz 1 ¥ Baud tRPW 13 — tCY — 16 ¥, 64 ¥ Baud tRPW 2 — tCY 1 ¥ Baud tRPD 15 — tCY 16 ¥, 64 ¥ Baud tRPD 3 — tCY — — — tTXRDY — 8 tCY — tTXRDY CLEAR — 400 ns — tRXRDY — 26 tCY — tRXRDY CLEAR — 400 ns — tIS — 26 tCY — Time from the Center of Last Bit to the Rise of TXRDY Time from the Leading Edge of WR to the Fall of TXRDY Time From the Center of Last Bit to the Rise of RXRDY Time from the Leading Edge of RD to the Fall of RXRDY Internal SYNDET Delay Time from Rising Edge of RXC SYNDET Setup Time for RXC Note 3 tES 18 — tCY — tTXEMPTY 20 — tCY — tWC 8 — tCY — tCR 20 — tCY — RXD Setup Time for Rising Edge of RXC (1X Baud) tRXDS 11 — tCY — RXD Hold Time for Falling Edge of RXC (1X Baud) tRXDH 17 — tCY — TXE Delay Time from the Center of Last Bit MODEM Control Signal Delay Time from Rising Edge of WR MODEM Control Signal Setup Time for Falling Edge of RD Notes: 1. AC characteristics are measured at 150 pF capacity load as an output load based on 0.8 V at low level and 2.2 V at high level for output and 1.5 V for input. 2. Addresses are CS and C/D. 3. fTX or fRX £ 1/(30 Tcy) 1¥ Baud fTX or fRX £ 1/(5 Tcy) 16¥, 64¥ Baud 4. This recovery time is mode Initialization only. Recovery time between command writes for Asynchronous Mode is 8 tCY and for Synchronous Mode is 18 tCY. Write Data is allowed only when TXRDY = 1. 5. This recovery time is Status read only. Read Data is allowed only when RXRDY = 1. 6. Status update can have a maximum delay of 28 clock periods from event affecting the status. http://www.hgsemi.com.cn 13 2018 AUG HG82C51 TIMING CHART Sytem Clock Input tf tr tf tf tCY CLK Transmitter Clock and Data tTPW TXC (1 ¥ MODE) tTPD TXC (16 ¥ MODE) tDTX tDTX TXD Receiver Clock and Data RXD RXC (1 ¥ Mode) RXC (16 ¥ Mode) (RXBAUD Counter starts here) Start bit tRPW 8RXC Periods (16¥Mode) http://www.hgsemi.com.cn Data bit 16 RXC Periods (16 ¥ Mode) 3tCY INT Sampling Pulse Data bit tRPD 3tCY tf 14 2018 AUG HG82C51 Write Data Cycle (CPU Æ USART) TXRDY tWW WR DATA IN (D. B.) tTXRDY Clear tWD tDW Don't Care Don't Care Data Stable C/D tAW tWA CS tAW tWA Read Data Cycle (CPU ¨ USART) RXRDY tRXRDY Clear tRR RD DATA OUT (D. B.) tRD Data Float tDF Data Float Data Out Active C/D tAR tRA CS tAR tRA Write Control or Output Port Cycle (CPU Æ USART) DTR. RTS DATA IN (D. B.) tWC tWW WR tWD tDW Don't Care Don't Care Data Stable C/D CS tAW tWA tAW tWA Read Control or Input Port Cycle (CPU ¨ USART) DSR. CTS tCR tRR RD DATA OUT (D. B.) tDF Data Float tRD Data Out Active Data Float tAR tRA tAR tRA C/D CS http://www.hgsemi.com.cn 15 2018 AUG HG82C51 Transmitter Control and Flag Timing (ASYNC Mode) CTS tTXEMPTY TXEMPTY TXRDY (STATUS BIT) tTXRDY TXRDY (PIN) Wr DATA 1 Wr DATA 2 Wr DATA 3 Wr DATA 4 C/D Wr TxEn Wr SBRK WR 0 1 2 3 4 5 6 TXD DATA CHAR 2 DATA CHAR 3 DATA CHAR 4 STOP BIT START BIT DATA CHAR 1 Note: The wave-form chart is based on the case of 7-bit data length + parity bit + 2 stop bit. Receiver Control and Flag Timing (ASYNC Mode) BREAK DETECT FRAMING ERROR (Status Bit) OVERRUN ERROR (Status Bit) RXRDY DATA CHAR2 Lost tRXRDY Rd Data C/D WR Wr RxEn Wr Error RxEn RD RXDATA Data CHAR 2 Data CHAR 3 Break RxEn Err Res Data Bit Start Bit Stop Bit Parity Bit Data CHAR 1 Note: The wave-form chart is based on the case of 7 data bit length + parity bit + 2 stop bit. Transmitter Control and Flag Timing (SYNC Mode) CTS TXEMPTY TXRDY (StatusBit) TXRDY (Pin) C/D Wr Data CHAR1 WR Marking State TXD Wr Data CHAR2 Wr Data CHAR3 Wr Data CHAR4 Wr Commond SBRK Data Data SYNC SYNC Data Marking CHAR1 CHAR2 CHAR1 SYNC CHAR2 CHAR3 CHAR4 State 0123 4 012 34 0 12 34 01234 012 34 0 123 4 PAR PAR PAR PAR PAR PAR Spacing State Wr Data CHAR5 Marking State Data SYNC CHAR5 CHAR ETC 0123 4 012 34 0 1 PAR PAR Note: The wave-form chart is based on the case of 5 data bit length + parity bit and 2 synchronous charactors. http://www.hgsemi.com.cn 16 2018 AUG HG82C51 Receiver Control and Flag Timing (SYNC Mode) (Note 2) SYNDET (Pin) (Note 1) tES tIS SYNDET (SB) OVERRUN ERROR (SB) Data CHAR2 Lost RXRDY (PIN) Rd Status C/D Wr EH RxEn Wr Err Res Rd Data CHAR 1 Rd Data CHAR 3 Rd Status Rd Status Wr EHo Rd SYNC CHAR 1 WR RD Don't Care RXD SYNC CHAR 1 SYNC CHAR 2 Data CHAR 1 Data CHAR 2 Data CHAR 3 SYNC CHAR 1 SYNC CHAR 2 Don't Care Data CHAR 1 x x x x x x 0 1 2 3 4 0 1 2 3 4 0 1 2 3 4 0 1 2 3 4 0 1 2 3 4 0 1 2 3 4 0 1 2 3 4 0 1 2 3 4 PAR PAR PAR PAR CHAR ASSY Begins RXC PAR Exit Hunt Mode Set SYNDET PAR x x x x x x x PAR PAR Data CHAR 2 CHAR ASSY Begins Exit Hunt Mode Set SYNDET (Status bit) ETC 0 1 x 3 4 PAR PAR Set SYNDET (Status bit) Note: 1. Internal Synchronization is based on the case of 5 data bit length + parity bit and 2 synchronous charactor. 2. External Synchronization is based on the case of 5 data bit length + parity bit. Note: 1. Half-bit processing for the start bit When the HG82C51 is used in the asynchronous mode, some problems are caused in the processing for the start bit whose length is smaller than the 1-data bit length. (See Fig. 1.) Start bit Length Mode Operation Smaller than 7-Receiver Clock Length ¥16 The short start bit is ignored. (Normal) Smaller than 31-Receiver Clock Length ¥64 The short start bit is ignored. (Normal) 8-Receiver Clock Length ¥16 Data cannot be received correctly due to a malfunction. 32-Receiver Clock Length ¥64 Data cannot be received correctly due to a malfunction. 9 to 16-Receiver Clock Length ¥16 The bit is regarded as a start bit. (normal) 33 to 64-Receiver Clock Length ¥64 The bit is regarded as a start bit. (normal) 2. Parity flag after a break signal is received (See Fig. 2.) When theHG82C51 is used in the asynchrous mode, a parity flag may be set when the next normal data is read after a break signal is received. A parity flag is set when the rising edge of the break signal (end of the break signal) is changed between the final data bit and the parity bit, through a RXRDY signal may not be outputted. If this occurs, the parity flag is left set when the next normal dats is received, and the received data seems to be a parity error. http://www.hgsemi.com.cn 17 2018 AUG HG82C51 Half-bit Processing Timing Chart for the Start bit (Fig. 1) Normal Operation RXD ST D0 D1 D2 D3 D4 D5 D6 D7 P SP ST D0 D1 D2 D3 D4 D5 D6 D7 P SP RXRDY The Start bit Is Shorter Than a 1/2 Data bit ST D0 D1 D2 D3 D4 D5 D6 D7 P SP RXD ST RXRDY The Start bit Is a 1/2 Data bit (A problem of HG82C51) ST D0 D1 D2 D3 D4 D5 D6 D7 P SP RXD ST RXRDY A RXRDY signal is outputted during data reception due to a malfunction. The Start bit Is Longer Than a 1/2 Data bit ST D0 D1 D2 D3 D4 D5 D6 D7 P SP RXD ST RXRDY ST: SP: P: D0 - D7: Start bit Stop bit Parity bit Data bits http://www.hgsemi.com.cn 18 2018 AUG HG82C51 Break Signal Reception Timing and Parity Flag (Fig. 2) Normal Operation BIT POS. ST D0 D7 P SP ST D0 D7 P SP ST D0 D1 D2 D3 D4 D5 D6 D7 P SP RXD RXRDY ≠ No parity flag is set. and no RXRDY signal is outputted. Bug Timing BIT POS. ST D0 D7 P SP ST D0 D7 P SP ST D0 D1 D2 D3 D4 D5 D6 D7 P SP RXD RXRDY ≠ A parity flag is set, but, no RXRDYsignal is outputted. Normal Operation BIT POS. ST D0 D7 P SP ST D0 D7 P SP ST D0 D1 D2 D3 D4 D5 D6 D7 P SP RXD RXRDY ≠ A parity flag is set. and a RXRDY signal is outputted. http://www.hgsemi.com.cn 19 2018 AUG HG82C51 Important statement: Huaguan Semiconductor Co,Ltd. reserves the right to change the products and services provided without notice. Customers should obtain the latest relevant information before ordering, and verify the timeliness and accuracy of this information. Customers are responsible for complying with safety standards and taking safety measures when using our products for system design and machine manufacturing to avoid potential risks that may result in personal injury or property damage. Our products are not licensed for applications in life support, military, aerospace, etc., so we do not bear the consequences of the application of these products in these fields. Our documentation is only permitted to be copied without any tampering with the content, so we do not accept any responsibility or liability for the altered documents. http://www.hgsemi.com.cn 20 2018 AUG
HG82C51N
物料型号:HG82C51
器件简介:HG82C51是一款通用同步/异步接收/发送器(USART),用于串行数据通信。作为微机系统的外围设备,HG82C51接收来自CPU的并行数据并转换为串行数据进行传输,同时也将外部的串行数据转换为并行数据发送给CPU。该设备采用硅门CMOS技术构建全静态电路,因此在所有操作暂停时,待机电流仅为100mA(最大),运行在极低功耗状态。
引脚分配:HG82C51采用28引脚塑料DIP封装,具有数据总线、控制线和电源地线等引脚。
参数特性:支持3V至6V的宽电源电压范围和-40°C至85°C的温度范围。同步通信速率高达64Kbaud,异步通信速率高达38.4Kbaud。具备双缓冲配置下的发送/接收操作、错误检测(奇偶校验、溢出和帧错误)。
功能详解:HG82C51的功能配置由软件编程确定。通过编程控制HG82C51与CPU之间的操作。包括模式指令和命令,用于设置功能和操作模式。
应用信息:HG82C51适用于需要串行数据通信的应用场景,如数据终端设备(DTE)和数据通信设备(DCE)之间的通信。
封装信息:HG82C51采用28引脚塑料DIP封装,具体封装类型为DIP28-P-600-2.54。
HG82C51N 价格&库存
很抱歉,暂时无法提供与“HG82C51N”相匹配的价格&库存,您可以联系我们找货
HG82C51N
    库存:5000
