LM1875
20W AUDIO POWER AMPLIFIER
DESCRIPTION
The HG LM1875 is a monolithic power amplifier offering
very low distortion and high quality performance for
consumer audio applications.
The HG LM1875 delivers 20 wants into a 4 Ω or 8Ω load
on +25V supplies.Using an 8 Ω load and +30V
supplies,over 30 watts of power may be delivered.The
amplifier is designed to operate with a minimum ofexternal
components.Device overload protection consists of both
internal current limit and thernal shutdown.
The HG LM1875 design takes advantage of advanced
circuit techniques and processing to achieve extremely low
distortion levels even at high output power levels.Other
outstanding features include high gain,fast slew rate and a
wide power bandwidth,large output voltage swing,high
current capability,and a very wide supply range.The
amplifier is internally compensated and stable for gains of
10 or greater.
1
TO-220B
1
TO-220-5
1: +IN
4: Output
FEATURES
*2: -IN
5: Vcc
3: -VEE
*Up to 30 watts output power
*Avo typically 90 dB
*Low distortion: 0.015%,1kHz,20W
*Wide power bandwidth: 70kHz
*Protection for AC and DC short circuits to ground
*Themal protection with parole circuit
*High current capability: 4A
*Wide supply range 16V-60V
*Internal output protection diodes
*94 dB ripple rejection
APPLICATIONS
*High performance audio systems
*Bridge amplifiers
*Stereo phonographs
*Servo amplifiers
*Instrument systems
http://www.hgsemi.com.cn
1
2016 JAN
LM1875
TYPICAL APPLICATIONS
+Vcc
C3
0.1μF
4Ω~8Ω
C1
2.2μF
1
VIN
5
R2
22k
R1
1M
C7 100μF
4
LM1875
2 _
R5
1
3
-VEE
C4
0.1μF
R4
20k
C6
+ 100μF
C5
0.22μF
R3 1K
C2
22μF
ABSOLUTE MAXIMUM RATINGS
PARAMETER
Supply Voltage
Input Voltage
Storage Temperature
Junction Temperature
Lead Temperature(Soldering,10 seconds)
SYMBOL
RATING
UNIT
Vs
VIN
Tstg
TJ
TL
60
-VEE ~ Vcc
-65 ~ +150
150
260
V
V
SYMBOL
RATING
UNIT
θJC
θJA
3
73
℃/W
℃/W
THERMAL DATA
DESCRIPTION
Thermal Resistance, Junction-case
Thermal Resistance, Junction-ambient
ELECTRICAL CHARACTERISTICS
Vcc=+25V,-VEE=-25V,TAMBIENT=25℃,RL=8Ω,Av=20(26dB),fo=1kHz,unless otherwise specified.
SYMBOL
TEST CONDITIONS
Supply Current
Output Power(Note 1)
Total Harmonic Distortion
(Note 1)
PARAMETER
Vs
Po
THD
POUT=0W
THD=1%
POUT=20W,fo=1kHz
POUT =20W, fo =20kHz
POUT =20W,RL=4Ω,fo=1kHz
POUT =20W,RL=4Ω,fo=20kHz
Offset Voltage
Vos
2
MIN
TYP
MAX
UNIT
70
25
0.015
0.05
0.022
0.07
±1
100
mA
W
0.4
0.6
±15
mV
2016 JAN
LM1875
PARAMETER
SYMBOL
Input Bias current
Input Offset Current
Gain-Bandwidth Product
Open Loop Gain
Power Supply Rejection Ratio
Iib
IIO
GBW
Gv
PSRR
CONDITIONS
MIN
Fo=20kHz
DC
Vcc,1kHz,1 Vrms
VEE,1kHz,1 Vrms
20W,8Ω,70kHz BW
TYP
MAX
UNIT
±0.2
90
95
83
8
4
3
±2
±0.5
µA
µA
MHz
dB
52
52
dB
Max Slew Rate
SR
V/µs
ILIM
Current Limit
VOUT=VSUPPLY – 10V
3
A
Rs=600Ω,CCIR
Equivalent Input Noise
en
µVrms
Voltage
Note 1: Assumes the use of a heat sink having a thermal resistance of 1℃/W and no insulator with an ambient
temperature of 25℃.Because the output limiting circuitry has a negative temperature coefficient,the maximum output
power delivered to a 4Ωload may be slightly reduced when the tab temperature exceeds 55℃.
TYPICAL APPLICATIONS(CONTINUED)
R2 +Vcc C4
0.1μF
22k
R1
22k
C2
10μF
C1
1.0μF
VIN
R4
1M
C7
+ 100μF
R3
22k
1
LM1875
2 _
C3
R5
10μF 10k
5
4
R7
1
C5
0.22μF
3
C6
2200μF
4Ω~ 8Ω
R6
200k
3
2016 JAN
LM1875
TYPICAL PERFORMANCE CHARACTERISTICS
THD vs Power Output
THD vs Supply Voltage
0.1
Vs=+25V
0.09 PD=10W
0.08
0.07
THD(%)
TOTAL HARMONIC DISTORTION(%)
1.0
0.1
0.06
0.05
0.04
RL=4Ω
0.03
RL=8Ω
0.02
0.01
0.01
1.0
10
50 100 200 500 1K 2K 5K 10K 20K
FREQUENCY(Hz)
POWER OUTPUT(W)
Power Output vs Supply Voltage
35
100
SUPPLY CURRENT(mA)
30
POWE OUTPUT(W)
Supply Current vs Supply Voltage
RL=8Ω
THD=1%
25
10
5
80
60
40
10
15
SUPPLY VOLTAGE(+V)
90
40
80 POSITIVE SUPPLY
70
35
DEVICE DISSIP ATION(W)
PSRR(dB)
45
NEGATIVE SUPPLY
50
40
15
30
Device Dissipation vs Ambient Temperature
PSRR vs Frequency
30
5
SUPPLY VOLTAGE(±V)
100
60
INPUT REFERRED
RS=0
RL=4
1 Vrms
INFINITE HEAT SINK
30
1℃/W HEAT SINK
25
5℃/W
HEAT SINK
15
10
5
50 100 200 500 1K 2K 5K10K 20K
FREQUENCY(Hz)
2℃/W
HEAT SINK
10℃/W HEAT SINK
20 40 60 80 100 120 140 160
TA - AMBIENT TEMPERATURE(℃)
INTERFACE=1℃/W
See Application Hints.
4
2016 JAN
LM1875
Power Disipation vs Power Output
50
40
35
30
Vs=+25V
25
Vs=+20V
15
10
Vs=+15V
RL=4Ω
fo=1kHz
5
RL=8Ω
fo=1kHz
45
POWER DISSIPATION(W)
45
10
15
POW ER OUTPUT(W )
40
35
30
Vs=+30V
25
Vs=+25V
Vs=+20V
10
Vs=+15V
5
5
15
30
Open Loop Gain and
Phase vs Frequency
IOUT vs VOUT-Current Limit/
Safe Operating Area Boundary
6
30
25
4
2
GAIN(dB)
OUTPUT CURRENT(A)
10
POW ER OUTPUT(W )
-4
15
135
10
90
5
45
-45
-10
-90
-135
-15
-6
-25 -20 -15 -10 -5
5
100k
10 15 20 25
OUTPUT VOLTAGE(V)
OHASE LAG(DEGREES)
50
Vs=+30V
1M
FREQUENCY(Hz)
-180
10M
Input Bias Current vs Supply Volage
300
INPUT BIAS CURRENT(nA)
T A=70℃
250
T A=
200
T A=0℃
25℃
150
100
* Thermal shutdown with infinite heat sink
**Thermal shutdown with 1℃/ W heat sink
10
15
SUPPLY VOLTAGE(+V)
30
5
2016 JAN
Vin
Cin
2.2μ
6
V- 3
2
Rin
22k
1
Q47
Q48
Q3
4p
C3
V+
Q7
5
R4
6.8k
Q4
R2
3.3k
Q1
R5
6.2k
Q9
R3
3.3k
Q8
Q5
R1
1.2k
R7
15k
R6
50k
4p
C1
Q6
Q29
R18
2.7k
Q2
Q10
Q11
R14
395
R9
4.9k
Z1
R13
1k
Q19
C2
4p
Q14
1
3
Q12
R12
450
R11
820
R10
3.6k
R8
1.7k
Q20
R15
3.3k
Q17
Q13
R17
910
Q40
Q15
R15
6k2
Q18
Q31
Z3
Z2
R23
20k
Q32
R24
80k
R27
450
R25
1.2k
Q30
R21
30
R26
40k
Q21
R19
5k
Q41
Q22
R20
370
R28
150
S
Q33
3x
3x
Q42
S
Q25
R29
3k
Q28
10X
R33
26
Q24
R22
30
1
R30
200
1
2
S
Q36
S
Q37
3x
3x 3x
Q26 Q46
S
Q27
10X
S
Q44
11
R40
40
R34
75
40X
Q38
R37
400
R31
75
S
Q34
40X
R39
510
Z7
Z6
R41
20k
R36
510
Z5
3X
R35B
R35A
R32B
R32A
3X
S
Q45
3X
Q43
3X
Z4
R38
20k
R35
0.25
S
Q39
500X
4
R32
0.25
S
Q35
500X
C1
22μ
R11
1k
R12
20k
Load
Rc
1
Cc
220n
Vout
LM1875
2016 JAN
很抱歉,暂时无法提供与“LM1875T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.48200
- 10+3.63960
- 50+3.21840
- 100+2.79720
- 500+2.54880
- 1000+2.41920
- 国内价格
- 1+2.58500
- 50+1.99100
- 1000+1.83700
- 国内价格
- 1+4.06700
- 10+3.30260
- 50+2.92040
- 100+2.53820
