IN-S42ATR
IN-S42ATR
    INOLUX(英诺斯)
    发光二极管/LED 红色 0402 631nm 90mcd 正贴
IN-S42ATR 数据手册
IN-S42AT series Top View SMD LED 0402 PCB Type Features • 0402 0.45mm SMD LED • High Brightness • AlInGaP / InGaN Technology • Small package • High reliability • Clear Lens Description The IN-S42AT series is a popular low profile 0402 package with versatile design capabilities. It is a PCB type molding style LED which can be used in various applications. Recommended Solder Pattern Applications • Consumer Electronics • Wearables • Automobile After Market • Industrial Equipment Figure 1. IN-S42AT Solder Pattern Package Dimensions in mm Figure 2. IN-S42AT Package Dimensions Inolux Corporation Proprietary & Confidential Page 1 April 25, 2017 www.inolux-corp.com IN-S42AT series Top View SMD LED 0402 PCB Type Absolute Maximum Rating at 25oC (Note 1) Product Emission Color Pd (mW) IF (mA) IFP* (mA) VR (V) TOP (oC) IN-S42ATYG Yellow Green 78 25 100 5 -30 C~+80 C IN-S42ATY Yellow 78 25 100 5 -30 C~+80 C IN-S42ATA Amber 78 25 100 5 -30 C~+80 C IN-S42ATR Red 78 25 100 5 -30 C~+80 C IN-S42ATB Blue 100 25 100 5 -30 C~+80 C IN-S42ATG Green 100 25 100 5 -30 C~+80 C IN-S42ATUW White 100 25 100 5 -30 C~+80 C TST (oC) o o -40 C~+85 C o o o o -40 C~+85 C o o o o -40 C~+85 C o o o o -40 C~+85 C o o o o -40 C~+85 C o o o o -40 C~+85 C o o o o -40 C~+85 C o o Notes 1. Condition for IFP is pulse of 1/10 duty and 0.1msec width ESD Precaution ATTENTION: Electrostatic Discharge (ESD) protection The symbol above denotes that ESD precaution is needed. ESD protection for GaP and AlGaAs based chips is necessary even though they are relatively safe in the presence of low static-electric discharge. Parts built with AlInGaP, GaN, or/and InGaN based chips are STATIC SENSITIVE devices. ESD precaution must be taken during design and assembly. If manual work or processing is needed, please ensure the device is adequately protected from ESD during the process. Please be advised that normal static precautions should be taken in the handling and assembly of this device to prevent damage or degradation which may be induced by electrostatic discharge (ESD). Inolux Corporation Proprietary & Confidential Page 2 April 25, 2017 www.inolux-corp.com IN-S42AT series Top View SMD LED 0402 PCB Type Electrical Characteristics T A = 25°C (Note 1) VF(V) Product Emission Color IN-S42ATYG Yellow Green λ(nm) IF(mA) Viewing Angle I*V(mcd) typ. max λD λP △λ 2θ1/2 typ. 20 1.9 2.6 572 575 - 130 28.5 IN-S42ATY Yellow 20 2.0 2.6 592 593 - 130 145 IN-S42ATA Amber 20 2.1 2.6 605 610 - 130 145 IN-S42ATR Red 20 2.1 2.6 631 645 - 130 90 IN-S42ATB Blue 20 3.1 4.0 470 468 - 120 100 IN-S42ATG Green 20 3.3 4.0 525 523 - 130 450 IN-S42ATUW White 20 3.1 4.0 X=0.295 Y=0.30 - - 130 600 Notes 1. Performance guaranteed only under conditions listed in above tables. Inolux Corporation Proprietary & Confidential Page 3 April 25, 2017 www.inolux-corp.com IN-S42AT series Top View SMD LED 0402 PCB Type Chromaticity Bin (for White only) BIN R27 R29 R31 CIE X Y X Y X Y Top 0.275 0.27 0.285 0.29 0.295 0.31 Inolux Corporation Proprietary & Confidential Right 0.285 0.28 0.295 0.3 0.305 0.32 Bottom 0.305 0.28 0.315 0.3 0.325 0.32 Left 0.295 0.27 0.305 0.29 0.315 0.31 BIN R28 R30 Page 4 CIE X Y X Y Top 0.28 0.28 0.29 0.3 Right 0.29 0.29 0.3 0.31 Bottom 0.31 0.29 0.32 0.31 Left 0.3 0.28 0.31 0.3 April 25, 2017 www.inolux-corp.com IN-S42AT series Top View SMD LED 0402 PCB Type Typical Characteristic Curves – YG, Y, A, R Inolux Corporation Proprietary & Confidential Page 5 April 25, 2017 www.inolux-corp.com IN-S42AT series Top View SMD LED 0402 PCB Type Typical Characteristic Curves – B, G, W Inolux Corporation Proprietary & Confidential Page 6 April 25, 2017 www.inolux-corp.com IN-S42AT series Top View SMD LED 0402 PCB Type Typical Characteristic Curves – Radiation Pattern Ordering Information Product Technolog Test Current Emission Color y IF (mA) Forward Luminous Intensity Voltage IV (mcd) VF (V) (Typ.) (Typ.) Orderable Part Number IN-S42ATYG Yellow Green AllnGaP 20 36 1.9 IN-S42ATYG IN-S42ATY Yellow AllnGaP 20 90 2.0 IN-S42ATY IN-S42ATA Amber AllnGaP 20 90 2.1 IN-S42ATA IN-S42ATR Red AllnGaP 20 90 2.1 IN-S42ATR IN-S42ATB Blue InGaN 20 100 3.1 IN-S42ATB IN-S42ATG Green InGaN 20 360 3.3 IN-S42ATG IN-S42ATUW White InGaN 20 600 3.1 IN-S42ATUW Inolux Corporation Proprietary & Confidential Page 7 April 25, 2017 www.inolux-corp.com IN-S42AT series Top View SMD LED 0402 PCB Type Label Specifications Inolux P/N: I N - S Material Inolux SMD 4 2 Package S = PCB Type A T Variation Orientation 42A = 1.0 x 0.5 x 0.45mm T = Top Mount X - Lens Color Customized Stamp-off (Blank) = 20mA 5=5mA (Blank) = Clear U = Diffused R=645m A=610nm Y=593nm YG=575nm G=523nm B=468nm W=White 7 01 24 001 Month Date Serial Current X X X X Lot No.: Z Internal Tracker Inolux Corporation Proprietary & Confidential 2 0 1 Year (2017, 2018, …..) Page 8 April 25, 2017 www.inolux-corp.com IN-S42AT series Top View SMD LED 0402 PCB Type Packaging Information: 5000pcs Per Reel Tape Dimension Reel Dimension Inolux Corporation Proprietary & Confidential Page 9 April 25, 2017 www.inolux-corp.com IN-S42AT series Top View SMD LED 0402 PCB Type Packing Dimension Inolux Corporation Proprietary & Confidential Page 10 April 25, 2017 www.inolux-corp.com IN-S42AT series Top View SMD LED 0402 PCB Type Dry Pack All SMD optical devices are MOISTURE SENSITIVE. Avoid exposure to moisture at all times during transportation or storage. Every reel is packaged in a moisture protected anti-static bag. Each bag is properly sealed prior to shipment. Upon request, a humidity indicator will be included in the moisture protected anti-static bag prior to shipment. The packaging sequence is as follows: Reflow Soldering • Recommended tin glue specifications: melting temperature in the range of 178~192 OC • The recommended reflow soldering profile is as follows (temperatures indicated are as measured on the surface of the LED resin): Lead-free Solder Profile Inolux Corporation Proprietary & Confidential Page 11 April 25, 2017 www.inolux-corp.com IN-S42AT series Top View SMD LED 0402 PCB Type Precautions • • • • • • Avoid exposure to moisture at all times during transportation or storage. Anti-Static precaution must be taken when handling GaN, InGaN, and AlInGaP products. It is suggested to connect the unit with a current limiting resistor of the proper size. Avoid applying a reverse voltage. Avoid operation beyond the limits as specified by the absolute maximum ratings. Avoid direct contact with the surface through which the LED emits light. If possible, assemble the unit in a clean room or dust-free environment. Reworking • • • Rework should be completed within 5 seconds under 260 OC. The iron tip must not come in contact with the copper foil. Twin-head type is preferred. Cleaning Following are cleaning procedures after soldering: • An alcohol-based solvent such as isopropyl alcohol (IPA) is recommended. • Temperature x Time should be 50oC x 30sec. or
IN-S42ATR 价格&库存
很抱歉,暂时无法提供与“IN-S42ATR”相匹配的价格&库存,您可以联系我们找货
IN-S42ATR
  • 1+2.024241+0.26315
  • 10+1.4095110+0.18324
  • 100+0.98325100+0.12782
  • 500+0.78835500+0.10249
  • 1000+0.723761000+0.09409
  • 2000+0.668702000+0.08693
库存:18472
IN-S42ATR
    IN-S42ATR
    • 1+1.75274
    • 10+1.19349
    • 100+0.84038
    • 500+0.66670
    • 1000+0.60681
    • 2000+0.55266
    • 2500+0.53733
    • 5000+0.49206
    • 10000+0.45169
    • 15000+0.43073
    库存:11242
    IN-S42ATR
      • 1+1.50412
      • 200+0.60016
      • 500+0.58007
      • 1000+0.57024
      IN-S42ATR
      • 50+1.37485
      • 1000+1.30470
      IN-S42ATR
      • 5000+0.608215000+0.07907
      • 10000+0.5703510000+0.07415
      • 15000+0.5509215000+0.07162
      • 25000+0.5289625000+0.06877
      • 35000+0.5158835000+0.06707
      • 50000+0.5031250000+0.06541
      库存:18472
