RMCF/RMCP Series
Stackpole Electronics, Inc.
General Purpose Thick Film Standard Power
and High-Power Chip Resistor
Features:
Resistive Product Solutions
RMCF – standard power ratings
RMCP – high power ratings
Nickel barrier terminations standard
Power derating from 100% at 70ºC to zero at +155ºC
AEC-Q200 Compliant (except RMCP0201)
RoHS compliant and halogen-free
Electrical Specifications - RMCF
Type / Code
Power Rating
(Watts) @ 70ºC
Maximum
Working
Voltage
(1)
Maximum
Overload
Voltage
Maximum
Current
(Amp)
RMCF01005
0.03W
15V
30V
0.5 A
RMCF0201
0.05W
25V
50V
0.5 A
RMCF0402
0.063W
50V
100V
1A
RMCF0603
0.1W
75V
150V
1A
RMCF0805
0.125W
150V
300V
2A
RMCF1206
0.25W
200V
400V
2A
RMCF1210
0.33W (3)
200V
400V
3A
RMCF2010
0.75W
200V
400V
3A
RMCF2512
1W
200V
400V
3A
Resistance
Temperature
Coefficient
Ohmic Range (Ω) and Tolerance (2)
-200/+600 ppm/ºC
± 250 ppm/ºC
± 400 ppm/ºC
± 200 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 500 ppm/ºC
± 400 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 200 ppm/ºC
± 400 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 400 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 400 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
1 - 9.76
10 - 1M
1 - 9.76
10 - 10M
1%
5%
1 - 9.76 (4)
10 - 1M
1.02M - 10M
1.1M - 20M
0.1 - 0.499
0.5 - 0.976
1 - 9.76
1 - 20M
10 - 1M
1.02M - 10M
0.1 - 9.76
0.1 - 20M
10 - 1M
1.02M - 10M
0.1 - 9.76
0.1 - 20M
10 - 1M
1.02M - 10M
0.1 - 0.976
1 - 9.76
10 - 20M
10 - 10M
0.1 - 0.976
1 - 9.76
10 - 10M
10 - 10M
0.1 - 0.976
1 - 9.76
10 - 10M
10 - 10M
Notes: (1) Lesser of √P*R or maximum working voltage
(2) Contact factory for extended ohmic values
(3) Power rating is 0.5W for ohmic values 1KΩ and below
(4) Contact factory for lower ohmic values
Rev Date: 01/07/2019
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
RMCF/RMCP Series
Electrical Specifications - RMCP
Type / Code
Power Rating
(Watts) @ 70ºC
Maximum
Working
(1)
Voltage
Maximum
Overload
Voltage
Maximum
Current
RMCP0201
0.063W
25V
50V
1 Amp
RMCP0402
0.125W
50V
100V
1.5 Amp
RMCP0603
0.25W
75V
150V
2 Amp
RMCP0805
0.33W
150V
300V
2.5 Amp
RMCP1206
0.33W
200V
400V
3.5 Amp
RMCP1210
0.5W
200V
400V
5 Amp
RMCP2010
1W
200V
400V
6 Amp
RMCP2512
2W
250V
500V
7 Amp
Resistance
Temperature
Coefficient
1%, 5%
1 - 9.76
10 - 1M
1 - 9.76
10 - 1M
1 - 9.76
10 - 1M
1 - 9.76
10 - 1M
1 - 9.76
10 - 1M
1 - 9.76
10 - 1M
1 - 9.76
10 - 1M
1 - 9.76
10 - 1M
-200/+400 ppm/ºC
± 200 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
± 100 ppm/ºC
Mechanical Specifications
Type / Code
Average Unit
Weight (mg)
RMCF01005
0.07
RMCF0201
RMCP0201
RMCF0402
RMCP0402
RMCF0603
RMCP0603
RMCF0805
RMCP0805
RMCF1206
RMCP1206
RMCF1210
RMCP1210
RMCF2010
RMCP2010
RMCF2512
RMCP2512
0.16
0.57
0.62
1.88
2.04
5.00
4.37
8.86
8.95
15.55
15.96
23.56
24.24
40.02
39.45
L
Body Length
0.016 ± 0.0008
0.40 ± 0.02
0.024 ± 0.0012
0.60 ± 0.03
0.039 ± 0.004
1.00 ± 0.10
0.061 ± 0.006
1.55 ± 0.15
0.079 ± 0.008
2.00 ± 0.20
0.126 ± 0.010
3.20 ± 0.25
0.126 ± 0.010
3.20 ± 0.25
0.197 ± 0.008
5.00 ± 0.20
0.248 ± 0.008
6.30 ± 0.20
W
Body Width
0.008 ± 0.0008
0.20 ± 0.02
0.012 ± 0.0012
0.30 ± 0.03
0.020 ± 0.002
0.50 ± 0.05
0.031 ± 0.006
0.80 ± 0.15
0.049 ± 0.004
1.25 ± 0.10
0.063 ± 0.006
1.60 ± 0.15
0.098 ± 0.010
2.50 ± 0.25
0.098 ± 0.008
2.50 ± 0.20
0.126 ± 0.010
3.20 ± 0.25
2
H
Body Height
0.005 ± 0.0008
0.13 ± 0.02
0.009 ± 0.0012
0.23 ± 0.03
0.012 ± 0.002
0.30 ± 0.05
0.018 ± 0.004
0.45 ± 0.10
0.020 ± 0.006
0.50 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
0.022 ± 0.006
0.55 ± 0.15
a
Top Termination
0.004 ± 0.0012
0.10 ± 0.03
0.006 ± 0.002
0.15 ± 0.05
0.008 ± 0.004
0.20 ± 0.10
0.012 ± 0.008
0.30 ± 0.20
0.014 ± 0.010
0.35 ± 0.25
0.020 ± 0.012
0.50 ± 0.30
0.020 ± 0.012
0.50 ± 0.30
0.024 ± 0.012
0.60 ± 0.30
0.024 ± 0.012
0.60 ± 0.30
b
Bottom Termination
0.004 ± 0.0012
0.10 ± 0.03
0.006 ± 0.002
0.15 ± 0.05
0.010 ± 0.006
0.25 ± 0.15
0.012 ± 0.008
0.30 ± 0.20
0.014 ± 0.010
0.35 ± 0.25
0.020 ± 0.012
0.50 ± 0.30
0.020 ± 0.012
0.50 ± 0.30
0.024 ± 0.014
0.60 ± 0.35
0.024 ± 0.014
0.60 ± 0.35
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
RMCF/RMCP Series
Performance Characteristics
Test
Test Specifications
Test Conditions (JIS-C 5202)
Short Time Overload
±(2%+0.1Ω)
2.5x rated voltage for 5 seconds
Dielectric Withstanding Voltage
No flashover or breakdown
100 VAC, 1 minute
Resistance to Soldering Heat
±1%
260ºC±5ºC, for 10 seconds ±0.5 seconds (Solder Bath)
Solderability
95% coverage, minimum
235ºC±5ºC, for 2 seconds ±0.5 seconds (Colophonium flux)
Temperature Cycle
±(1%+0.05Ω)
Jumper (
很抱歉,暂时无法提供与“RMCF1206FT27R0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.17139
- 200+0.15965
- 500+0.14791
- 1000+0.13617
- 3000+0.13031
- 6000+0.12209
- 国内价格 香港价格
- 1+0.887231+0.11476
- 10+0.2736510+0.03540
- 25+0.2052425+0.02655
- 50+0.1644150+0.02127
- 100+0.13437100+0.01738
- 250+0.10536250+0.01363
- 500+0.08858500+0.01146
- 1000+0.075491000+0.00977
- 国内价格 香港价格
- 5000+0.054835000+0.00710
- 10000+0.0488710000+0.00632
- 15000+0.0459715000+0.00595
- 25000+0.0428425000+0.00554
- 35000+0.0410435000+0.00531
- 50000+0.0393550000+0.00509
