DATA SHEET
THIN FILM CHIP RESISTORS
High precision - high stability
RT series
0.01% TO 1%, TCR 5 TO 50
sizes 0201/0402/0603/0805/1206/
1210/2010/2512
Product specification – September 12, 2017 V.9
RoHS compliant
Chip Resistor Surface Mount
RT
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC
This specification describes RT
series high precision - high stability
chip resistors with lead-free
terminations made by thin film
process.
Both part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED )
APPLICATIONS
Converters
Printing equipment
Server board
Telecom
Consumer
FEATURES
Halogen Free Epoxy
RoHS compliant
Reducing environmentally
hazardous wastes
High component and
equipment reliability
2
9
0201 to 2512 (RoHS Compliant)
SERIES
RT XXXX F X X XX XXXX L
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0201/ 0402 / 0603 / 0805 / 1206 / 1210 / 2010 / 2512
(2) TOLERANCE
L = ± 0.01%
P = ± 0.02%
W = ± 0.05%
B = ± 0.1%
C = ± 0.25%
D = ± 0.5%
F = ± 1%
(3) PACKAGING TYPE
R = Paper/PE taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
Saving of PCB space
A = 5 ppm/°C
None forbidden-materials used
in products/production
B = 10 ppm/°C
C = 15 ppm/°C
D = 25 ppm/°C
E = 50 ppm/°C
(5) TAPING REEL
07 = 7 inch dia. Reel
10 = 10 inch dia. Reel
13 = 13 inch dia. Reel
(6) RESISTANCE VALUE
There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point.
Detailed resistance rules show in table of “Resistance rule of global part number”.
(7) DEFAULT CODE
Letter L is system default code for order only (Note)
number
Resistance code rule
Example
XRXX
(1 to 9.76 Ω)
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XMXX
(1 to 9.76 MΩ)
1M = 1,000,000 Ω
9M76= 9,760,000 Ω
O RDERING EXAMPLE
The ordering code of a RT0603
chip resistor, TC 50 value 56 Ω
with ± 0.5% tolerance, supplied in
7-inch tape reel is:
RT0603DRE0756RL.
NOTE
1. All our RSMD products meet RoHS
compliant and Halogen Free. "LFP" of
the internal 2D reel label mentions
"Lead Free Process"
2. On customized label, "LFP" or
specific symbol can be printed
www.yageo.com
Sep. 12, 2017 V.9
RT
SERIES
3
9
PHYCOMP BRAND ordering codes
Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp
brand products. For matching traditional types with size codes, please refer to “Comparison table of traditional
types and sizes”.
For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2.
12NC CODE
2390
X
XX
(1)
(2)
(3)
X
(4)
START TCR (2) PACKING CODE TOL . (4)
WITH (1) (ppm/°C) BY SIZE (inch) (3) (%)
2390
XXXX
(5)
RESISTANCE
RANGE
The remaining 4 digits
7 = ± 15
47 = 13'' reel 6 = ± 0.5 represent the resistance
value with the last digit
6 = ± 25 0603: 04 = 7'' reel 5 = ± 0.25 indicating the multiplier
4 = ± 50
24 = 10'' reel 4 = ± 0.1 as shown in the table of
44 = 13'' reel 3 = ± 0.05 “Last digit of 12NC”.
8 = ± 10 0402: 07 = 7'' reel
7 = ±1
0805: 01 = 7'' reel
41 = 13'' reel
1206: 11 = 7'' reel
51 = 13'' reel
1210: 12 = 7'' reel
52 = 13'' reel
2010: 15 = 7'' reel
L
(6)
DEFAULT
CODE
(NOTE)
Letter L is
system
default
code for
order only
(Note)
types and sizes
TF
X
X
X
(1)
(2)
START SIZE
WITH CODE
TF
(4)
(3)
TCR
TOL.
(ppm/°C) (%)
3 = 0402 4 = ± 10 0 = ± 1
2 = 0603 3 = ± 15 1 = ± 0.5
1 = 0805 1 = ± 25 2 = ± 0.25
0402: 4.7Ω ≤ R ≤ 240KΩ
0 = 1206 2 = ± 50 3 = ± 0.1
0603: 1 Ω ≤ R ≤ 1MΩ
5 = 1210
0805: 1Ω ≤ R ≤ 1.5 MΩ
7 = 2010
1206: 1Ω ≤ R ≤ 1.5 MΩ
4 = ± 0.05
6 = 2512
1210: 4.7Ω ≤ R ≤ 1 MΩ
Example:
2010: 4.7Ω ≤ R ≤ 1 MΩ
TF321 = RT0402, TC50, ± 0.5% tolerance
2512: 4.7Ω ≤ R ≤ 1 MΩ
2512: 18 = 7'' reel
Resistance decade (3)
Last digit
1 to 9.76 Ω
10 to 97.6 Ω
8
100 to 976 Ω
1
1 to 9.76 kΩ
2
Exceptions to above packing code definitions:
10 to 97.6 kΩ
3
0805 TC50 with 1%, supplied in 13" reel, the packing code is 02.
100 to 976 kΩ
4
0603 TC50 with 1%, supplied in 13" reel, the packing code is 03.
1 to 9.76 MΩ
5
2512 TC15, in 7" reel, the packing code is 35.
10 to 97.6 MΩ
6
2010 TC15, in 7" reel, the packing code is 31.
O RDERING EXAMPLE
The ordering code of a TF221 resistor, TC50, value 56 Ω with ± 0.5%
tolerance, supplied in tape of 5,000 units per reel is: 239040465609L or
RT0603DRE0756RL.
Example:
1Ω
33 kΩ
10 MΩ
9
1008 or 108
3303 or 333
1006 or 106
NOTE
1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process"
2. On customized label, "LFP" or specific symbol can be printed
www.yageo.com
Sep. 12, 2017 V.9
RT
4
9
SERIES
MARKING
RT0201 / RT0402 / RESISTANCE VALUE IS NOT IN E-24 / E96 SERIES
No marking
Fig. 4
RT0603
563
E-24 series: exception values 10/11/13/15/20/75 of E -24 series, one short bar
under marking letter
Fig. 2 Value = 56 kΩ
E-96 series: including values 10/11/13/15/20/75 of E-24 series, 3 digits
Fig. 3 Value = 12.4 kΩ
RT0805 / RT1206 / RT1210 / RT2010 / RT2512
00
Fig. 1 Value = 10 kΩ
Either resistance in E-24 or E-96: 4 digits
First three digits for significant figure and 4th digit for number of zeros
For further marking information, please see special data sheet “Chip resistors marking”.
CONSTRUCTION
The resistors are constructed out of a high-grade ceramic
body. Internal metal electrodes are added at each end and
connected by a resistive layer. The resistive layer is adjusted
to give the approximate required resistance and laser cutting
of this resistive layer that achieves tolerance trims the value.
The resistive layer is covered with a protective coat and
printed with the resistance value. Finally, the two external
terminations (matte tin) are added. See fig. 5.
OUTLINES
For dimension see Table 1
DIMENSION
Table 1 For outlines see fig. 5
TYPE
L (mm) W (mm) H (mm)
RT0201 0.60 ± 0.03 0.30 ± 0.03 0.23 ± 0.03
RT0402 1.00 ± 0.10 0.50 ± 0.05 0.30 ± 0.05
RT0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10
RT0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10
RT1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10
RT1210 3.10 ± 0.10 2.60 ± 0.15 0.55 ± 0.10
RT2010 5.00 ± 0.10 2.50 ± 0.15 0.55 ± 0.10
RT2512 6.35 ± 0.10 3.20 ± 0.15 0.55 ± 0.10
I1 (mm)
I2 (mm)
0.10 ± 0.05 0.15 ± 0.05
0.20 ± 0.10 0.25 ± 0.10
0.25 ± 0.15 0.25 ± 0.15
0.35 ± 0.20 0.35 ± 0.20
0.45 ± 0.20 0.40 ± 0.20
0.50 ± 0.20 0.50 ± 0.20
Fig. 5 Chip resistor outlines
0.60 ± 0.20 0.50 ± 0.20
www.yageo.com
Sep. 12, 2017 V.9
RT
5
9
SERIES
ELECTRICAL CHARACTERISTICS
Table 2
TYPE
RT0201
Operating
Temperature
Range
–55°C
to
+125°C
Max.
Max.
Dielectric
Power Work
T.C.R.
Overload Withstand
Rating
(ppm/°C)
Vol.
Vol.
Vol. (1)
1/20W 25V
50V
50V
± 0.01%
± 0.02%
± 0.05%
± 0.1%
± 50
22 ~75K
22 ~75K 22 ~75K 22 ~75K
± 25
22~75K
22~75K
22~75K
22~75K
± 15
± 10
±5
RT0402
1/16W 50V
100V
75V
RT0603
1/10W 75V
150V
100V
RT0805
1/8W
150V
300V
200V
RT1206
1/4W
200V
400V
300V
–55°C
to
+155°C
RT1210
RT2010
1/4W
–55°C
to
+125°C
RT2512
1/2W
3/4W
200V
200V
200V
400V
400V
400V
400V
400V
400V
Resistance Range (E-24/E-96 series)(2) & Tolerance
± 0.25%
± 0.5%
± 1.0%
± 50
± 25
± 15
± 10
±5
± 50
± 25
± 15
± 10
±5
± 50
± 25
± 15
± 10
±5
± 50
± 25
± 15
± 10
±5
50.1~12K
50.1~12K
20~12K
20~12K
20~10K
50.1~30K
50.1~30K
50.1~100K
50.1~100K
20~30K
50.1~30K
50.1~30K
50.1~200K
50.1~200K
20~50K
50.1~30K
50.1~30K
50.1~500K
50.1~500K
20~100K
50.1~12K
50.1~12K
20~12K
20~12K
20~10K
50.1~30K
50.1~30K
50.1~100K
50.1~100K
20~30K
50.1~30K
50.1~30K
50.1~200K
50.1~200K
20~50K
50.1~30K
50.1~30K
50.1~500K
50.1~500K
20~100K
20~12K
20~12K
20~12K
20~12K
20~10K
4.7~100K
4.7~100K
4.7~100K
4.7~100K
20~30K
4.7~200K
4.7~200K
4.7~200K
4.7~200K
20~50K
5.6~500K
5.6~500K
5.6~500K
5.6~500K
20~100K
4.7~240K
4.7~240K
20~70K
20~70K
20~10K
1~1M
1~1M
4.7~332K
4.7~332K
20~30K
1~1.5M
1~1.5M
4.7~800K
4.7~800K
20~50K
1~1.5M
1~1.5M
5.6~1M
5.6~1M
20~100K
± 50
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 25
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 15
100~100k
4.7~100k
4.7~100k
± 10
100~100k
4.7~100k
4.7~100k
±5
± 50
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 25
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 15
100~100k
4.7~100k
4.7~100k
± 10
100~100k
4.7~100k
4.7~100k
±5
± 50
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 25
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 15
100~100k
4.7~100k
4.7~100k
± 10
100~100k
4.7~100k
4.7~100k
±5
4.7~240K 4.7~240K 4.7~240K
20~70K
----20~70K
----20~10K
----1~1M
1~1M
1~1M
1~1M
1~1M
1~1M
4.7~332K
----4.7~332K
----20~30K
----1~1.5M 1~1.5M 1~1.5M
4.7~800K
----4.7~800K
----20~50K
5.6~1M
----5.6~1M
----20~100K
NOTE
1. The maximum working voltage that may be continuously applied to the resistor element, see “IEC publication 60115-8”
2. Value of E-192 series is on request
www.yageo.com
Sep. 12, 2017 V.9
RT
SERIES
6
9
FOOTPRINT AND SOLDERING PROFILES
For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
REEL RT0201
DIMENSION
Paper/PE taping reel (R)
RT0402
RT0603
RT0805
RT1206
RT1210
RT2010
RT2512
7" (178 mm)
10,000
10,000
5,000
5,000
5,000
5,000
10" (254 mm)
20,000
20,000
10,000
10,000
10,000
10,000
13" (330 mm)
50,000
50,000
20,000
20,000
20,000
20,000
7" (178 mm)
4,000
4,000
Embossed taping reel (K)
NOTE
1. For Paper/Embossed tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”
FUNCTIONAL DESCRIPTION
POWER RATING
Each type rated power at 70°C:
RT0201=1/20W, RT0402=1/16W, RT0603=1/10W,
RT0805=1/8W, RT1206=1/4W, RT1210=1/4W,
RT2010=1/2W, RT2512=3/4W.
R ATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V= (PxR)
or max. working voltage whichever is less
Where
Fig. 6 Maximum dissipation (P) in percentage of rated power as a
function of the operating ambient temperature (T amb )
V=Continuous rated DC or
AC (rms) working voltage (V)
P=Rated power (W)
R=Resistance value (Ω)
www.yageo.com
Sep. 12, 2017 V.9
RT
SERIES
7
9
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Temperature
Coefficient of
Resistance
(T.C.R.)
MIL-STD-202 Method 304
At +25/–55 °C and +25/+125 °C
Refer to table 2
Formula:
R2–R1
T.C.R= ------------------------- × 106 (ppm/°C)
R1(t2–t1)
Where
t1=+25 °C or specified room temperature
t2=–55 °C or +125 °C test temperature
R1=resistance at reference temperature in ohms
R2=resistance at test temperature in ohms
Life/Endurance
IEC 60115-1 4.25.1
MIL-STD-202 Method 108A
At 70± 5 °C for 1,000 hours, RCWV applied for
1.5 hours on, 0.5 hour off, still air required
± (0.5%+0.05 Ω)
High
Temperature
Exposure
IEC 60068-2-2
1000 hours at maximum operating temperature
depending on specification, unpowered
± (0.5%+0.05 Ω)
Moisture
Resistance
MIL-STD-202 Method 106G
Each temperature / humidity cycle is defined at 8
hours, 3 cycles / 24 hours for 10d. with 25 °C /
65 °C 95% R.H, without steps 7a & 7b,
unpowered
± (0.5%+0.05 Ω)
Parts mounted on test-boards, without
condensation on parts
Measurement at 24± 2 hours after
test conclusion
Thermal Shock
MIL-STD-202 Method 107G
-55/+125 °C
Number of cycles required is 300.
Devices mounted
± (0.5%+0.05 Ω) for 10 KΩ to
10 MΩ
± (0.5%+0.05 Ω) for others
Maximum transfer time is 20 seconds.
Dwell time is 15 minutes. Air – Air
Humidity
(steady state)
IEC 60115-1 4.24.2
Steady state for 1000 hours at 40 °C / 95% R.H.
± (0.5%+0.05 Ω)
RCWV applied for 1.5 hours on and
0.5 hour off
www.yageo.com
Sep. 12, 2017 V.9
RT
8
9
SERIES
TEST
Short Time Overload
TEST METHOD
PROCEDURE
REQUIREMENTS
IEC60115-1 4.13
2.5 times of rated voltage or maximum
± (0.5%+0.05 Ω)
overload voltage whichever is less for 5 sec at No visible damage
room temperature
Board Flex/
Bending
IEC 60115-1 4.33
Chips mounted on a 90mm glass epoxy resin ± (0.25%+0.05 Ω)
PCB (FR4)
No visible damage
Bending: see table 6 for each size
Bending time: 60± 5 seconds
Insulation Resistance
IEC 60115-1 4.6
≥10 GΩ
Rated continuous overload voltage (RCOV)
for 1 minute
Details see below table 5
Dielectric Withstand
Voltage
Solderability
- Wetting
IEC 60115-1 4.7
J-STD-002 test B
Maximum voltage (Vrms) applied for 1 minute
No breakdown or flashover
Electrical Test not required
Well tinned (≥95%
covered)
No visible damage
Magnification 50X
SMD conditions:
1st step: method B, aging 4 hours at 155°C
dry heat
2nd step: leadfree solder bath at 245± 3°C
Dipping time: 3± 0.5 seconds
- Leaching
- Resistance to
Soldering Heat
J-STD-002 test D
Leadfree solder, 260 °C, 30 seconds
immersion time
No visible damage
IEC 60115-1 4.18
Condition B, no pre-heat of samples.
Leadfree solder, 260 °C, 10 seconds
immersion time
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
± (0.5%+0.05 Ω)
No visible damage
Table 5 Criteria of rated continued working voltage and overload voltage
TYPE
RT0201
RT0402
RT0603
RT0805
RT1206
RT1210
RT2010
RT2512
50
100
100
300
500
500
500
500
Voltage (DC/unit: V); (AC/ unit: Vrms)
Table 6 Bending for sizes 0201 to 2512
TYPE
Specification (mm)
RT0201
RT0402
RT0603
RT0805
RT1206
RT1210
RT2010
RT2512
5
5
3
3
2
2
2
2
www.yageo.com
Sep. 12, 2017 V.9
RT
SERIES
9
9
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 9
Sep. 12, 2017 -
- Add ± 0.02% tol. for 0402 to 1206
Version 8
May 31, 2017 -
- Add 10" packing
Version 7
Jan. 17, 2017
Version 6
May. 11, 2015 -
- Extend resistor value
Version 5
Aug. 22, 2014 -
- Add RT0201
- Add ± 0.01% tol. for 0402 to 1206
- RT0402/0603/0805/1206: resistance range and operating temperature
range updated
- Fig. 6 updated
Version 4
Oct 21, 2009 -
- Test Items and methods updated
- Test requirements upgraded
Version 3
Jul 11, 2008
- Change to dual brand datasheet that describe RT0402 to RT2512 with
RoHS compliant
- Description of "Halogen Free Epoxy" added
- Define global part number
- Modify electrical characteristic
Version 2
Dec 26, 2005 -
- New datasheet for thin film high precision - high stability chip resistors
sizes of 0201/0402/0603/0805/1206/1210/2010/2512, 1%, 0.5%, 0.25%,
0.1%, 0.05%, TC25/50 with lead-free terminations
- Replace the 0402 to 1210 parts of pdf files: TFx10_1_1, TFx11_.5_2,
TFx12_.25_2, TFx13_.1_3, TFx14_.05_1, TFx20_1_2, TFx21_.5_2,
TFx22_.25_2, TFx23_.1_2, TFx24_.05_1, and combine into a document.
- Test method and procedure updated
- PE tape added (paper tape will be replaced by PE tape)
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any
product change will be announced by PCN.”
www.yageo.com
Sep. 12, 2017 V.9
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Vitrohm:
RT0603BRD07820KL
Yageo:
RT0805FRE1033KL RT0805FRE1047KL RT0805FRE104K7L RT0805FRE101K3L RT0805FRE101K5L
RT0805FRE101K8L RT0805FRE101KL RT0805FRE101ML RT0805FRE10200KL RT0603FRE10150RL
RT0603FRE101K2L RT0603FRE101K5L RT0603FRE101KL RT0805FRE1016KL RT0805FRE1018KL
RT0603FRE10100KL RT0603FRE10100RL RT0603FRE1010RL RT0603FRE1011RL RT0603FRE1013KL
RT0603FRE10150KL RT0603DRE1047KL RT0603DRE104K7L RT0603DRE1312KL RT0603DRE13240RL
RT0603DRE1324KL RT0603DRE133K3L RT0603DRE1010KL RT0603DRE101K5L RT0603DRE101K8L
RT0603DRE1020KL RT0603DRE102K2L RT0603DRE102KL RT1206BRD0779K6L RT0402BRD0721K8L
RT0603FRE135K62L RT0201BRD074K99L RT0603FRE1322K1L RT0805BRD13422KL RT0402BRE073K83L
RT0402BRE07158KL RT0201BRD0710KL RT0603BRC07500RL RT2010BKD0710KL RT0603DRD071ML
RT0603DRD0728K4L RT0402FRE07220KL RT0603DRD07316RL RT0201BRE0718K2L RT0402DRE0718K4L
RT0402BRE07162RL RT0603BRE075K83L RT0201BRD076K81L RT0402CRB0743KL RT0201BRE074K02L
RT0603FRE072R49L RT0201BRE072K8L RT0201BRE073K01L RT0201BRE073K32L RT1206FRD074R99L
RT2512FKD0715KL RT0201BRD072KL RT0603FRE07750KL RT0603DRD0792KL RT1210BRD07250RL
RT0603FRE07910KL RT0603FRE133K92L RT0603BRE0711K7L RT0603FRE1333K2L RT1206BRD071M11L
RT1206FRE073R9L RT0805FRE134K75L RT0805BRB1310RL RT0402FRD071KL RT0603BRE07806KL
RT0603DRD07741RL RT1206FRE1357K6L RT1210FRE0754RL RT0805FRE13511RL RT1206FRD07475KL
RT1206DRE076K9L RT0805FRE071R2L RT0805WRB0720KL RT0603FRE135K11L RT1206BRD07249KL
RT1206BRD07330KL RT2512CKB07121RL RT0603BRD0710KL RT0603BRD0712K4L RT0603BRD072K67L
RT0603BRD0749R9L RT0603FRE0710K2L RT0603FRE071K78L RT0603FRE072K7L RT0603FRE0733KL
RT0603FRE07348RL RT0603FRE075K49L RT0603FRE076K2L RT0805BRD0722K6L RT0805BRD0724K9L
