RS1M-SMA
RS1M-SMA
    TK(通科)
    SMA(DO-214AC)
    1.0A快速表面恢复二极管
RS1M-SMA 数据手册
DongGuan Tongke Electronic Co.,LTD RS1A – RS1M 1.0A SURFACE MOUNT FAST RECOVERY DIODE Features ! ! ! ! ! ! Ideally Suited for Automatic Assembly B Low Forward Voltage Drop, High Efficiency Surge Overload Rating to 30A Peak Low Power Loss A Ultra-Fast Recovery Time F Plastic Case Material has UL Flammability Classification Rating 94V-O C H G E SMA/DO-214AC Dim Min Max 2.90 2.50 A 4.00 4.60 B 1.60 1.20 C 0.152 0.305 D 4.80 5.28 E 2.00 2.44 F 0.051 0.203 G 0.76 1.52 H All Dimensions in mm Mechanical Data ! ! ! ! ! ! Case: SMA/DO-214AC, Molded Plastic Terminals: Solder Plated, Solderable per MIL-STD-750, Method 2026 Polarity: Cathode Band or Cathode Notch Marking: Type Number Weight: 0.064 grams (approx.) Lead Free: For RoHS / Lead Free Version, Maximum Ratings and Electrical Characteristics Characteristic Symbol Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Average Rectified Output Current @TA=25°C unless otherwise specified RS1A RS1B RS1D RS1G RS1J RS1K RS1M Unit VRRM VRWM VR 50 100 200 400 600 800 1000 V VR(RMS) 35 70 140 280 420 560 700 V IO 1.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 30 A Forward Voltage @IF = 1.0A VFM 1.3 V @TA = 25°C @TA = 100°C IRM 10 500 µA Peak Reverse Current At Rated DC Blocking Voltage @TL = 100°C D 150 250 500 nS Reverse Recovery Time (Note 1) trr Typical Junction Capacitance (Note 2) Cj 15 pF RJL 30 °C/W Tj, TSTG -65 to +150 °C Typical Thermal Resistance (Note 3) Operating and Storage Temperature Range Note: 1. Measured with IF = 0.5A, IR = 1.0A, Irr = 0.25A. See figure 5. 2. Measured at 1.0 MHz and applied reverse voltage of 4.0 V DC. 3. Mounted on P.C. Board with 8.0mm2 land area. RS1A – RS1M 1 of 2 www.tongke888.com 400-6922-883 DongGuan Tongke Electronic Co.,LTD RS1A – RS1M IF, INSTANTANEOUS FORWARD CURRENT (A) IO, AVERAGE RECTIFIED CURRENT (A) 1.2 1.0 0.8 0.6 0.4 0.2 10 1.0 0.1 Tj = 25°C IF Pulse Width: 300µs 0.01 0 25 50 75 100 125 150 0 175 30 Single Half-Sine-Wave (JEDEC Method) Tj = 150°C 20 10 0 1 0.8 1.2 1.6 VF, INSTANTANEOUS FORWARD VOLTAGE (V) Fig. 2 Typical Forward Characteristics IR, INSTANTANEOUS REVERSE CURRENT (µA) IFSM, PEAK FORWARD SURGE CURRENT (A) TT, TERMINAL TEMPERATURE (°C) Fig. 1 Forward Current Derating Curve 0.4 1000 Tj = 125°C 100 10 Tj = 25°C 1.0 0.1 0 10 100 NUMBER OF CYCLES AT 60Hz Fig. 3 Forward Surge Current Derating Curve 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig. 4 Typical Reverse Characteristics trr +0.5A 50Ω NI (Non-inductive) 10Ω NI Device Under Test (-) 0A (+) Pulse Generator (Note 2) 50V DC Approx (-) 1.0Ω NI Oscilloscope (Note 1) -0.25A (+) Notes: 1. Rise Time = 7.0ns max. Input Impedance = 1.0MΩ, 22pF. 2. Rise Time = 10ns max. Input Impedance = 50Ω. -1.0A Set time base for 50/100 ns/cm Fig. 5 Reverse Recovery Time Characteristic and Test Circuit RS1A – RS1M 2 of 2 www.tongke888.com 400-6922-883
RS1M-SMA 价格&库存
很抱歉,暂时无法提供与“RS1M-SMA”相匹配的价格&库存,您可以联系我们找货
