XL4001
XL4001
    XLSEMI(芯龙)
    ESOP-8
    150KHz 40V 2A开关电流自带恒流环路降压型DC-DC转换器
XL4001 数据手册
Datasheet 2A 150kHz 40V Buck DC/DC Converter With Constant Current Loop XL4001 Features General Description „ „ Wide 4.5V to 40V Input Voltage Range Output Adjustable from 1.235V to 37V „ Minimum Drop Out 1.5V „ „ „ Fixed 150kHz Switching Frequency 2A Constant Output Current Capability Internal Optimize Power Transistor „ „ „ „ Excellent line and load regulation TTL shutdown capability ON/OFF pin with hysteresis function With output constant current loop The XL4001 is a 150KHz fixed frequency PWM buck (step-down) DC/DC converter, capable of driving a 2A load with high efficiency, low ripple and excellent line and load regulation. Requiring a minimum number of external components, the regulator is simple to use and include internal frequency compensation and a fixed-frequency oscillator. „ Built in thermal shutdown function Built in current limit function Built in output over voltage protection SOP8-EP (Exposed PAD) package „ „ „ The PWM control circuit is able to adjust the duty ratio linearly from 0 to 100%. An enable function, an over current protection function is built inside. An internal compensation block is built in to minimize external component count. Applications „ „ „ Car Charger Battery Charger LED Constant Current Driver Figure1. Package Type of XL4001 Rev 1.2 www.xlsemi.com 1 Datasheet 2A 150kHz 40V Buck DC/DC Converter With Constant Current Loop XL4001 Pin Configurations SW 1 8 VIN SW 2 7 VIN GND 3 6 EN FB 4 5 CS XL4001 Figure2. Pin Configuration of XL4001 (Top View) Table 1 Pin Description Pin Number Pin Name 1,2 SW 3 GND 4 FB 5 CS 6 EN 7,8 VIN Description Power Switch Output Pin (SW). Output is the switch node that supplies power to the output. Ground Pin.(Note: Connected the back exposed PAD to Pin3.) Feedback Pin (FB). Through an external resistor divider network, Feedback senses the output voltage and regulates it. The feedback threshold voltage is 1.235V. Output Current Sense Pin; (Iload=0.155V/Rcs) Enable Pin. Drive EN pin low to turn on the device, drive it high to turn it off. Floating is default low. Supply Voltage Input Pin. XL4001 operates from a 4.5V to 40V DC voltage. Bypass Vin to GND with a suitably large capacitor to eliminate noise on the input. Rev 1.2 www.xlsemi.com 2 Datasheet 2A 150kHz 40V Buck DC/DC Converter With Constant Current Loop XL4001 Function Block Figure3. Function Block Diagram of XL4001 Typical Application Circuit (Car Charger) Figure4. XL4001 Typical Application Circuit (Li Battery Charger) Rev 1.2 www.xlsemi.com 3 Datasheet 2A 150kHz 40V Buck DC/DC Converter With Constant Current Loop XL4001 Typical Application Circuit (Buck LED Constant Current Driver) L 33uh EN FB VIN +6V~36V CIN 100uf/50V 4 6 7,8 XL4001 1,2 SW 3 5 GND CS VOUT C1 105 LED 1W~5W R2 D1 1N5821 COUT 100uf/35V R1 1K Rcs Figure5. XL4001 Typical Application Circuit (LED Constant Current Driver) Ordering Information Order Information XL4001E1 Marking ID XL4001E1 Package Type SOP8-EP Packing Type Supplied As 2500 Units on Tape & Reel XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant. Absolute Maximum Ratings(Note1) Parameter Symbol Value -0.3 to 45 -0.3 to Vin -0.3 to Vin -0.3 to Vin Internally limited Unit V V V V mW Input Voltage Vin FB Pin Voltage VFB EN Pin Voltage VEN SW Pin Voltage VSW Power Dissipation PD Thermal Resistance 60 ºC/W RJA (Junction to Ambient, No Heatsink, Free Air) Operating Junction Temperature -40 to 125 ºC TJ Storage Temperature -65 to 150 ºC TSTG Lead Temperature (Soldering, 10 sec) 260 ºC TLEAD ESD (HBM) 2000 V Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operation is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Rev 1.2 www.xlsemi.com 4 Datasheet 2A 150kHz 40V Buck DC/DC Converter With Constant Current Loop XL4001 XL4001 Electrical Characteristics Ta = 25℃;unless otherwise specified. Symbol Parameter Test Condition Min. Typ. Max. Unit 1.21 1.235 1.26 V - 83 - % System parameters test circuit figure4 Feedback Voltage VFB ŋ Efficiency Vin = 8V to 32V, Vout=5V Iload=0.2A to 2A Vin=12V ,Vout=5V Iout=2A Electrical Characteristics (DC Parameters) Vin = 12V, GND=0V, Vin & GND parallel connect a 220uf/50V capacitor; Iout=500mA, Ta = 25℃; the others floating unless otherwise specified. Parameters Symbol Test Condition Min. Typ. 4.5 Max. Unit 40 V Input operation voltage Vin Shutdown Supply Current ISTBY VEN=5V 80 200 uA Quiescent Supply Current Iq VEN =0V, VFB =Vin 2 5 mA 150 172 Khz Oscillator Frequency Fosc Switch Current Limit IL VFB =0 3 A EN Pin Threshold VEN High (Regulator OFF) Low (Regulator ON) 1.4 0.8 V Output Saturation Voltage VCE VFB=0V ISW=2A 1.1 Constant Voltage VCS current sense 127 1.4 0.140 0.155 0.170 Rev 1.2 V V www.xlsemi.com 5 Datasheet 2A 150kHz 40V Buck DC/DC Converter With Constant Current Loop XL4001 Schottky Diode Selection Table Current 1A 3A Surface Through VR (The same as system maximum input voltage) Mount Hole 20V 30V 40V 50V 1N5817 1N5818 1N5819 √ 60V √ 1N5820 1N5821 1N5822 √ MBR320 MBR330 MBR340 MBR350 MBR360 SK32 SK33 SK34 SK36 30WQ03 30WQ04 30WQ05 31DQ03 31DQ04 31DQ05 SR303 SR304 SR305 √ √ √ √ SR302 Rev 1.2 SK35 SR306 www.xlsemi.com 6 Datasheet 2A 150kHz 40V Buck DC/DC Converter With Constant Current Loop XL4001 Package Information (SOP8-EP) Rev 1.2 www.xlsemi.com 7
XL4001
物料型号:XL4001
器件简介:XL4001是一款150kHz固定频率PWM降压DC/DC转换器,能够以高效率、低纹波和出色的线路与负载调节驱动2A负载。它需要最少数量的外部组件,包括内部频率补偿和固定频率振荡器。
引脚分配:XL4001有8个引脚,包括电源开关输出引脚(SW)、地引脚(GND)、反馈引脚(FB)、输出电流感测引脚(CS)、使能引脚(EN)和供电电压输入引脚(VIN)。
参数特性:XL4001具有4.5V至40V的宽输入电压范围,输出可调节从1.235V至37V,最小降额电压为1.5V。它还具有2A的恒定输出电流能力、内部优化的功率晶体管、TTL关闭能力、带滞后功能的ON/OFF引脚、内置的热关闭功能、内置的电流限制功能和内置的输出过压保护。
功能详解:XL4001的PWM控制电路能够线性调整占空比从0%至100%。内部还构建了使能功能和过电流保护功能。此外,还内置了补偿块以最小化外部组件数量。
应用信息:XL4001适用于汽车充电器、电池充电器和LED恒流驱动器。
封装信息:XL4001采用SOP8-EP(暴露PAD)封装。
电气特性表提供了在不同条件下的最小值、典型值和最大值,例如反馈电压、效率、输入操作电压、待机电流、振荡频率、开关电流限制、使能引脚阈值、输出饱和电压和恒流感测电压等参数。
XL4001 价格&库存
很抱歉,暂时无法提供与“XL4001”相匹配的价格&库存,您可以联系我们找货
