XL6009
XL6009
    XLSEMI(芯龙)
    TO263-5
    400KHz 60V 4A开关电流升压/降压升压/逆变DC/DC转换器
XL6009 数据手册
XL6009 400KHz 60V 4A Switching Current Boost / Buck-Boost / Inverting DC/DC Converter Features General Description n n The XL6009 regulator is a wide input range, current mode, DC/DC converter which is capable of generating either positive or negative output voltages. It can be configured as either a boost, flyback, SEPIC or inverting converter. The XL6009 built in N-channel power MOSFET and fixed frequency oscillator, current-mode architecture results in stable operation over a wide range of supply and output voltages. The XL6009 regulator is special design for portable electronic equipment applications. n n n n n n n n n n n n n n Wide 5V to 32V Input Voltage Range Positive or Negative Output Voltage Programming with a Single Feedback Pin Current Mode Control Provides Excellent Transient Response 1.25V reference adjustable version Fixed 400KHz Switching Frequency Maximum 4A Switching Current SW PIN Built in Over Voltage Protection Excellent line and load regulation EN PIN TTL shutdown capability Internal Optimize Power MOSFET High efficiency up to 94% Built in Frequency Compensation Built in Soft-Start Function Built in Thermal Shutdown Function Built in Current Limit Function Available in TO263-5L package Applications n n n EPC / Notebook Car Adapter Automotive and Industrial Boost Buck-Boost / Inverting Converters Portable Electronic Equipment / Figure1. Package Type of XL6009 Rev 1.1 www.xlsemi.com 1 XL6009 400KHz 60V 4A Switching Current Boost / Buck-Boost / Inverting DC/DC Converter Pin Configurations Figure2. Pin Configuration of XL6009 (Top View) Table 1 Pin Description Pin Number 1 Pin Name GND 2 EN 3 SW 4 VIN 5 FB Description Ground Pin. Enable Pin. Drive EN pin low to turn off the device, drive it high to turn it on. Floating is default high. Power Switch Output Pin (SW). Supply Voltage Input Pin. XL6009 operates from a 5V to 32V DC voltage. Bypass Vin to GND with a suitably large capacitor to eliminate noise on the input. Feedback Pin (FB). Through an external resistor divider network, FB senses the output voltage and regulates it. The feedback threshold voltage is 1.25V. Rev 1.1 www.xlsemi.com 2 XL6009 400KHz 60V 4A Switching Current Boost / Buck-Boost / Inverting DC/DC Converter Function Block Figure3. Function Block Diagram of XL6009 Typical Application Circuit Figure4. XL6009 Typical Application Circuit (Boost Converter) Rev 1.1 www.xlsemi.com 3 XL6009 400KHz 60V 4A Switching Current Boost / Buck-Boost / Inverting DC/DC Converter Ordering Information Package Temperature Range Part Number Lead Free XL6009E1 XL6009TRE1 Marking ID Lead Free XL6009E1 XL6009E1 Packing Type Tube Tape & Reel XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant. Absolute Maximum Ratings(Note1) Parameter Symbol Vin VFB VEN VOutput PD Value -0.3 to 36 -0.3 to Vin -0.3 to Vin -0.3 to 60 Internally limited Unit V V V V mW Input Voltage Feedback Pin Voltage EN Pin Voltage Output Switch Pin Voltage Power Dissipation Thermal Resistance (TO263-5L) (Junction to Ambient, No Heatsink, Free Air) Operating Junction Temperature Storage Temperature Lead Temperature (Soldering, 10 sec) ESD (HBM) RJA 30 ºC/W TJ TSTG TLEAD -40 to 125 -65 to 150 260 >2000 ºC ºC ºC V Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operation is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Rev 1.1 www.xlsemi.com 4 XL6009 400KHz 60V 4A Switching Current Boost / Buck-Boost / Inverting DC/DC Converter XL6009 Electrical Characteristics Ta = 25℃;unless otherwise specified. Symbol Parameter Test Condition Min. Typ. Max. Unit 1.213 1.25 1.287 V - 92 - % System parameters test circuit figure4 Feedback Voltage VFB Efficiency ŋ Vin = 12V to 16V, Vout=18V Iload=0.1A to 2A Vin=12V ,Vout=18.5V Iout=2A Electrical Characteristics (DC Parameters) Vin = 12V, GND=0V, Vin & GND parallel connect a 220uf/50V capacitor; Iout=0.5A, Ta = 25℃; the others floating unless otherwise specified. Parameters Symbol Test Condition Min. Typ. 5 Max. Unit 32 V Input operation voltage Vin Shutdown Supply Current ISTBY VEN=0V 70 100 uA Quiescent Supply Current Iq VEN =2V, VFB =Vin 2.5 5 mA 400 480 Khz Oscillator Frequency Fosc Switch Current Limit IL VFB =0 4 Output Power NMOS Rdson Vin=12V, ISW=4A 110 VEN High (Regulator ON) Low (Regulator OFF) 1.4 0.8 IH VEN =2V (ON) 3 10 uA IL VEN =0V (OFF) 3 10 uA DMAX VFB=0V 90 EN Pin Threshold EN Pin Input Leakage Current Max. Duty Cycle 320 Rev 1.1 A 120 mohm V % www.xlsemi.com 5 XL6009 400KHz 60V 4A Switching Current Boost / Buck-Boost / Inverting DC/DC Converter Schottky Diode Selection Table Current 1A 3A Surface Through VR (The same as system maximum input voltage) Mount Hole 20V 30V 40V 50V 1N5817 1N5818 1N5819 √ √ 1N5820 1N5821 1N5822 √ MBR320 MBR330 MBR340 MBR350 MBR360 SK32 SK33 SK34 SK36 30WQ03 30WQ04 30WQ05 31DQ03 31DQ04 31DQ05 SR305 SR306 √ √ √ 5A √ 60V SK35 √ SR302 SR303 SR304 √ 1N5823 1N5824 1N5825 √ SR502 SR503 SR504 SR505 SR506 √ SB520 SB530 SB540 SB550 SB560 50WQ03 50WQ04 50WQ05 Typical System Application for EPC/Notebook Car Adapter – Boost (Output 18.5V/2.5A) Figure5. XL6009 Typical System Application (Boost Converter) Rev 1.1 www.xlsemi.com 6 XL6009 400KHz 60V 4A Switching Current Boost / Buck-Boost / Inverting DC/DC Converter Typical System Application for Portable Notebook Car Adapter – SEPIC Buck-Boost Topology (Input 10V~30V, Output 12V/2A) Figure6. XL6009 Typical System Application (SEPIC Buck-Boost Converter) Typical System Application for Inverting Converter – SEPIC Inverting Topology (Input 10V~30V, Output + -12V/1A) Figure7. XL6009 Typical System Application (SEPIC Inverting Converter) Rev 1.1 www.xlsemi.com 7 XL6009 400KHz 60V 4A Switching Current Boost / Buck-Boost / Inverting DC/DC Converter Package Information TO263-5L Symbol A B C C2 D E e F L L2 Dimensions In Millimeters Min Max 4.440 4.650 0.710 0.970 0.360 0.640 1.255 1.285 8.390 8.890 9.960 10.360 1.550 1.850 6.360 7.360 13.950 14.750 1.120 1.420 Rev 1.1 Dimensions In Inches Min Max 0.175 0.183 0.028 0.038 0.014 0.025 0.049 0.051 0.330 0.350 0.392 0.408 0.061 0.073 0.250 0.290 0.549 0.581 0.044 0.056 www.xlsemi.com 8
XL6009 价格&库存
很抱歉,暂时无法提供与“XL6009”相匹配的价格&库存,您可以联系我们找货
