XL7007
XL7007
    XLSEMI(芯龙)
    SOP-8
    1.2A 180KHz 70V降压DC-DC转换器
XL7007 数据手册
深圳市劲锐科技有限公司 SHENZHEN JINRUI TECHNOLOGIES CO., LTD. XLSEMI TEL:0755-83088967 83088481 Mail: info@jinrui-tech.com FAX:0755-83088481 1.2A 180KHz 70V Buck DC to DC Converter XL7007 Features General Description n n n n n n n n n n n n n n The XL7007 is a 180KHz fixed frequency PWM buck (step-down) DC/DC converter, capable of driving a 1.2A load with high efficiency, low ripple and excellent line and load regulation. Requiring a minimum number of external components, the regulator is simple to use and include internal frequency compensation and a fixed-frequency oscillator. Wide 10V to 70V Input Voltage Range Output Adjustable from 1.25V to 50V Maximum Duty Cycle 100% Minimum Drop Out 0.3V Fixed 180KHz Switching Frequency Maximum 1.2A Switching Current Internal Optimize Power MOSFET Recommend output power less than 10W High efficiency Excellent line and load regulation Built in thermal shutdown function Built in current limit function Built in output short protection function Available in SOP8L package The PWM control circuit is able to adjust the duty ratio linearly from 0 to 100%. An over current protection function is built inside. When short protection function happens, the operation frequency will be reduced from 180KHz to 36KHz. An internal compensation block is built in to minimize external component count. Applications n n n n n Car Charger Battery Charger Ebike controller power supply Portable instrument power supply Telecom / Networking Equipment Figure1. Package Type of XL7007 Rev 1.0 深圳市龙华新区油松路天汇大厦C栋205 1 www.jinrui-tech.com 深圳市劲锐科技有限公司 SHENZHEN JINRUI TECHNOLOGIES CO., LTD. XLSEMI TEL:0755-83088967 83088481 Mail: info@jinrui-tech.com 1.2A 180KHz 70V Buck DC to DC Converter FAX:0755-83088481 XL7007 Pin Configurations Figure2. Pin Configuration of XL7007 (Top View) Table 1 Pin Description Pin Number 1 Pin Name NC 2 FB 3 VC 4 VIN 5,6 SW 7,8 GND Rev 1.0 Description No connected, hold floating; Feedback Pin (FB). Through an external resistor divider network, FB senses the output voltage and regulates it. The feedback threshold voltage is 1.25V. Internal Voltage Regulator Bypass Capacity. In typical system application, The VC pin connect a 1uf capacity to VIN. Supply Voltage Input Pin. XL7007 operates from a 10V to 70V DC voltage. Bypass Vin to GND with a suitably large capacitor to eliminate noise on the input. Power Switch Output Pin (SW). SW is the switch node that supplies power to the output. Ground Pin. Care must be taken in layout. This pin should be placed outside of the Schottky Diode to output capacitor ground path to prevent switching current spikes from inducing voltage noise into XL7007. 深圳市龙华新区油松路天汇大厦C栋205 2 www.jinrui-tech.com 深圳市劲锐科技有限公司 SHENZHEN JINRUI TECHNOLOGIES CO., LTD. XLSEMI TEL:0755-83088967 83088481 Mail: info@jinrui-tech.com FAX:0755-83088481 1.2A 180KHz 70V Buck DC to DC Converter XL7007 Function Block Figure3. Function Block Diagram of XL7007 Typical Application Circuit Figure4. XL7007 Typical Application Circuit (VIN=16V~70V, VOUT=15V/0.7A) Rev 1.0 深圳市龙华新区油松路天汇大厦C栋205 3 www.jinrui-tech.com 深圳市劲锐科技有限公司 SHENZHEN JINRUI TECHNOLOGIES CO., LTD. XLSEMI TEL:0755-83088967 83088481 Mail: info@jinrui-tech.com FAX:0755-83088481 1.2A 180KHz 70V Buck DC to DC Converter XL7007 Ordering Information Package Temperature Range Part Number Lead Free XL7007E1 Marking ID Lead Free XL7007E1 Packing Type 2500 Units on Tape & Reel XLSEMI Pb-free products, as designated with “E1” suffix in the par number, are RoHS compliant. Absolute Maximum Ratings(Note1) Parameter Symbol Vin VFB VOutput PD Value -0.3 to 75 -0.3 to Vin -0.3 to Vin Internally limited Unit V V V mW Input Voltage Feedback Pin Voltage Output Switch Pin Voltage Power Dissipation Thermal Resistance (SOP8L) (Junction to Ambient, No Heatsink, Free Air) Operating Junction Temperature Storage Temperature Lead Temperature (Soldering, 10 sec) ESD (HBM) RJA 100 ºC/W TJ TSTG TLEAD -40 to 125 -65 to 150 260 >2000 ºC ºC ºC V Note1: Stresses greater than those listed under Maximum Ratings may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operation is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Rev 1.0 深圳市龙华新区油松路天汇大厦C栋205 4 www.jinrui-tech.com 深圳市劲锐科技有限公司 SHENZHEN JINRUI TECHNOLOGIES CO., LTD. XLSEMI TEL:0755-83088967 83088481 Mail: info@jinrui-tech.com FAX:0755-83088481 1.2A 180KHz 70V Buck DC to DC Converter XL7007 XL7007 Electrical Characteristics Ta = 25℃;unless otherwise specified. Symbol Parameter Test Condition Min. Typ. Max. Unit 1.225 1.25 1.275 V - 92 - % - 89 - % System parameters test circuit figure4 Feedback Voltage VFB Efficiency ŋ Efficiency ŋ Vin = 16V to 70V, Vout=15V Iload=0.1A to 0.7A Vin=36V ,Vout=15V Iout=0.7A Vin=48V ,Vout=15V Iout=0.7A Electrical Characteristics (DC Parameters) Vin = 48V, GND=0V, Vin & GND parallel connect a 33uf/100V capacitor; Iout=100mA, Ta = 25℃; the others floating unless otherwise specified. Parameters Symbol Input operation voltage Vin Quiescent Supply Current Fosc Output Short Frequency Fosp Min. Typ. Max. Unit 70 V 3 5 mA 180 216 KHz 10 Iq Oscillator Frequency Switch Current Limit Test Condition VFB =Vin 144 36 KHz IL VFB =0 1.3 A Max. Duty Cycle DMAX VFB=0V 100 % Output Power PMOS Rdson VFB=0V, Vin=48V, ISW=1A 180 Rev 1.0 深圳市龙华新区油松路天汇大厦C栋205 5 210 mohm www.jinrui-tech.com 深圳市劲锐科技有限公司 SHENZHEN JINRUI TECHNOLOGIES CO., LTD. XLSEMI TEL:0755-83088967 83088481 Mail: info@jinrui-tech.com FAX:0755-83088481 1.2A 180KHz 70V Buck DC to DC Converter XL7007 Typical System Application (VOUT=15V/0.7A) Figure5. XL7007 System Parameters Test Circuit (VIN=16V~70V, VOUT=15V/0.7A) Efficiency VS Load current 100 95 90 85 80 Efficiency(%) 75 70 65 60 VIN=24V,VOUT=15V,IOUT=0.1A~0.7A VIN=36V,VOUT=15V,IOUT=0.1A~0.7A VIN=48V,VOUT=15V,IOUT=0.1A~0.7A VIN=60V,VOUT=15V,IOUT=0.1A~0.7A 55 50 45 40 35 30 0.1 0.2 0.3 0.4 0.5 0.6 0.7 Load current(A) Figure6. XL7007 System Efficiency Curve Rev 1.0 深圳市龙华新区油松路天汇大厦C栋205 6 www.jinrui-tech.com 深圳市劲锐科技有限公司 SHENZHEN JINRUI TECHNOLOGIES CO., LTD. XLSEMI TEL:0755-83088967 83088481 Mail: info@jinrui-tech.com FAX:0755-83088481 1.2A 180KHz 70V Buck DC to DC Converter XL7007 Typical System Application (VOUT=5V/1A) Figure7. XL7007 System Parameters Test Circuit (VIN=10V~60V, VOUT=5V/1A) Efficiency VS Load current 95 90 85 80 Efficiency(%) 75 70 65 60 VIN=12V,VOUT=5V,IOUT=0.1A~1A VIN=24V,VOUT=5V,IOUT=0.1A~1A VIN=36V,VOUT=5V,IOUT=0.1A~1A VIN=48V,VOUT=5V,IOUT=0.1A~1A VIN=60V,VOUT=5V,IOUT=0.1A~1A 55 50 45 40 35 30 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 Load current(A) Figure8. XL7007 System Efficiency Curve Rev 1.0 深圳市龙华新区油松路天汇大厦C栋205 7 www.jinrui-tech.com 深圳市劲锐科技有限公司 SHENZHEN JINRUI TECHNOLOGIES CO., LTD. XLSEMI TEL:0755-83088967 83088481 Mail: info@jinrui-tech.com FAX:0755-83088481 1.2A 180KHz 70V Buck DC to DC Converter XL7007 Typical System Application (VOUT=10V/1A) Figure9. XL7007 System Parameters Test Circuit (VIN=12V~60V, VOUT=10V/1A) Efficiency VS Load current 100 95 90 85 80 Efficiency(%) 75 70 65 VIN=12V,VOUT=10V,IOUT=0.1A~1A VIN=24V,VOUT=10V,IOUT=0.1A~1A VIN=36V,VOUT=10V,IOUT=0.1A~1A VIN=48V,VOUT=10V,IOUT=0.1A~1A VIN=60V,VOUT=10V,IOUT=0.1A~1A 60 55 50 45 40 35 30 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 Load current(A) Figure10. XL7007 System Efficiency Curve Rev 1.0 深圳市龙华新区油松路天汇大厦C栋205 8 www.jinrui-tech.com 深圳市劲锐科技有限公司 SHENZHEN JINRUI TECHNOLOGIES CO., LTD. XLSEMI TEL:0755-83088967 83088481 Mail: info@jinrui-tech.com FAX:0755-83088481 1.2A 180KHz 70V Buck DC to DC Converter XL7007 Typical System Application (VOUT=20V/0.5A) Figure11. XL7007 System Parameters Test Circuit (VIN=24V~70V, VOUT=20V/0.5A) Efficiency VS Load current 100 95 90 85 80 Efficiency(%) 75 70 65 60 VIN=24V,VOUT=20V,IOUT=0.1A~0.5A VIN=36V,VOUT=20V,IOUT=0.1A~0.5A VIN=48V,VOUT=20V,IOUT=0.1A~0.5A VIN=60V,VOUT=20V,IOUT=0.1A~0.5A 55 50 45 40 35 30 0.10 0.15 0.20 0.25 0.30 0.35 0.40 0.45 0.50 Load current(A) Figure12. XL7007 System Efficiency Curve Rev 1.0 深圳市龙华新区油松路天汇大厦C栋205 9 www.jinrui-tech.com 深圳市劲锐科技有限公司 SHENZHEN JINRUI TECHNOLOGIES CO., LTD. XLSEMI TEL:0755-83088967 83088481 Mail: info@jinrui-tech.com 1.2A 180KHz 70V Buck DC to DC Converter FAX:0755-83088481 XL7007 Package Information SOP8 Package Mechanical Dimensions Rev 1.0 深圳市龙华新区油松路天汇大厦C栋205 10 www.jinrui-tech.com
XL7007 价格&库存
很抱歉,暂时无法提供与“XL7007”相匹配的价格&库存,您可以联系我们找货
XL7007
