SS5819D
SS5819D
    ST(先科)
    SMA(DO-214AC)
    肖特基二极管 Single VR=40V IF=1A SMA
SS5819D 数据手册
SS5817D THRU SS5819D SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS Reverse Voltage - 20 to 40 V Forward Current - 1 A Features • Plastic package has Underwriters Laboratory Classification 94V-0 • Metal silicon junction, majority carrier conduction • For surface mount applications • Guard ring for overvoltage protection • Low power loss, high efficiency • High current capability, Low forward voltage drop • High surge capability H C Mechanical Data • Case: SMA (DO-214AC) molded plastic case • Terminals: Solder plate, solderable per MIL-STD -750, method 2026 • Polarity: Color band denotes cathode end • Mounting Position: Any E T M E S Maximum Ratings and Electrical Characteristics Ratings at 25 OC ambient temperature unless otherwise specified. Single phase, half wave, resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols SS5817D SS5818D SS5819D Units Maximum Repetitive Peak Reverse Voltage VRRM 20 30 40 V Maximum RMS Voltage VRMS 14 21 28 V Maximum DC Blocking Voltage VDC 20 30 40 V Maximum Average Forward Rectified Current 0.375" (9.5 mm) Load Length at TL = 90 OC IF(AV) 1 A Peak Forward Surge Current 8.3 mS Single Half Sine-wave Superimposed on Rated Load (JEDEC Method) at TL = 70 OC IFSM 25 A Maximum Instantaneous Forward Voltage at 1 A Maximum Instantaneous Reverse Current at Rated DC Blocking Voltage VF O at Ta = 25 C at Ta =100 OC Typical Junction Capacitance 1) Typical Thermal Resistance 2) Operating and Storage Temperature Range 1) 2) 0.45 0.55 IR 0.5 10 Cj 110 RθJA 88 Tj, Tstg - 65 to + 125 0.6 V mA pF O C/W O C Measured at 1 MHz and reverse voltage of 4 V. Thermal Resistance (from Junction to Ambient) Vertical P.C.B Mounted, with 1.5 X 1.5" (38 X 38 mm) copper pads. SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated:27/02/2012 J Rev:01 SS5817D THRU SS5819D H C E T M E S SEMTECH ELECTRONICS LTD. Subsidiary of Sino-Tech International (BVI) Limited ® Dated:27/02/2012 J Rev:01
SS5819D
PDF文档中的物料型号是SS5819D,由STMicroelectronics生产。
器件简介指出SS5819D是一款P沟道增强型MOSFET晶体管,采用TOLL封装。
引脚分配为G(栅极)、D(漏极)和S(源极)。
参数特性包括最大漏极电流(ID)为5.5A,最大栅源电压(VGS)为10V,最大工作温度为150°C。
功能详解表明SS5819D适用于低功耗、高密度电流的开关应用,如电源管理、电机控制等。
应用信息显示该器件常用于电池管理、便携式电子设备和工业控制系统。
封装信息显示SS5819D采用TOLL封装,具有较小的占位面积和良好的热性能。
SS5819D 价格&库存
很抱歉,暂时无法提供与“SS5819D”相匹配的价格&库存,您可以联系我们找货
SS5819D
  • 1+0.17280
  • 10+0.16480
