TDC63VS4700M25.4*40_VS
    SAMYOUNG(韩国三莹)
    插件,D25.4xL40mm
    直插铝电解电容 插件,D25.4xL40mm 4.7mF ±20% Ф25.40 x 40.00mm 63V 2000Hrs@105℃
TDC63VS4700M25.4*40_VS 数据手册
LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS •1 0 5 ℃ 2 , 0 0 0 H r s a s s u r e d . TDC Series •Non-solvent proof. •Downsized. •For SMPS, Inverter. •RoHS compliant. •Halogen-free capacitors are also available. TDA TDC Downsized SPECIFICATIONS ltem Characteristics Rated Voltage Range 160 ~ 500 VDC Operating Temperature Range -25 ~ +105℃ Capacitance Tolerance ±20% (M) (at 20℃, 120Hz) I=0.02CV or 3mA, whichever is smaller. Where, I:Leakage current(㎂) C:Nominal capacitance(㎌) V:Rated voltage(VDC) (at 20℃, 5 minutes) Leakage Current ※ Dissipation Factor(Tan δ) Rated Voltage(VDC) 160~400 420~500 Tanδ(Max.) 0.15 0.20 (at 20℃, 120Hz) Temperature Characteristics (Max.Impedance ratio) Rated Voltage(VDC) 160~400 420~500 Z(-25℃)/Z(20℃) 4 8 (at 120HZ) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours at 105℃. Load Life Capacitance change Tanδ Leakage Current ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after the exposing them at 105℃ for 1,000 hours without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Shelf Life Capacitance change Tanδ Leakage Current Others ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ The initial specified value Satisfied characteristics KS C IEC 60384-4 ※ For capacitors with CV products › 100,000 Higher Tanδvalue may apply. ※ When the capacitance exceeds 1,000㎌, 0.01 shall be added every 1,000㎌ increase. DIMENSIONS OF TDC Series RATED RIPPLE CURRENT When capacitors are operated in any other condition at 120HZ, the maximum ripple current must be multiplied by the figure shown in the table. ØD=Ø22~Ø35 VN/VS type PC board pin-out Frequency multiplying factor Freq.(Hz) VDC 1 6 0 ~ 2 5 0 VDC 3 1 5 ~ 5 0 0 VDC 60 0.81 0.77 120 1.00 1.00 300 1.17 1.16 1k 1.32 1.30 10k~ 1.45 1.41 Marking : BROWN SLEEVE, SILVER INK The standard design has no bottom plate. 204 Unit(mm) LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF TDC Series ㎌ VDC ØD 160 22 25.4 200 30 35 22 25.4 250 30 35 180 220 270 330 390 470 560 680 820 22×20 1.20 22×25 1.32 22×30 1.46 22×30 1.66 22×35 1.87 22×40 2.09 1,000 1,200 ㎌ VDC ØD 25.4×20 1.39 25.4×25 1.51 25.4×25 1.68 25.4×30 1.88 25.4×30 2.14 25.4×35 2.38 25.4×40 2.66 30×20 1.31 30×20 1.54 30×25 1.68 30×25 1.96 30×25 35×25 2.15 2.04 30×30 35×25 2.40 2.55 30×35 35×30 2.69 2.86 22×25 1.20 22×25 1.28 22×25 1.31 22×30 1.45 22×40 1.67 22×45 1.75 22×50 2.04 25.4×20 1.27 25.4×20 1.43 25.4×25 1.53 25.4×30 1.67 25.4×35 1.75 25.4×40 2.04 315 22 25.4 30×20 1.43 30×20 1.53 30×25 1.67 30×25 1.74 30×30 2.04 30×35 2.30 35×20 1.67 35×20 1.72 35×25 2.04 35×30 2.30 35×30 2.65 120 150 180 220 270 330 390 470 560 25.4 350 30 35 22 25.4 22×25 0.75 22×25 0.82 22×30 25.4×25 0.91 0.94 25.4×25 1.13 25.4×30 30×25 1.19 1.17 25.4×40 30×30 35×20 1.41 1.28 1.30 30×35 35×30 1.40 1.49 30×40 35×30 1.44 1.64 30×45 35×35 1.71 1.82 35×40 2.00 30 35 35×20 1.30 35×20 1.49 35×20 1.57 35×25 1.72 35×30 2.10 35×30 2.36 35×35 2.63 400 30 35 82 100 22 22×20 0.78 22×25 25.4×20 1.00 0.95 25.4×20 1.10 25.4×25 30×20 1.20 1.26 30×25 1.44 30×25 1.57 30×30 1.80 30×30 1.94 30×35 2.29 30×45 2.59 22×25 0.72 22×30 25.4×25 0.84 0.89 22×35 25.4×30 0.98 0.94 22×40 25.4×30 30×25 1.04 1.07 1.13 25.4×35 30×30 1.24 1.27 25.4×40 30×35 35×25 1.39 1.43 1.49 25.4×50 30×40 35×30 1.55 1.60 1.66 25.4×50 30×45 35×30 1.72 1.81 1.83 35×35 2.07 22 25.4 22×20 0.55 22×25 25.4×20 0.66 0.67 25.4×25 0.76 25.4×25 0.86 25.4×30 0.97 25.4×35 1.12 25.4×40 1.26 25.4×45 1.44 25.4×50 1.51 30 35 30×20 0.89 30×25 1.02 30×30 1.12 30×30 1.27 30×35 1.43 30×40 1.60 30×45 1.81 35×20 1.02 35×20 1.11 35×25 1.27 35×30 1.44 35×30 1.63 35×35 1.80 Case Size ØD×L(mm) Rated Ripple Current(Arms/105℃, 120Hz) TDC Series 205 LARGE SIZED ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF TDC Series ㎌ VDC ØD 420 22 25.4 450 30 35 68 82 100 120 150 180 220 270 330 390 470 206 22×20 0.58 22×25 0.66 22×30 0.75 22×40 0.86 22×45 0.96 22×50 1.11 25.4×25 0.69 25.4×25 0.77 25.4×30 0.88 25.4×35 0.97 25.4×40 1.14 25.4×45 1.29 30×20 0.75 30×25 0.88 30×30 1.02 30×30 1.14 30×40 1.30 30×45 1.48 35×20 1.05 35×25 1.12 35×30 1.35 35×35 1.49 35×40 1.64 35×45 1.79 22 25.4 500 30 22×20 0.50 22×25 25.4×25 0.59 0.62 25.4×25 0.70 25.4×30 0.75 25.4×30 30×25 0.88 0.87 25.4×35 30×25 1.01 1.00 30×35 1.10 30×40 1.24 35 35×30 1.25 35×35 1.42 35×40 1.63 35×45 1.78 22 25.4 30 22×35 0.50 22×40 25.4×30 0.53 0.55 22×45 25.4×35 0.61 0.64 22×50 25.4×40 30×30 0.66 0.71 0.73 25.4×45 30×35 0.81 0.80 25.4×50 30×40 0.86 0.93 30×45 0.94 30×50 1.07 30×60 1.28 35 35×30 0.95 35×35 0.98 35×40 1.13 35×45 1.29 35×50 1.47 35×60 Case Size ØD×L(mm) Rated Ripple Current(Arms/105℃, 120Hz) 1.71
TDC63VS4700M25.4*40_VS 价格&库存
很抱歉,暂时无法提供与“TDC63VS4700M25.4*40_VS”相匹配的价格&库存,您可以联系我们找货
