NFR450VB6.8M10*16_5.0TP
    SAMYOUNG(韩国三莹)
    插件,D10xL16mm
    直插铝电解电容 插件,D10xL16mm 6.8µF ±20% Ф10.00 x 16.00mm 450V 250mA 10000Hrs@105℃
NFR450VB6.8M10*16_5.0TP 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS NFR Series •105℃ 8,000~12,000Hrs assured. •Non-solvent proof. •High Ripple, Long Life. •For Ballasts stabilizer and other long life required applications. •RoHS compliant. •Halogen-free capacitors are also available. NFR NFL High Ripple SPECIFICATIONS ltem Characteristics Rated Voltage Range 160~400 VDC 420~500 VDC Operating Temperature Range -40~+105℃ -25~+105℃ Capacitance Tolerance ±20%(M) Time c·v Leakage Current After 1 minute (at 20℃, 120Hz) After 5 minutes ≦ 1000 I=0.1CV+40 I=0.03CV+15 > 1000 I=0.04CV+100 I=0.02CV+25 Where, I:Max. Leakage current(㎂) C:Nominal capacitance(㎌) V:Rated voltage(VDC) Dissipation Factor(Tan δ) Temperature Characteristics (Max. Impedance ratio) Load Life Rated Voltage(VDC) 160~250 350~500 Tanδ(Max.) 0.20 0.24 (at 20℃) (at 20℃, 120Hz) Rated Voltage(VDC) 160~250 350~400 420~500 Z(–25℃)/Z(20℃) 3 5 6 Z(–40℃)/Z(20℃) 6 6 - (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 12,000 hours at 105℃. (where, 8,000 hours for Ø8, 10,000 hours for Ø10, Ø8x50L) Capacitance change Tan δ Leakage current ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. Shelf Life Satisfied characteristics KS C IEC 60384-4 Unit(mm) Marking : DARK BROWN SLEEVE, SILVER INK ØD 20 18 8 10 12.5 16 Ød 0.6 0.6 0.6 0.8 0.8 0.8 F 3.5 5.0 5.0 7.5 7.5 7.5 ØD′ ØD+0.5 max. L′ L+2.0 max. Ø8×11.5~20L, L' ≦ L+1.5 ※Ø 167 Series DIMENSIONS OF NFR Series ≦ ±20% of the initial value ≦ 200% of the initial specified value ≦ 500% of the initial specified value NFR Others Capacitance change Tan δ Leakage current MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NFR Series ㎌ V DC ltems 10 22 10×16 10×16 320 450 25 10×16 478 27 33 39 47 56 10×16 10×16 10×16 10×20 10×20 10×20 12.5×20 12.5×25 12.5×25 16×20 16×25 16×25 16×31.5 18×25 16×35.5 16×40 18×31.5 18×35.5 18×40 500 600 613 750 788 900 950 1,025 1,125 1,125 1,339 1,510 1,933 1,870 2,189 2,516 2,446 2,745 3,064 68 82 100 120 150 220 270 330 390 470 ㎌ V DC ltems 4.7 6.8 10 22 33 47 68 82 100 120 150 180 220 168 ØD×L(mm) 160 Rated Ripple Current (mArms/105 ℃, 100kHZ) ØD×L(mm) 8×11.5 8×11.5 10×12.5 8×15 10×16 10×16 10×20 12.5×16 12.5×20 8×50 12.5×20 10×40 12.5×25 12.5×30 16×20 16×25 18×20 18×20 18×25 12.5×50 18×31.5 18×31.5 250 Rated Ripple Current (mArms/105 ℃, 100kHZ) 160 180 250 240 350 470 500 613 688 875 850 1,125 1,070 1,340 1,340 1,400 1,400 1,450 1,740 1,910 1,960 2,040 ØD×L(mm) 200 Rated Ripple Current (mArms/105℃, 100kHZ) 10×16 10×16 8×20 10×16 10×16 10×20 10×20 12.5×20 12.5×25 10×33 12.5×25 16×20 320 450 465 478 500 650 670 850 1,013 1,200 1,070 1,250 16×25 1,300 16×25 16×25 1,339 1,510 18×31.5 2,030 18×35.5 2,300 18×40 2,586 ØD×L(mm) 350 Rated Ripple Current (mArms/105℃, 100kHZ) 8×20 10×16 350 330 12.5×20 650 10×33 12.5×25 16×20 10×50 16×20 16×31.5 18×25 700 750 750 950 950 1,300 1,300 18×25 1,400 18×31.5 1,550 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS RATINGS OF NFR Series ㎌ V DC ltems 1 2.2 3.3 4.7 6.8 10 15 22 33 47 ㎌ 400 Rated Ripple Current (mArms/105 ℃, 100kHZ) ØD×L(mm) 8×11.5 8×11.5 8×11.5 10×12.5 8×11.5 10×12.5 8×15 10×16 8×20 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 16×20 16×25 18×20 60 100 130 150 145 170 180 280 350 350 410 410 500 550 780 800 980 980 56 68 82 100 18×25 18×31.5 18×35.5 1,350 1,500 1,650 120 18×40 1,850 150 180 18×45 18×45 1,900 2,000 V DC ltems 4.7 6.8 10 15 22 33 8×20 10×16 10×16 10×20 10×20 10×20 12.5×20 12.5×25 725 12.5×30 16×25 750 920 10×50 12.5×40 16×25 900 920 980 40 47 18×25 18×31.5 1,100 1,300 100 18×35.5 1,400 120 18×40 18×45 20×40 1,650 1,800 1,800 150 12.5×20 450 ØD×L(mm) 580 725 750 920 920 980 950 1,100 1,300 1,400 1,600 1,750 500 Rated Ripple Current (mArms/105 ℃, 100kHZ) 12.5×20 12.5×25 16×20 12.5×30 16×25 18×20 16×31.5 18×25 12.5×50 440 500 500 600 600 600 700 700 860 18×31.5 880 12.5×60 18×35.5 18×40 18×45 20×40 1,180 1,200 1,300 1,500 1,500 Series 60 68 82 360 NFR 16×20 10×20 12.5×25 16×20 12.5×30 16×25 12.5×40 16×25 18×20 18×25 18×31.5 18×35.5 18×35.5 18×40 450 Rated Ripple Current (mArms/105 ℃, 100kHZ) 220 220 250 280 360 400 450 580 ØD×L(mm) ØD×L(mm) 420 Rated Ripple Current (mArms/105℃, 100kHZ) RATED RIPPLE CURRENT MULTIPLIERS Frequency Multipliers Freq.(Hz) Cap.(㎌) 1~15 22~82 100~470 120 1k 10k 50k 100k 0.35 0.40 0.45 0.65 0.70 0.75 0.90 0.90 0.90 0.95 0.95 0.95 1.00 1.00 1.00 169
NFR450VB6.8M10*16_5.0TP 价格&库存
很抱歉,暂时无法提供与“NFR450VB6.8M10*16_5.0TP”相匹配的价格&库存,您可以联系我们找货
