0B
5.08mm Pitch - Plug-in PCB Terminal Block Set
5.08mm
Pitch:
Direction:
Screw cage
Clamp:
Direction:
Vertical
Mounting:
KF2EDGK 5.08
0.00g
Electrical
Pluggable
KF2EDGV 5.08
0.00g
N.W.:
Electrical
Current
IEC
15A
UL
10A
Voltage Wire Range Withstanding
300V
28-12AWG
AC1500V
Installation
Current
IEC
15A
UL
10A
Voltage Withstanding
300V
AC1500V
Installation
Screw size
Torque
Strip Lgth
Max Solder
Hole Size
Max Solder
M2.5
0.50mm
8.00mm
+250deg
1.40mm
+250deg
4.4lb.in
0.31in
Material
0.06in
Material
Screw:
Galvanized Steel
Screw:
Contact:
Nickled brass
Pin:
Clamp:
Nickled brass,Galvanized Steel
Clamp:
Housing:
PA66.UL94-0
Housing:
Temp limit: -40deg-+105deg
Color:
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
2P
Poles:
Mounting: Pluggable
N.W.:
5.08mm
Clamp:
2P
Poles:
Pitch:
N.W.
Color:
Total
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
PA66.UL94-0
Green
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
Tin-plate brass
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
N.W.
Green
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
Total
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
/2P*1000 ROHS
A
$29.50 /2P*1000
B
MOQ: 2P*1000,000
Price:
KEFA Terminal Block · No.1 Xinggong Road,Xiaolin Town,Cixi , Zhejiang,CN · Tel/Fax:0574-63509566 · www.cnkefa.com · cnkefa@hotmail.com
5.08mm Pitch - Plug-in PCB Terminal Block Female
5.08mm
Pitch:
Pitch:
Direction:
5.08mm
Direction:
Screw cage
Clamp:
Clamp:
2P
Poles:
2P
Poles:
Mounting: Pluggable
Mounting:
KF2EDGKA 5.08
3.49g
N.W.:
Screw cage
Electrical
N.W.:
Pluggable
KF2EDGKB 5.08
3.49g
Electrical
IEC
UL
Installation
Current
15A
10A
Screw size
M2.5
300V
28-12AWG AC1500V
Torque
0.50mm
4.4lb.in
Strip Lgth
8.00mm
0.31in
IEC
UL
Installation
Max Solder
+250deg
Material
Current
15A
10A
Voltage
300V
Flang
M2.5
Hole Size
1.40mm
0.06in
28-12AWG AC1500V
Max Solder
+250deg
Material
Galvanized Steel
Screw:
Contact: Nickled brass
Nickled brass
Clamp:
Housing: PA66.UL94-0
Green
Color:
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
N.W.
3.49g
5.23g
6.97g
8.72g
10.46g
12.20g
13.95g
15.69g
17.43g
19.18g
Price:
A
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
MOQ: 2P*1000,000
Total
3486.60g
3137.94g
3486.60g
4358.25g
4183.92g
4881.24g
4183.92g
4706.91g
5229.90g
3835.26g
/2P*1000 ROHS
Screw:
Contact:
Clamp:
Housing:
Temp limit:
Color:
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
N.W.
3.49g
5.23g
6.97g
8.72g
10.46g
12.20g
13.95g
15.69g
17.43g
19.18g
Price:
A
Galvanized Steel
Nickled brass
Nickled brass
PA66.UL94-0
-40deg-+105deg
Green
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
Total
3486.60g
3137.94g
3486.60g
4358.25g
4183.92g
4881.24g
4183.92g
4706.91g
5229.90g
3835.26g
/2P*1000 ROHS
MOQ: 2P*1000,000
5.08mm
Pitch:
Direction:
Screw cage
Clamp:
Direction:
Vertical
2P
Poles:
Mounting: Pluggable
Mounting:
KF2EDGKM 5.08
0.00g
N.W.:
5.08mm
Clamp:
2P
Poles:
Pitch:
Electrical
Pluggable
KF2EDGVM 5.08
0.00g
N.W.:
Electrical
Current
IEC
15A
UL
10A
300V
28-12AWG
AC1500V
Installation
Current
IEC
15A
UL
10A
300V
AC1500V
Installation
Screw size
Torque
Strip Lgth
Max Solder
Flang
Hole Size
Max Solder
M2.5
0.50mm
8.00mm
+250deg
M2.5
1.40mm
+250deg
4.4lb.in
0.31in
Material
0.06in
Material
Screw:
Galvanized Steel
Flang:
Nickled brass
Contact:
Nickled brass
Pin:
Tin-plate brass
Clamp:
Clamp:
Housing:
PA66.UL94-0
Housing:
Color:
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
N.W.
Price:
A
Green
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
Color:
Total
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
PA66.UL94-0
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
N.W.
Green
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
Total
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
$94.87 /2P*1000 ROHS
MOQ: 2P*1000,000
5.08mm Pitch - Pluggable Terminal Block Male Dual-Pin
Pitch:
5.08mm
Pitch:
5.08mm
Direction:
Parallel
Direction:
Parallel
Clamp:
Clamp:
2P
Poles:
Mounting: Pluggable
Mounting:
KF2EDGRT 5.08
0.00g
N.W.:
2P
Poles:
Electrical
N.W.:
Pluggable
KF2EDGRTC 5.08
0.00g
Electrical
IEC
UL
Installation
Current
15A
10A
300V
AC1500V
IEC
UL
Installation
Current
15A
10A
Hole Size Max Solder
1.60mm
+250deg
0.06in
Material
300V
AC1500V
Hole Size
1.60mm
0.06in
Max Solder
+250deg
Material
Screw:
Tin-plate brass
Pin :
Clamp:
Green
Color:
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
N.W.
Price:
A
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
MOQ: 2P*1000,000
Total
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
/2P*1000 ROHS
Screw:
Pin :
Clamp:
Housing:
Temp limit:
Color:
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
N.W.
Price:
A
Tin-plate brass
PA66.UL94-0
-40deg-+105deg
Green
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
Total
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
/2P*1000 ROHS
MOQ: 2P*1000,000
Pitch:
5.08mm
Pitch:
5.08mm
Direction:
Vertical
Direction:
Vertical
Clamp:
Clamp:
2P
Poles:
Mounting: Pluggable
Mounting:
KF2EDGVT 5.08
0.00g
N.W.:
2P
Poles:
Electrical
N.W.:
Pluggable
KF2EDGVTC 5.08
0.00g
Electrical
IEC
UL
Installation
Current
15A
10A
300V
AC1500V
IEC
UL
Installation
Current
15A
10A
1.60mm
+250deg
0.06in
Material
300V
AC1500V
Hole Size
1.60mm
0.06in
Max Solder
+250deg
Material
Screw:
Tin-plate brass
Pin :
Clamp:
Green
Color:
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
N.W.
Price:
A
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
MOQ: 2P*1000,000
Total
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
/2P*1000 ROHS
Screw:
Pin :
Clamp:
Housing:
Temp limit:
Color:
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
N.W.
Price:
A
Tin-plate brass
PA66.UL94-0
-40deg-+105deg
Green
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
Total
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
/2P*1000 ROHS
MOQ: 2P*1000,000
Pitch:
5.08mm
Pitch:
5.08mm
Direction:
Parallel
Direction:
Vertical
Clamp:
Clamp:
2P
Poles:
Mounting: Pluggable
Mounting:
KF2EDGRH 5.08
0.00g
N.W.:
2P
Poles:
Electrical
N.W.:
Pluggable
KF2EDGVH 5.08
0.00g
Electrical
IEC
UL
Installation
Current
15A
10A
300V
AC1500V
IEC
UL
Installation
Current
15A
10A
1.60mm
+250deg
0.06in
Material
300V
AC1500V
Hole Size
1.60mm
0.06in
Max Solder
+250deg
Material
Screw:
Tin-plate brass
Pin :
Clamp:
Green
Color:
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
N.W.
Price:
A
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
MOQ: 2P*1000,000
Total
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
/2P*1000 ROHS
Screw:
Pin :
Clamp:
Housing:
Temp limit:
Color:
No. Poles
2P
3P
4P
5P
6P
7P
8P
9P
10P
11P
N.W.
Price:
A
Tin-plate brass
PA66.UL94-0
-40deg-+105deg
Green
Box
1000pcs
600pcs
500pcs
500pcs
400pcs
400pcs
300pcs
300pcs
300pcs
200pcs
Total
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
.00g
/2P*1000 ROHS
MOQ: 2P*1000,000
很抱歉,暂时无法提供与“KF2EDGVC-7.62-12P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.14413
- 10+2.90773
- 30+2.86045
- 100+2.71861
