33MHZ 3225 无源
33MHZ 3225 无源
    YXC(扬兴科技)
    SMD3225_4P
    无源晶振 40Ω 7pF 33MHz ±10ppm -40℃~+85℃ SMD3225_4P
33MHZ 3225 无源 数据手册
Crystal unit Product Number (please contact us) FA-238V : Q22FA23V0xxxx17 FA-238 : Q22FA2380xxxx17 TSX-3225 : X1E000021xxxx16 MHz RANGE CRYSTAL UNIT FA - 238V / FA - 238 TSX - 3225 •Frequency range : • External dimensions : : •Overtone order : •Applications : : 12 MHz to 60 MHz(FA-238,FA-238V) 3.2 × 2.5 × 0.6 mm ···TSX-3225 3.2 × 2.5 × 0.7 mm ···FA-238V / FA-238 Fundamental Mobile phone, Bluetooth, W-LAN ISM band radio, Clock for MPU Actual size FA-238V/ FA-238 TSX-3225 Specifications (characteristics) Item Symbol Nominal frequency range f_nom Storage temperature Operating temperature Level of drive T_stg T_use DL Frequency tolerance f_tol Frequency versus temperature characteristics Load capacitance Motional resistance (ESR) Frequency aging For Clock For RF Reference FA-238V FA-238 TSX-3225 12.000 MHz to 16.000 MHz to 16.000 MHz to 15.999 MHz 60.000 MHz 48.000 MHz -40 °C to +125 °C -40 °C to +85 °C (+105 °C) 200 µW Max. ±50 × 10-6 (standard), -6 ±10 × 10 (±15 × 10-6 to ±50 × 10-6 is available) ±30 × 10-6/-20 °C to +70 °C f_tem Conditions / Remarks Fundamental *1 Please contact us about available frequencies. Storage as single product. Please contact us about +85 °C < T_use Recommended: 1 to 100 µW +25 °C Please contact us for requirements not listed in this specifications. *1 Please contact us for requirements not listed in this specifications. *1 Please specify. -40 °C to +85 °C, DL = 100 µW +25 °C, First year ±10 × 10 /-20 °C to +75 °C -6 7 pF to ∞ CL R1 f_age As per table below ±5 × 10-6 / year Max. *1 FA-238: For over 40 MHz, only the standard specification applies. As per table below ±1 × 10-6 / year Max.*2 *2 40 MHz ≤ f_nom : ±2 × 10-6 / year Max. Motional resistance (ESR) (FA-238V / FA-238) Frequency 12.0 MHz ≤ f_nom ≤ 13.0 MHz 13.0 MHz < f_nom < 20.0 MHz 20.0 MHz ≤ f_nom < 25.0 MHz 25.0 MHz ≤ f_nom < 30.0 MHz 30.0 MHz ≤ f_nom ≤ 60.0 MHz Product name (Standard form) FA-238V Motional resistance 100 Ω Max. 80 Ω Max. 60 Ω Max. 50 Ω Max. 40 Ω Max. 12.000000MHz (TSX-3225) Frequency 16.0 MHz ≤ f_nom < 21.0 MHz 21.0 MHz ≤ f_nom ≤ 48.0 MHz Motional resistance 60 Ω Max. 40 Ω Max. 12.0 +15.0-15.0 -6 Model Frequency Load capacitance(pF) Frequency tolerance(× 10 , +25 °C) In addition to the above mentioned specification item, please specify frequency temperature characteristics and operating temperature range in case of inquiry. External dimensions #1 #2 3.2±0.1 0.7 Max. #1 #2 0.7 #1 #2 C 0.3 Min. 0.8 0.7 0.8 0.9 #4 #3 #2 and #4 are connected to the cover. (Please connect to ground) 1.0 #1 #2 0.9 #4 #3 #3 1.0 Footprint (Recommended) FA-238V / FA-238 (Unit:mm) TSX-3225 2.2 2.2 1.6 1.6 1.15 1.2 1.4 #2 0.6 Max. 1.2 #1 #1 #2 3.2±0.15 0.7 Max. 1.2 #4 Marking #2 Internal connection (TOP VIEW) #4 #3 0.8 0.7 3.2±0.1 #3 #4 2000M E66RA 2.5±0.1 1200M V66RA #3 #4 2.5±0.15 FA-238 #3 #4 #1 (Unit:mm) TSX-3225 2.5±0.1 FA-238V 1.4 PROMOTION OF ENVIRONMENTAL MANAGEMENT SYSTEM CONFORMING TO INTERNATIONAL STANDARDS At Seiko Epson, all environmental initiatives operate under the Plan-Do-Check-Action (PDCA) cycle designed to achieve continuous improvements. The environmental management system (EMS) operates under the ISO 14001 environmental management standard. All of our major manufacturing and non-manufacturing sites, in Japan and overseas, completed the acquisition of ISO 14001 certification. ISO 14000 is an international standard for environmental management that was established by the International Standards Organization in 1996 against the background of growing concern regarding global warming, destruction of the ozone layer, and global deforestation. WORKING FOR HIGH QUALITY In order provide high quality and reliable products and services than meet customer needs, Seiko Epson made early efforts towards obtaining ISO9000 series certification and has acquired ISO9001 for all business establishments in Japan and abroad. We have also acquired ISO/TS 16949 certification that is requested strongly by major automotive manufacturers as standard. ISO/TS16949 is the international standard that added the sector-specific supplemental requirements for automotive industry based on ISO9001. ►Explanation of the mark that are using it for the catalog ►Pb free. ►Complies with EU RoHS directive. *About the products without the Pb-free mark. Contains Pb in products exempted by EU RoHS directive. (Contains Pb in sealing glass, high melting temperature type solder or other.) ►Designed for automotive applications such as Car Multimedia, Body Electronics, Remote Keyless Entry etc. ►Designed for automotive applications related to driving safety (Engine Control Unit, Air Bag, ESC etc ). Notice • • • • • • This material is subject to change without notice. Any part of this material may not be reproduced or duplicated in any form or any means without the written permission of Seiko Epson. The information about applied data, circuitry, software, usage, etc. written in this material is intended for reference only. Seiko Epson does not assume any liability for the occurrence of customer damage or infringing on any patent or copyright of a third party. This material does not authorize the licensing for any patent or intellectual copyrights. When exporting the products or technology described in this material, you should comply with the applicable export control laws and regulations and follow the procedures required by such laws and regulations. You are requested not to use the products (and any technical information furnished, if any) for the development and/or manufacture of weapon of mass destruction or for other military purposes. You are also requested that you would not make the products available to any third party who may use the products for such prohibited purposes. These products are intended for general use in electronic equipment. When using them in specific applications that require extremely high reliability, such as the applications stated below, you must obtain permission from Seiko Epson in advance. / Space equipment (artificial satellites, rockets, etc.) / Transportation vehicles and related (automobiles, aircraft, trains, vessels, etc.) / Medical instruments to sustain life / Submarine transmitters / Power stations and related / Fire work equipment and security equipment / traffic control equipment / and others requiring equivalent reliability. • All brands or product names mentioned herein are trademarks and/or registered trademarks of their respective. Seiko Epson Corporation
33MHZ 3225 无源 价格&库存
很抱歉,暂时无法提供与“33MHZ 3225 无源”相匹配的价格&库存,您可以联系我们找货
33MHZ 3225 无源
  • 1+1.45220
  • 30+1.40213
  • 100+1.30198
  • 500+1.20182
  • 1000+1.15175
