110991191
110991191
    SEEED(矽递科技)
    Sipeed MAix Go Suit for RISC-V AI+IoT边缘计算套件 人工智能
110991191 数据手册
JavaScript seems to be disabled in your browser. For the best experience on our site, be sure to turn on Javascript in your browser. USD Shop Fusion PCB/PCBA Community  What are you looking for? Sign in  Home / Development Platform / Programmer / MicroPython / Sipeed MAix Go Suit for RISC-V AI+IoT Sipeed MAix Go Suit for RISC-V AI+IoT SKU 110991191       Sipeed MAix Go have on board JTAG&UART based on STM32F103C8, I2S Mic, Speaker, RGB LED, Mic array connector, thumbwheel, TF card Slot and lithium battery manager chip with power path management function, all pins out, with standard M12 lens DVP camera. -  Description Documents Learn Reviews FAQS Tips We have released the Sipdeed AI forum area, where we will publish relevant resources from time to time. You are welcome to ask questions and communicate in the forum area. Sipeed MAix: AI at the edge AI is pervasive today, from consumer to enterprise applications. With the explosive growth of connected devices, combined with a demand for privacy/confidentiality, low latency and bandwidth constraints, AI models trained in the cloud increasingly need to be run at the edge. MAIX is Sipeed’s purpose-built module designed to run AI at the edge, we called it AIoT. It delivers high performance in a small physical and power footprint, enabling the deployment of high-accuracy AI at the edge, and the competitive price make it possible embed to any IoT devices. As you see, Sipeed MAIX is quite like Google edge TPU, but it act as master controller, not an accelerator like edge TPU, so it is more low cost and low power than AP+edge TPU solution. MAix's Advantage and Usage Scenarios: MAIX is not only hardware, but also provide an end-to-end, hardware + software infrastructure for facilitating the deployment of customers' AI-based solutions. Thanks to its performance, small footprint, low power, and low cost, MAIX enables the broad deployment of high-quality AI at the edge. MAIX isn't just a hardware solution, it combines custom hardware, open software, and state-of-the-art AI algorithms to provide high-quality, easy to deploy AI solutions for the edge. MAIX can be used for a growing number of industrial use-cases such as predictive maintenance, anomaly detection, machine vision, robotics, voice recognition, and many more. It can be used in manufacturing, on-premise, healthcare, retail, smart spaces, transportation, etc. Sipeed MAix Go development kit MAix Go development board is bigger and better than M1 Dock. Features It is 88x60mm, all pins out, with standard M12 lens DVP camera, and the Camera can be fliped from front to rear! It have on board JTAG&UART based on STM32F103C8, so you can debug M1 without extra Jlink. It have lithium battery manager chip with power path management function, you can use the board with lithium battery and usb power without conflict~ It have I2S Mic, Speaker, RGB LED, Mic array connector, thumbwheel, TF card Slot and so on. This suit include 2.8 inch LCD too, and have an simple case for it. Specification Downloaded from Arrow.com. Master module Sipeed M1W AIOT module GPIO interface All GPIOs connected to header 2*20 2.54mm Micro SD card(TF card) slot Support Self-elastic card holder Onboard MEMS microphone MSM261S4030H0 is an omnidirectional, Bottom-ported, I 2 S digital output MEMS Microphone. It has high performance and Reliability. DVP Camera interface 24P 0.5mm FPC connector LCD interface Maix-LCD board(with Resistive touch screen) is directly connected to the pin header 1 + CN Warehouse Add to Cart RTC Onboard 32.768k crystal connected with STM32F103 Button Three-way dial switch and one Reset push button Digital Triaxial · User selectable range : ±2g, ±4g, ±8g, ±16g Accelerometer · User selectable data output rate · I2C interface · 14 bits resolution · Low power consumption Power management ETA6002(ETA6002 is a single-cell Li-Ion switch-type charging chip with a charging current of 2.5A. It integrates dynamic path management, and the internal path of the switch has an internal resistance of only 50mohm, allowing the system to remain in the adapter without the battery) Battery path and USB path can be switched automatically MAix's CPU In hardware, MAIX have powerful KPU K210 inside, it offers many excited features: 1st competitive RISC-V chip, also 1st competitive AI chip, newly release in Sep. 2018 28nm process, dual-core RISC-V 64bit IMAFDC, on-chip huge 8MB high-speed SRAM (not for XMR :D), 400MHz frequency (able to 800MHz) KPU (Neural Network Processor) inside, 64 KPU which is 576bit width, support convolution kernels, any form of activation function. It offers 0.25TOPS@0.3W,400MHz, when overclock to 800MHz, it offers 0.5TOPS. It means you can do object recognition 60fps@VGA APU (Audio Processor) inside, support 8mics, up to 192KHz sample rate, hardcore FFT unit inside, easy to make a Mic Array (MAIX offer it too) Flexible FPIOA (Field Programmable IO Array), you can map 255 functions to all 48 GPIOs on the chip DVP camera and MCU LCD interface, you can connect an DVP camera, run your algorithm, and display on LCD Many other accelerators and peripherals: AES Accelerator, SHA256 Accelerator, FFT Accelerator (not APU's one), OTP, UART, WDT, IIC, SPI, I2S, TIMER, RTC, PWM, etc. MAix's Module Inherit the advantage of K210's small footprint, Sipeed MAIX-I module, or called M1, integrate K210, 3-channel DC-DC power, 8MB/16MB/128MB Flash (M1w module add wifi chip esp8285 on it) into Square Inch Module. All usable IO breaks out as 1.27mm(50mil) pins, and pin's voltage is selectable from 3.3V and 1.8V. MAix's SoftWare MAIX support original standalone SDK, FreeRTOS SDK base on C/C++. And we port micropython on it: http://en.maixpy.sipeed.com/. It support FPIOA, GPIO, TIMER, PWM, Flash, OV2640, LCD, etc. And it have zmodem, vi, SPIFFS on it, you can edit python directly or sz/rz file to board. We are glad to see you contribute for it: https://github.com/sipeed/MaixPy //Maixpy project https://github.com/sipeed/MaixPy_Doc_Us_En_Backup //Maixpy wiki project MAix's Deep learning MAIX support fixed-point model that the mainstream training framework trains, according to specific restriction rules, and have model compiler to compile models to its own model format. It support tiny-yolo, mobilenet-v1, and, TensorFlow Lite! Many TensorFlow Lite model can be compiled and run on MAIX! And We will soon release model shop, you can trade your model on it. SOFTWARE FEATURES FreeRtos & Support FreeRtos and Standard SDK Standrad development kit. MicroPython Support MicroPython on M1 Support Machine vision Machine vision based on convolutional neural network Speech High performance Recognition microphone array processor ELECTRICAL SPEC Supply voltage of 4.8V ~ 5.2V external power supply Supply current of >600mA external power supply Temperature rise
110991191 价格&库存
很抱歉,暂时无法提供与“110991191”相匹配的价格&库存,您可以联系我们找货
  • 10000+372.7782010000+48.36767
