107990053
107990053
    SEEED(矽递科技)
    Respeaker Mic array远场麦克风 AI机器人智能语音识别开发板模块
107990053 数据手册
ReSpeaker Mic Array v2.0 ReSpeaker Mic Array v2.0 – Far-field w/ 4 PDM Microphones Product Overview The ReSpeaker Mic Array v2.0 is an upgrade to the original ReSpeaker Mic Array v1. This upgraded version is based on XMOS’s XVF3000, a significantly higher performing chipset than the previously used XVSM2000. This new chipset includes many voice recognition algorithms to assist in performance. The array can be stacked (connected) right onto the top of the original ReSpeaker Core to significantly improve the voice interaction performance. The microphones have also been improved in this version allowing significant performance improvements over the first generation mic array with only 4 microphones. The ReSpeaker Mic Array v2.0 supports USB Audio Class 1.0 (UAC 1.0) directly. All major Operating System, including Windows, macOS, and Linux are compatible with UAC 1.0, allowing the mic array to function as a sound card without the ReSpeaker Core, while also retaining voice algorithms, such as DoA, BF, and AEC on those systems. The ReSpeaker Mic Array v2.0 has two firmware versions available, one including speech algorithms and a second for raw voice data. Key Benefits • Far-field Voice Capture • Support USB Audio Class 1.0 (UAC 1.0) • Four Microphones Array • 12 Programmable RGB LED Indicators • Speech Algorithms and Features • Voice Activity Detection • Direction of Arrival • Beamforming • Noise Suppression • De-reverberation • Acoustic Echo Cancellation The ReSpeaker Mic Array v2.0 is a great solution for those who wish to add voice interface into their existing products or future products. It also works well as an entry point to higher level voice interface evaluation. The board allows some flexibility for customization upon request. Copyright © 2008-2018 Seeed Development Limited All rights reserved 1 ReSpeaker Mic Array v2.0 Hardware Features Applications • XVF-3000 from XMOS • USB Voice Capture • 4 High Performance Digital Microphones • Smart Speaker • Intelligent Voice Assistant Systems • Supports Far-field Voice Capture • Voice Recorders • Speech Algorithms On-Chip • Voice Conferencing System • 12 Programmable RGB LED Indicators • Meeting Communicating Equipment • Microphones: ST MP34DT01TR-M • Voice Interacting Robot • Sensitivity: -26 dBFS (Omnidirectional) • Car Voice Assistant • Acoustic Overload Point: 120 dBSPL • Other Voice Interface Scenarios • SNR: 63 dB • Power Supply: 5V DC from Micro USB or Expansion Header • Dimensions: 70mm (Diameter) • 3.5mm Audio Jack Output Socket Copyright © 2008-2018 Seeed Development Limited All rights reserved 2 ReSpeaker Mic Array v2.0 Hardware Overview Copyright © 2008-2018 Seeed Development Limited All rights reserved 3
107990053 价格&库存
很抱歉,暂时无法提供与“107990053”相匹配的价格&库存,您可以联系我们找货
    库存:46
