Q14 series
-Q
D
IN
LED INDICATORS
03
19
14
Ø14 mm panel mount LED indicators
DISTINCTIVE FEATURES
10 mm colored diffused epoxy lens or 10 mm water clear
super bright LEDs
Prominent and flush bezel styles
(2.8 x 0.8) solder lug/faston terminals, pins or (200 mm long)
wire terminations
Custom engraving available
Available in RGB
ENVIRONMENTAL SPECIFICATIONS
• IP67 sealing option (EN60529)
• Operating & Storage Temperature Range:
Rear plastic body: -30 °C to +65° C ( -22 °F to +149 °F)
Rear epoxy body: -40 °C to +85° C ( -40 °F to +185 °F)
GENERAL SPECIFICATIONS
• Max Reverse Voltage: 5 V
• Viewing Angle: 30–100° (dependant on model)
• Life Expectancy: 100,000 hours
• Torque: 75 cNm
• Maximum panel thickness 11 mm
MATERIALS
• Plated brass bezel finished in bright chrome, black or satin
grey and moulded polycarbonate rear body
MOUNTING
The company reserves the right to change specifications without notice.
All LED characteristics are dependent upon environmental conditions. Therefore published data
should be considered nominal and subject to variations.
1
ELECTRICAL SPECIFICATIONS
Voltage
STANDARD LED INTENSITY
LED COMPONENT SPECIFICATIONS
Operating Voltage
Operating Current
(Min to Max)
(Typical All
Types)
Prominent and
Recessed
Flush
Forward Voltage
02 (No Resistor)
1.8 to 3.3 VDC
20 mA max
HE Red
80 mcd
10 mcd
2.0 V
6 VDC
5.4 to 6.6 VDC
20 mA
Green
60 mcd
5 mcd
2.2 V
12 VDC
10.8 to 13.2 VDC
20 mA
24 VDC
21.6 to 26.4 VDC
20 mA
Yellow
50 mcd
4 mcd
2.1 V
Blue
540 mcd
100 mcd
3.3 V
White
1000 mcd
150 mcd
3.3 V
Orange
80 mcd
200 mcd
2.2 V
Bi-color (Typical)
(Red/Green)
15/15 mcd
14/10 mcd
2.0V/2.2 V
Tri-color (Typical)
(Red/Green/Yellow)
60/50/50mcd
15/10/30 mcd
2.0 V/2.2 V/2.1 V
Bi-color - The color is changed by reversing the polarity of the supply voltage.
Tri-color - The indicator has red and green LEDs, when both connected yellow is
produced.
28 VDC
25.2 to 30.8 VDC
20 mA
110 VAC
99 to 121 VAC
6 mA
220 VAC
207 to 235 VAC
3 mA
* Customer to supply resistor for desired operating
current.
ADDITIONNAL INFORMATION ON LED COMPONENTS
• The operating voltage must not be exceeded by
more that 10% as this will result in reduced life
expectancy
SUPER BRIGHT LED INTENSITY
Prominent and
Recessed
Flush
Forward Voltage
HE Red
17,000 mcd
2,000 mcd
2.2 V
Green
11,000 mcd
680 mcd
3.3 V
Yellow
4,000 mcd
350 mcd
2.0 V
Blue
2,500mcd
250 mcd
3.3 V
White
4,400 mcd
250 mcd
3.3 V
Orange
2,800 mcd
300 mcd
2.2 V
• Luminous intensity is measured at 20 mA on a
discrete led unless otherwise stated.
• Luminous intensities and color shades of white
LEDs may vary within a batch.
• Luminous intensity will be reduced with lower
operating current.
CONNECTIONS
HYPER BRIGHT LED INTENSITY
REAR EPOXY WIRES FOR RGB OPTION
Flush
Forward Voltage
2,800 mcd
800 mcd
2.1 V
Green
2,200 mcd
250 mcd
3.2 V
Yellow
1,300 mcd
250 mcd
2.0 V
Orange
850 mcd
200 mcd
2.1 V
4.75
0.187
RGB LED INTENSITY
ITEM
DC Forward Voltage
Luminous Intensity
2
BLACK ANODE +VE
RED CATHODE -VE
GREEN CATHODE -VE
BLUE CATHODE -VE
13.0
0.512
HE Red
M14 x 1.0 THREAD
Prominent and
Recessed
16.0
0.630
LED INDICATORS
Q14 series
13.5
0.531
17.5
0.689
SYMBOL
CONDITION
TYP.
VF(R)
IF=20 mA
2.1
VF(B/G)
IF=20 mA
2.1
Iv (Red)
220 mdc
Iv (Green)
500 mdc
Iv (Blue)
100 mdc
210
190
8.268
7.480
BUILD YOUR PART NUMBER
Q
SERIES
TERMINALS
MOUNTING HOLE
14
Ø14mm
BEZEL STYLE
P
Prominent
R
Recessed
F
Flush
1
Solder Lug/
Fastons (2.8 x 0.8)
2
Pins
3
Wires
4
Rear epoxy Pins
BEZEL FINISH
5
Rear epoxy Wires
6
Short body Pins
7
Short body Wires
XX
Fixed Light
R
Red
KK
Flashing Light
(12V – 28VDC)
G
Green
YY
Bi-color
Y
Yellow
ZZ
Tri-color
B
Blue
W
White
O
Orange
HR
Hyper Bright
Red
Red
C
Bright Chrome
AG
Green
B
Black
AY
Yellow
G
Satin Grey
AB
Blue
AN
Black
02
no resistor
06
6 VDC
12
12 VDC
HG
Hyper Bright
Green
SB
Super Bright
Blue
HY
Hyper Bright
Yellow
SW
Super Bright
White
HO
Hyper Bright
Orange
RG
Red/Green
RY
12A
Red/Yellow
GY
24
Green/Yellow
SR
Super Bright
Red
SG
Super Bright
Green
RYG
Red/Yellow/
Green
SY
Super Bright
Yellow
RGB
Red/Green/
Blue*
* Terminals option 5 and
common anode only
ABOUT THIS SERIES
24A
28
OTHERS
AR
VOLTAGE
LED COLOR
TYPE OF ILLUMINATION
ANODIZED
FLUSH
12 VAC/DC
24 VDC
24 VAC/DC
SEALING
(Blank)
E
(Blank)
-CA
Unsealed
IP67
Common cathode
Common anode
28 VDC
28A
28 VAC/DC
110
110 VAC
220
220 VAC
Notice: please note that not all combinations of above numbers are available.
• Gold faston terminal denotes anode (+), silver terminal denotes
cathode (-)
• Take care when soldering to the faston terminals (recommended
solder temperature 300 °C - 3 sec)
• Standard wire length is 200 mm, 22 AWG UL1061, red wire
denotes anode (+), black wire denotes cathode (-) for other wire
lengths consult APEM
• Short body pins and wires are only available up to 28 VDC
• For LEDs with alternative voltages and mutlit-voltage options
consult APEM
• Standard tri-color faston terminals are two anodes (+) and one
cathode (-)
• 110 VAC and 220 VAC, short body terminal options, 5, 6 and 7
please consult the factory
• Bi-color leds, by connecting the gold faston (+) one color
is produced, by reversing the supply voltage another color is
produced – bi-colors are available up to 28 VDC
• The Tri-color LED has red and green LEDs when both are
connected yellow is produced
• Tri-color wires are one red (+) and one green (+) anode and one
black (-) cathode
• Tri-color pins are center (–) cathode, shortest (+) anode pin
green, longest (+) anode pin red
• We recommend using Hyperbright or Superbright LEDs for use
at 110 VAC and 220 VAC
3
LED INDICATORS
Q14 series
LED INDICATORS
Q14 series
PROMINENT BEZEL
SOLDER LUG/FASTON
WIRES
PINS
REAR EPOXY WIRES
REAR EPOXY PINS
SHORT BODY WIRES
SHORT BODY PINS
4
FLUSH BEZEL
SOLDER LUG/FASTON
WIRES
PINS
REAR EPOXY WIRES
REAR EPOXY PINS
SHORT BODY WIRES
SHORT BODY PINS
5
LED INDICATORS
Q14 series
LED INDICATORS
Q14 series
RECESSED BEZEL
SOLDER LUG/FASTON
WIRES
PINS
REAR EPOXY WIRES
REAR EPOXY PINS
SHORT BODY WIRES
SHORT BODY PINS
6
CUSTOM ENGRAVING
Some common codes are listed above, for your custom requirements please contact APEM.
Unless specified standard engraving with white infill will be supplied.
Suffix the part number with legend code :
High beam
-0AJ
Low beam
-097
Rear fog
-027
Front fog
-026
Windscreen
wiper
-021
Windscreen
washer
-022
Ventilator
fan
-023
Turn Signal
-0AH
Side lights
-098
Horn
-041
Hazard
warning
-013
Heating
-018
Brake test
-0BU
Arrow
-0K6
USB
connection
-0UB
ABS
Battery
-0AG
Oil can
-0GP
Windscreen
heating
-020
ABS
-086
Engine coil
-0EL
Seat belt
-0SB
Side step
-0AD
Air con
-012
Engine
-040
Boot/Trunk
Release
-0BR
ECU
Steam
-0ST
ECU
-0EU
CABLE LENGTH AND CONNECTOR
For custom cable length and
connectors contact APEM.
7
LED INDICATORS
Q14 series
很抱歉,暂时无法提供与“Q14P1CXXR12E”相匹配的价格&库存,您可以联系我们找货
