ASPHSPH24K152
ASPHSPH24K152
    JST
    Dupont Line
    杜邦线 163.8mm Black 163.80mm
ASPHSPH24K152 数据手册
THIS DRAWING CONTAINS INFORMATION THAT IS PROPRIETARY TO J.S.T. AND SHALL NOT BE USED OR SHOWN WITHOUT WRITTEN PERMISSION. 4 ITEM 3 CONNECTOR PART NO. 2 IPI CHECK DESCRIPTION 1 SPH-002T-P0.5S PH CONNECTOR CONTACT 2 UL1007, 24 AWG BLACK 1 EOR CHECK Applicable Tooling APPLICATOR Applicable Housings D C (163.8 +/- 5.0) 152.4 +/- 5.0 1 1 2 NO. OF CIRCUITS 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 HOUSING PART NO. PHR-2 PHR-3 PHR-4 PHR-5 PHR-6 PHR-7 PHR-8 PHR-9 PHR-10 PHR-11 PHR-12 PHR-13 PHR-14 PHR-15 PHR-16 B D C B Electrical Specifications Current: 2.0A AC/DC Voltage: 100V AC/DC SCALE 1: 1 DIMENSIONS DESCRIPTION All dimensions are in MM with a tolerance of +/- 3.0 unless otherwise specified. A DRAWN BY 1 Add electrical specifications REV. 7/2/2018 DESCRIPTION 4 DATE 3 SP 2.0 mm Pitch PH Series Standard Leads - 6" Inside Length DOUBLE-END LEADS ASSEMBLY PART NO. STEVEN PILKINGTON BY CHECK ED BY ASPHSPH24K152 DRAWING NO. JUSTIN BAKER 2 DATE GAM-059 3/8/2016 1 A
ASPHSPH24K152 价格&库存
很抱歉,暂时无法提供与“ASPHSPH24K152”相匹配的价格&库存,您可以联系我们找货
ASPHSPH24K152
    库存:2000
