ULN2003/ULN2004
ULN2003/ULN2004 Seven Darlington array
Features
Seven Darlingtons per package
Output current 500 mA per driver (600 mA
peak)
Output voltage 50 V
Integrated suppression diodes for inductive
loads
Outputs can be paralleled for higher current
TTL/CMOS/PMOS/DTL compatible inputs
Inputs pinned opposite outputs to simplify
layout
DIP-16
SOP-16
(Narrow)
These versatile devices are useful for driving a
wide range of loads including solenoids, relays
DC motors, LED displays filament lamps, thermal
printheads and high power buffers.
Description
The ULN2003A/2004A are
supplied in 16 pin plastic DIP packages with a
copper leadframe to reduce thermal resistance.
They are available also in small outline package
(SOP-16) as ULN2003D/2004D
The ULN2003, ULN2004,
are high voltage, high current Darlington
arrays each containing seven open collector
Darlington pairs with common emitters. Each
channel rated at 500 mA and can withstand peak
currents of 600 mA. Suppression diodes are
included for inductive load driving and the inputs
are pinned opposite the outputs to simplify board
layout.
Pin configuration
The versions interface to all common logic
families:
– ULN2003 (5 V TTL, CMOS)
– ULN2004 (6 - 15 V CMOS, PMOS)
(top view)
http://www.hgsemi.com.cn
1
2018 AUG
ULN2003/ULN2004
Diagram
Schematic diagram
ULN2003 (each driver)
ULN2004 (each driver)
2
2018 AUG
ULN2003/ULN2004
Maximum ratings
Absolute maximum ratings
Symbol
Parameter
Value
Unit
VO
Output voltage
50
V
VI
Input voltage (for ULN2003A/D - 2004A/D )
30
V
IC
Continuous collector current
500
mA
IB
Continuous base current
25
mA
TA
Operating ambient temperature range
- 40 to 85
°C
Storage temperature range
- 55 to 150
°C
150
°C
TSTG
TJ
Junction temperature
Thermal data
Symbol
RthJA
Parameter
Thermal resistance junction-ambient, Max.
3
DIP-16
SO-16
Unit
70
120
°C/W
2018 AUG
ULN2003/ULN2004
Electrical characteristics
TA = 25 °C unless otherwise specified.
Symbol
ICEX
Parameter
Output leakage current
Collector-emitter saturation
VCE(SAT)
voltage (Figure 3. )
II(ON)
Input current (Figure 4. )
Test condition
Min.
VI(ON)
50
TA = 85°C, VCE = 50 V (Figure 1. )
100
TA = 85°C for ULN2002, VCE = 50 V,
VI = 6 V (Figure 2.)
500
VI = 1V (Figure 2.)
500
IC = 100 mA, IB = 250 µA
0.9
1.1
IC = 200 mA, IB= 350 µA
1.1
1.3
IC = 350 mA, IB= 500 µA
1.3
1.6
for ULN2002, VI = 17 V
0.82
1.25
for ULN2003, VI = 3.85 V
0.93
1.35
for ULN2004, VI = 5 V
0.35
0.5
1
1.45
Input current (Figure 5. )
TA = 85°C, IC = 500 µA
Input voltage (Figure 6.)
VCE= 2 V, for ULN2002
IC = 300 mA
for ULN2003
IC = 200 mA
IC = 250 mA
IC = 300 mA
for ULN2004
IC = 125 mA
IC = 200 mA
IC = 275 mA
IC = 350 mA
hFE
DC Forward current gain
(Figure 3.)
CI
Input capacitance
tPLH
Turn-on delay time
tPHL
Max.
VCE = 50 V, (Figure 1. )
for ULN2001, VCE = 2 V,
IC = 350 mA
Unit
µA
V
mA
VI = 12 V
II(OFF)
Typ.
50
65
µA
13
2.4
2.7
3
V
5
6
7
8
1000
15
25
pF
0.5 VI to 0.5 VO
0.25
1
µs
Turn-off delay time
0.5 VI to 0.5 VO
0.25
1
µs
Clamp diode leakage current
(Figure 7.)
VR = 50 V
50
IR
TA = 85°C, VR = 50 V
100
VF
Clamp diode forward voltage
(Figure 8. )
µA
IF = 350 mA
4
1.7
2
V
2018 AUG
ULN2003/ULN2004
Test circuits
Figure 1. Output leakage currentFigure
Figure 2. Output leakage current
Figure 3.Collector-emitter saturation voltage
Figure 4.Input current (ON)
Figure 5.Input current (OFF)
Figure 6.Input voltage
5
2018 AUG
ULN2003/ULN2004
Figure 7.Clamp diode leakage current
Figure 8.Clamp diode forward voltage
6
2018 AUG
ULN2003/ULN2004
Typical performance characteristics
Figure 10.Collector current vs. saturation
voltage
Figure 9.Collector current vs. saturation
voltage (TJ = 25°C)
I OUT [mA]
85°C
25°C
-30°C
IIN = 500 µA
VCESAT [V]
Figure 11.Input current vs. input voltage
Figure 12.Input current vs. input voltage
(Ta = 25°C)
ULN2003A
Ta = 25°C
ULN2003A
Iout=100 mA
Io ut=200mA
Max
Iou t=300mA
Typ
Min
Figure 13.Collector current vs. input current
Figure 14.h
FE
vs. output current
DC Current Transfer Ratio (hFE)
10000
85 °C
I OUT [mA]
-30 °C
25 °C
VCE = 2 V
VCE = 2 V
85 °C
1000
-40 °C
25 °C
100
10
1
1
IIN [μA]
10
100
1000
Output current IOUT [mA]
7
2018 AUG
ULN2003/ULN2004
Figure 15.Peak collector current vs. duty
cycle (DIP-16)
Ic peak
(mA)
Figure 16.Peak collector current vs. duty
cycle (SO-16)
Ic peak
(mA)
D96IN451
NUMBER OF ACTIVE OUTPUT
7 6 5
500
4
3
2
D96IN452A
Tamb=70°C
(SO16)
500
400
400
2
300
300
Tamb=70°C
(DIP16)
3
5
200
200
7
100
100
40
60
80
DC
8
60
80
100
DC
2018 AUG
很抱歉,暂时无法提供与“ULN2004M/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.10268
- 50+0.85774
- 150+0.75276
- 500+0.62176
- 2500+0.58277
- 5000+0.54778
