Plastic-Encapsulate Transistors
FEATURES
MMBT2907A (PNP)
Epitaxial planar die construction
Complementary NPN Type available(MMBT2222A)
Marking:2F
MAXIMUM RATINGS (TA=25
unless otherwise noted)
Parameter
Symbol
Value
Unit
Collector-Base Voltage
VCBO
-60
V
Collector-Emitter Voltage
VCEO
-60
V
Emitter-Base Voltage
VEBO
-5
V
Collector Current -Continuous
IC
-600
mA
Collector Power Dissipation
PC
250
mW
RθJA
500
℃/W
Junction Temperature
TJ
150
Storage Temperature
Tstg
-55 to +150
Thermal Resistance Junction to Ambient
ELECTRICAL CHARACTERISTICS (Tamb=25
Parameter
1. BASE
2. EMITTER
SOT-23
3. COLLECTO
unless otherwise specified)
Symbol
Test
conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
VCBO
IC=-10μA,IE=0
-60
V
Collector-emitter breakdown voltage
VCEO*
IC=-10mA,IB=0
-60
V
Emitter-base breakdown voltage
VEBO
IE=-10μA,IC=0
-5
V
Collector cut-off current
ICBO
VCB=-50V,IE=0
-20
nA
Base cut-off current
IEBO
VCE=-3V, IC =0
-10
nA
ICEX
VCE=-30 V, VBE(off) =-0.5V
-50
nA
DC current gain
Collector-emitter saturation voltage
Base-emitter saturation voltage
hFE(1)
VCE=-10V,IC=-150mA
hFE(2)
VCE=-10V,IC=-0.1mA
hFE(3)
VCE=-10V,IC=-1mA
100
hFE(4)
VCE=-10V,IC=-10mA
100
hFE(5)
VCE=-10V,IC=-500mA
50
VCE(sat)*
IC=-150mA,IB=-15mA
-0.4
V
VCE(sat)*
IC=-500mA,IB=-50mA
-1.6
V
VBE(sat)*
IC=-150mA,IB=-15mA
-1.3
V
VBE(sat)*
IC=-500mA,IB=-50mA
-2.6
V
Transition frequency
fT
VCE=-20V,IC=-50mA,f=100MHz
Delay time
td
Rise time
tr
Storage time
tS
VCE=-6V,IC=-150mA,
Fall time
tf
IB1=- IB2=- 15mA
100
300
75
200
MHz
10
VCE=-30V,IC=-150mA,B1=-15mA
nS
25
nS
225
nS
60
nS
*Pulse test: tp≤300μS, δ≤0.02.
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P1
MMBT2907A
Typical Characteristics
hFE
Static Characteristic
-0.25
500
—— IC
COMMON EMITTER
VCE=-10V
-800uA
-0.20
400
-720uA
DC CURRENT GAIN hFE
COLLECTOR CURRENT IC (A)
COMMON EMITTER
Ta=25℃
-640uA
-0.15
-560uA
-480uA
-0.10
-400uA
-320uA
-240uA
-0.05
300
Ta=100℃
Ta=25℃
200
100
-160uA
IB=-80uA
-0.00
-0
-2
-4
-6
-8
COLLECTOR-EMITTER VOLTAGE
VCEsat
-0.9
-10
VCE
-12
IC
-10
-100
COLLECTOR CURRENT
IC
VBEsat
IC
-1.2
β=10
-0.6
Ta=100℃
-0.3
Ta=25℃
-0.0
Ta=25℃
-0.8
Ta=100℃
-0.4
-0.0
-1
-10
-100
COLLECTOR CURRENT
IC
IC
-1
-600
(mA)
-10
-100
COLLECTOR CURRENT
—— VBE
Cob/ Cib
100
-600
IC
VCB/ VEB
f=1MHz
IE=0/ IC=0
Ta=25℃
Cib
CAPACITANCE C (pF)
-100
Ta=100℃
-10
Ta=25℃
-1
-0.1
-0.0
-0.2
-0.4
-0.6
-0.8
-1.0
BASE-EMMITER VOLTAGE VBE (V)
Pc
300
-600
(mA)
COMMON EMITTER
VCE=-10V
COLLECTOR CURRENT IC (mA)
-600
(mA)
β=10
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
-1
(V)
Cob
10
1
-0.1
-1
REVERSE VOLTAGE
-10
V
-20
(V)
Ta
COLLECTOR POWER DISSIPATION
Pc (mW)
250
200
150
100
50
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
GUANGDONG HOTTECH
INDUSTRIAL CO., LTD
Page:P2-P2
很抱歉,暂时无法提供与“MMBT2907A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.23320
- 200+0.07777
- 1500+0.04862
- 3000+0.03861
- 国内价格
- 50+0.09800
- 600+0.07665
- 1200+0.07550
- 国内价格
- 50+0.10691
- 500+0.08362
- 3000+0.06936
- 6000+0.06166
- 24000+0.05490
- 51000+0.05130
