BAT54WS
SCHOTTKY BARRIER DIODE
FEATURES
Low Forward Voltage
Fast Switching
Surface Mount device
For Low Current Rectifier Circuits Applications
SOD-323
MECHANICAL DATA
Case: SOD-323
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Moisture Sensitivity: Level 1 per J-STD-020
Weight: 0.005 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Symbol
Value
Unit
Non-Repetitive Peak Reverse Voltage
VRM
30
V
Reverse Voltage
VR
21
V
Forward Current
IF
200
mA
Repetitive Peak Forward Current
IFRM
300
mA
Non-Repetitive Peak Forward Surge Current @ t = 8.3 ms
IFSM
0.6
A
Power Dissipation
PD
200
mW
Thermal Resistance From Junction To Ambient
RθJA
500
°C/W
Junction Temperature
TJ
125
°C
Storage Temperature
TSTG
-55 ~+150
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol
V(BR)
Reverse breakdown voltage
Forward voltage
VF
IR
Reverse voltage leakage current
CD
Diode capacitance
Trr
Reverse recovery time
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
Min
30
Max
1000
2
10
5
Unit
V
mV
uA
pF
nS
IR=100uA
Conditions
IF=100mA
VR=25V
VR=1V,f=1MHz
I F=IR=10mA Irr=0.1×IR RL=100Ω
E-mail:hkt@heketai.com
1/4
BAT54WS
Typical Characteristics
Forward Characteristics
200
Reverse Characteristics
100
Pulsed
Pulsed
(uA)
T=
a 2
5℃
FORWARD CURRENT
10
REVERSE CURRENT IR
a
T
IF
=1
00
(mA)
100
1
0.1
400
FORWARD VOLTAGE
600
VF
Ta=25℃
0.1
(mV)
5
10
15
REVERSE VOLTAGE
Capacitance Characteristics
0.01
800
Ta=100℃
10
25
VR
30
(V)
Power Derating Curve
250
(mW)
f=1MHz
200
PD
16
12
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
Ta=25℃
8
4
10
REVERSE VOLTAGE
15
VR
(V)
100
50
50
75
AMBIENT TEMPERATURE
100
Ta
125
2/4
BAT54WS
SOD-323 Package Outline Dimensions
Symbol
Dimensions In Millimeters
Min.
Dimensions In Inches
Max.
A
Min.
Max.
1.000
0.039
A1
0.000
0.100
0.000
0.004
A2
0.800
0.900
0.031
0.035
b
0.250
0.350
0.010
0.014
c
0.080
0.150
0.003
0.006
D
1.200
1.400
0.047
0.055
E
1.600
1.800
0.063
0.071
E1
2.250
2.750
0.100
0.108
L
0.475 RE F
0.019 REF
L1
0.250
0.400
0.010
0.016
θ
0°
8°
0°
8°
SOD-323 Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
BAT54WS
SOD-323 Tape and Reel
SOD-323 Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SOD-323
1.48
3.3
1.25
Ø1.50
1.75
3.50
4.00
4.00
2.00
8
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SOD-323 Tape Leader and Trailer
SOD-323 Reel
REEL OPTION
7’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø178
54.40
13.00
R78
R25.60
R6.50
9.50
12.30
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“BAT54WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.21340
- 200+0.07117
- 1500+0.04455
- 3000+0.03531
- 国内价格
- 50+0.09292
- 600+0.07232
- 1200+0.07124
- 3000+0.06094
- 国内价格
- 50+0.09960
- 500+0.07740
- 3000+0.06520
- 6000+0.05780
- 24000+0.05160
- 51000+0.04810
- 国内价格
- 50+0.10137
- 500+0.07890
- 3000+0.06649
- 6000+0.05899
- 24000+0.05254
- 51000+0.04905
