SS22F-SS2200F
SCHOTTKY BARRIER RECTIFIER
FEATURES
For surface mounted applications
Metal silicon junction, majority carrier conduction
Built-in strain relief, ideal for automated placement
Low power loss, high efficiency.
High forward surge current capability
SMAF
Plastic package has Underwriters Laboratory
Flammability Classification 94V-0
10
MECHANICAL DATA
Cathode
Case: SMAF Molded plastic
Terminals: Pure tin plated, lead free
Polarity: Indicated by cathode band
Weight: 27mg
(approx.)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating at 25°C ambient temperature unless otherwise specified. Single phase, half wave ,60Hz, resistive or
inductive load.For capacitive load, derate current by 20%
Parameter
Symbol
SS
22F
SS
23F
SS
24F
SS
25F
SS
26F
SS
28F
SS
210F
SS
2150F
SS
2200F
Unit
Maximum Repetitive Peak Reverse Voltage
VRRM
40
50
60
80
100
150
200
V
Maximum RMS Voltage
VRMS
14
21
28
35
42
56
70
105
140
V
Maximum DC Blocking Voltage
VDC
40
50
60
80
100
150
200
V
Maximum Average Forward Rectified Current
IF(AV)
2.0
A
Peak Forward Surge Current 8.3 ms Half
Sine-wave Superimposed on Rated Load
(JEDEC method)
IFSM
50.0
A
Maximum Instantaneous Forward Voltage at 2A
VF
Maximum DC Reverse Current
Cat Rated DC Blocking
Voltage
IR
@ TA =25°C
@ TA =100°C
0.55
0.70
0.85
0.5
Typical Junction Capacitance(Note1)
Cj
Typical Thermal Resistance (Note2)
RθJA
Operating Temperature Range
Storage Temperature Range
10.0
5.0
220
180
0.95
V
0.2
mA
2.0
mA
pF
75.0
°C/w
TJ
-50 to +150
°C
TSTG
-50 to +150
°C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
E-mail:hkt@heketai.com
1/3
SS22F-SS2200F
2.0
1.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
0.8
SS22F-SS26F
SS28F-SS2200F
0.4
50
75
100
125
150
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
50
40
30
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
TJ=25 C
10.0
1
SS22F-SS24F
SS25F-SS26F
SS28F-SS2150F
SS2200F
0.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.4
0.6
0.8
1.0
1.2
1.4
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
1000
TJ=25 C
100
SS22F-SS24F
SS25F-SS2200F
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
1.6
TRANSIENT THERMAL IMPEDANCE,
C/W
0.01
100
NUMBER OF CYCLES AT 60 Hz
50
JUNCTION CAPACITANCE, pF
10
AMBIENT TEMPERATURE, C
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
CURRENT,AMPERES
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Typical Characteristics
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
0.01
0.1
1
10
100
t,PULSE DURATION,sec.
2/3
SS22F-SS2200F
SMAF Package Outline Dimensions
∠ALL ROUND
C
A
∠ALL ROUND
HE
E
A
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.1
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
43
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
g
pad
E
e
A
pad
D
V M
7°
3/3
很抱歉,暂时无法提供与“SS24F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.21115
- 50+0.17185
- 150+0.15001
- 500+0.13687
- 3000+0.11738
- 6000+0.11122
- 国内价格
- 20+0.19355
- 300+0.13750
- 1200+0.12546
- 3000+0.10759
- 国内价格
- 1+0.33220
- 200+0.11000
- 1500+0.06908
- 3000+0.05478
- 国内价格
- 5+0.08970
- 50+0.08320
- 150+0.07890
- 500+0.07560
- 3000+0.06810
