SS12-SS120
SCHOTTKY BARRIER RECTIFIER
FEATURES
For surface mounted applications
Metal silicon junction, majority carrier conduction
Built-in strain relief, ideal for automated placement
Low power loss, high efficiency.
High forward surge current capability
DO-214AC (SMA)
Plastic package has Underwriters Laboratory
Flammability Classification 94V-0
MECHANICAL DATA
10
Case: DO-214AC (SMA)Molded plastic
Terminals: Pure tin plated, lead free
Cathode
Polarity: Indicated by cathode band
Weight: 0.064 gram(approx.)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating at 25°C ambient temperature unless otherwise specified. Single phase, half wave ,60Hz, resistive or
inductive load.For capacitive load, derate current by 20%
Parameter
Symbol
SS
12
SS
13
SS
14
SS
15
SS
16
SS
18
SS
110
SS
115
SS
120
Unit
Maximum Repetitive Peak Reverse Voltage
VRRM
40
50
60
80
100
150
200
V
Maximum RMS Voltage
VRMS
14
21
28
35
42
56
70
105
140
V
Maximum DC Blocking Voltage
VDC
40
50
60
80
100
150
200
V
Maximum Average Forward Rectified Current
IF(AV)
1.0
A
Peak Forward Surge Current 8.3 ms Half
Sine-wave Superimposed on Rated Load
(JEDEC method)
IFSM
30.0
A
Maximum Instantaneous Forward Voltage at 1A
VF
Maximum DC Reverse
Current Cat Rated DC
Blocking Voltage
IR
@ TA =25°C
@ TA =100°C
0.45
0.55
0.70
0.85
0.5
Typical Junction Capacitance(Note1)
Cj
Typical Thermal Resistance (Note2)
RθJA
Operating Temperature Range
Storage Temperature Range
10.0
5.0
110
90
0.95
V
0.2
mA
2.0
mA
pF
88
°C/w
TJ
-50 to +150
°C
TSTG
-50 to +150
°C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
©GUANGDONG HOTTECH INDUSTRIAL CO.,LTD
E-mail:hkt@heketai.com
1/3
SS12-SS120
1.0
0.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.6
0.4
SS12-SS16
SS18-SS120
0.2
50
75
100
125
150
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
24
18
12
6
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
50
TJ=25 C
10.0
1
SS12-SS14
SS15-SS16
SS18-SS115
SS120
0.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.01
100
NUMBER OF CYCLES AT 60 Hz
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
CURRENT,AMPERES
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Typical Characteristics
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
0.4
0.6
0.8
1.0
1.2
1.4
1.6
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
400
200
TJ=25 C
SS12-SS14
SS15-SS120
2
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
TRANSIENT THERMAL IMPEDANCE,
C/W
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
100
t,PULSE DURATION,sec.
2/3
SS12-SS120
SMA Package Outline Dimensions
10
52
4.50
7
( DIMENSIONS ARE IN MILLIMETER )
SMA Embossed Carrier Tape
P0
P1
d
E
MAX.3°
A
MAX.3°
T
F
W
C
B
R
A
P
DIMENSIONS
ARE
IN
MILLIMETER
TYPE
A
B
C
d
E
F
P
P0
P1
T
W
SMA
3.0
5.4
2.4
1.5
1.5
5.65
4
4
2
0.3
12
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.05
±0.1
±0.1
±0.1
±0.05
±0.2
SMA Reel
D2
D
W1
DIMENSIONS
REEL OPTION
D1
ARE
IN
MILLIMETER
D
D1
D2
W1
7’’ DIA
178
50 min.
13
16.8
TOLERANCE
±2
±0.1
±0.5
±2
3/3
很抱歉,暂时无法提供与“SS110”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12580
- 200+0.11610
- 600+0.10640
- 3000+0.09670
- 国内价格
- 20+0.12433
- 200+0.12247
- 800+0.09998
- 2000+0.07909
- 10000+0.07091
- 20000+0.06386
- 国内价格
- 50+0.13564
- 500+0.10907
- 2000+0.08629
- 4000+0.07736
- 24000+0.06967
- 50000+0.06557
