SS210
SS210
    HOTTECH(合科泰)
    SMA(DO-214AC)
    肖特基二极管 Single VR=100V IF=2A IR=5mA Cj=180pF SMA
SS210 数据手册
Plastic-Encapsulate Diodes SCHOTTKY DIODES SS22---SS2200 FEATURES Metal silicon junction, majority carrier conduction 52 0 32 Low power loss, high efficiency The plastic package carries Underwriters Laboratory flammability 7 4.50 Classification 94V-0 High forward surge current capability Built-in strain relief, ideal for automated placement MECHANICAL DATA SMA (DO-214AC) molded plastic Polarity: Color band denotes cathode end DO-214AC (SMA) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS O Ratings at 25 C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL(see fig.1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction temperature range Storage temperature range SYMBOLS SS22 SS23 VRRM VRMS VDC 20 14 20 30 21 30 SS24 SS25 SS26 SS28 SS210 SS2150 SS2200 UNITS 40 28 40 50 35 50 60 42 60 80 56 80 100 70 100 150 105 150 200 140 200 VOLTS VOLTS VOLTS I(AV) 2.0 Amps IFSM 50.0 Amps VF 0.85 0.5 IR CJ RθJA TJ, TSTG 0.70 0.55 10.0 5.0 220 180 75.0 -50 to +125 -50 to +150 -50 to +150 0.95 0.2 2.0 Volts mA pF C/W C C Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas GUANGDONG HOTTECH INDUSTRIAL CO., LTD Page:P2-P1 Plastic-Encapsulate Diodes SS22---SS2200 Typical Characteristics GUANGDONG HOTTECH INDUSTRIAL CO., LTD Page:P2-P2
SS210
物料型号:文档列出了SS22至SS2200的型号。
器件简介:肖特基二极管具有金属硅结、多数载流子导电、低功耗、高效率等特点。塑料封装符合UL94V-0的阻燃等级,具有高正向浪涌电流能力,内置的应变缓解适合自动化安装。
引脚分配:极性由色带表示,阴极端有色带。
参数特性:包括最大重复峰值反向电压(VRRM)、最大RMS电压(VRMS)、最大直流阻断电压(Voc)、最大平均正向整流电流(I(AV))、峰值正向浪涌电流(IFSM)、最大瞬时正向电压(VF)、最大直流反向电流(IR)、典型结电容(CJ)和典型热阻(ROJA)。
功能详解:文档提供了正向电流降额曲线、最大可承受正向浪涌电流曲线、典型瞬时正向电压特性、典型反向特性、典型结电容和典型瞬态热阻抗等图表。
应用信息:文档没有明确提供应用信息,但根据器件的特性,可以推断这些肖特基二极管适用于需要高效率和高浪涌电流能力的电路。
封装信息:封装类型为SMA (DO-214AC),尺寸数据以英寸和毫米提供。
SS210 价格&库存
很抱歉,暂时无法提供与“SS210”相匹配的价格&库存,您可以联系我们找货
SS210
  • 5+0.13941
  • 20+0.12711
  • 100+0.11481
  • 500+0.10250
  • 1000+0.09676
  • 2000+0.09266
库存:2664
