规 格 承 认 书
SPECIFICATION FOR APPROVAL
产 品 名 称:
Product
Name:
产 品 型 号:
Product
Type:
产 品 编 码:
Product
Code:
客 户 名 称:
Customers Name:
客 户 编 码:
Customers Code:
日
期:
Issue
Date:
金属化聚酯膜介质电容器
Metallized polyester film dielectric capacitor
CL21
CL21
深圳华秋电子有限公司
2019.07.31
2019.07.31
浙江七星电子股份有限公司
Zhejiang Qixing Electronics Corp ., Ltd.
地址:中国浙江省长兴县煤山镇发展大道 50 号
No. 50, Development Avenue,Meishan Town, Changxing County, Zhejiang Province , P.R.China
Tel:0572-6295698
Fax:0572-6295700
CL21
CL21 金属化聚酯膜电容器
CL21
Metallized polyester film capacitor
■ Characteristic:
● Small size, Light weight.
●Excellent self-healing property and reliability.
■ 特点
● 体积小、重量轻
● 自愈性好、可靠性高
■Main purpose
●Bypass, partition, coupling, decoupling.
●Pulse, logic, timing, compact CFL.
●LCD monitor rectification, automotive DC
motor suppression interference
■主要用途
● 旁路,隔直,耦合,退耦
● 脉冲,逻辑,定时,紧凑型节能灯
●LCD 监视器整流,汽车直流马达抑制干扰
■ 技术要求 Technical requirements
引用标准 Reference criteria
GB/T 7332〔IEC 60384-2〕
气候类别 Climate category
55/125/21
额定温度 Rated temperature
85℃
工作温度 Operating temperature
-55℃~125℃
额定电压 Rated voltage
50/63v;100v;250v;400v;630V;1000V;1250
电容量范围 Electricity capacity range
0.010μF~10.0μF
电容量偏差 Capacitance deviation
±5%〔J〕,±10%〔K〕,±20%〔M〕
耐电压 Voltage resistance
1.4Ur 〔2s〕
〔+85℃to+125℃:decreasing factor 1.25% per℃ for Ur(dc) 〕
频率 Frequency
损耗角正切值 Loss angle tangent
Cn≤0.1μF
C>0.1μF
1KHz
tgδ≤0.0080
tgδ≤0.010
10KHz
tgδ≤0.0120
tgδ≤0.015
Ur≤100V
绝缘电阻 Insulation resistance
Ur>100V
最大脉冲爬升:
Maximum Pulse Climbing Rate:
若实际工作电压 U 比额定电压 Ur 低,电容器可工
作在更高的 dv/dt 场合,这样 dv/dt 允许值应为右表
值 乘 以 Ur/U
If the actual working voltage U is
lower than the rated voltage Or, the capacitor can work
in a higher dv/dt case so that the dv/dt allowed value
should be multiplied by the right table value Ur/U
Ur〔V〕
+25±5℃ 10V
1min
R≥15000MΩ
Cn≤0.33μF
IR≥5000S
Cn>0.33μF
IR≥1000S
Cn=1~2.2μF
R≥30000 MΩ
Cn≤0.33μF
IR≥10000S
Cn>0.33μF
+25±5℃ 100V
1min
dV/dt〔V/μs〕
P=7.5
P=10
P=15
P=22.5
P=27.5
50/63V
7.5
6
3
2
100V
15
9
5
3
250v
30
8
5
400V
40
30
7
630V
40
25
12
10
1000V
70
60
30
15
12
1250V
80
70
40
18
14
1
CL21
■电容器外形尺寸 Capacitor dimensions
50V/63V〔40VAC〕
电容
量
CAP
电容器外形尺寸 Capacitor
dimensions
100V〔63VAC〕
电容量
电容器代码
Part number
T
H
W
P
Φd
0.12
4.0
7.0
9.8
7.5
0.6
L210063V124****
0.15
4.1
7.8
9.8
7.5
0.6
0.33
4.1
7.7
9.8
7.5
0.39
4.3
8.0
9.8
0.47
4.1
7.7
0.56
4.4
0.82
CAP
电容器外形尺寸 Capacitor
dimensions
电容器代码
Part number
T
H
W
P
Φd
0.12
4.0
7.0
9.8
7.5
0.6
L210100V124****
L210063V154****
0.15
4.1
7.8
9.8
7.5
0.6
L210100V154****
0.6
L210063V334****
0.22
4.1
7.8
9.8
7.5
0.6
L210100V224****
7.5
0.6
L210063V394****
0.27
4.0
7.0
9.8
7.5
0.6
L210100V274****
9.8
7.5
0.6
L210063V474****
0.33
4.1
7.7
9.8
7.5
0.6
L210100V334****
8.0
9.8
7.5
0.6
L210063V564****
0.39
4.3
8.0
9.8
7.5
0.6
L210100V394****
5.1
8.7
9.8
7.5
0.6
L210063V824****
0.47
4.6
8.3
9.8
7.5
0.6
L210100V474****
1.0
4.8
8.4
12.3
10.0
0.6
L210063V105****
0.56
5.0
8.6
9.8
7.5
0.6
L210100V564****
1.2
5.1
8.8
12.3
10.0
0.6
L210063V125****
0.68
5.4
9.0
9.8
7.5
0.6
L210100V684****
1.5
5.6
9.3
12.3
10.0
0.6
L210063V155****
0.82
5.0
8.7
12.3
10.0
0.6
L210100V824****
1.8
6.1
9.7
12.3
10.0
0.6
L210063V185****
1.0
5.5
9.1
12.3
10.0
0.6
L210100V105****
2.2
5.9
9.6
17.5
15.0
0.6
L210063V225****
1.2
5.9
9.5
12.3
10.0
0.6
L210100V125****
2.7
6.4
10.0
17.5
15.0
0.6
L210063V275****
1.5
6.5
10.1
12.3
10.0
0.6
L210100V155****
3.3
6.9
10.6
17.5
15.0
0.6
L210063V335****
1.8
5.7
11.4
17.5
15.0
0.6
L210100V185****
3.9
7.5
11.6
17.5
15.0
0.8
L210063V395****
2.7
6.7
12.4
17.5
15.0
0.6
L210100V275****
4.7
6.2
11.9
25.2
22.5
0.8
L210063V475****
3.3
6.8
14
17.5
15.0
0.6
L210100V335****
5.6
6.7
12.4
25.2
22.5
0.8
L210063V565****
4.7
6.6
13.9
25.2
22.5
0.8
L210100V475****
6.8
7.3
13
25.2
22.5
0.8
L210063V685****
5.6
7.2
14.4
25.2
22.5
0.8
L210100V565****
8.2
8.4
13.6
25.2
22.5
0.8
L210063V825****
6.8
8.3
15.1
25.2
22.5
0.8
L210100V685****
10.0
9.2
14.4
25.2
22.5
0.8
L210063V106****
10.0
9.4
17.7
25.2
22.5
0.8
L210100V106****
250V〔160VAC〕
电容
电容器外形尺寸
量
250V〔160VAC〕
电容量
电容器代码
Part number
CAP
T
H
W
P
Φd
0.010
3.5
6.5
9.8
7.5
0.6
L210250V103****
0.012
3.7
6.7
9.8
7.5
0.6
0.022
3.8
7.4
9.8
7.5
0.039
3.9
7.5
9.8
0.056
4.4
8.0
0.068
3.9
0.082
电容器外形尺寸
CAP
电容器代码
Part number
T
H
W
P
Φd
0.39
5.2
10.4
17.5
15
0.6
L210250V394****
L210250V123****
0.47
5.6
10.8
17.5
15
0.6
L210250V474****
0.6
L210250V223****
0.56
5.5
12.3
17.5
15
0.6
L210250V564****
7.5
0.6
L210250V393****
0.68
6.0
12.8
17.5
15
0.6
L210250V684****
9.8
7.5
0.6
L210250V563****
0.82
6.5
13.8
17.5
15
0.6
L210250V824****
7.5
9.8
7.5
0.6
L210250V683****
1.0
7.1
14.4
17.5
15
0.6
L210250V105****
4.1
7.8
9.8
7.5
0.6
L210250V823****
1.2
7.7
15.0
17.5
15
0.8
L210250V125****
0.10
4.4
8.1
9.8
7.5
0.6
L210250V104****
1.5
9.1
15.9
17.5
15
0.8
L210250V155****
0.12
4.8
8.4
9.8
7.5
0.6
L210250V124****
1.8
9.9
16.2
17.5
15
0.8
L210250V185****
0.15
5.2
8.8
9.8
7.5
0.6
L210250V154****
2.2
8.8
15.6
25.2
22.5
0.8
L210250V225****
0.18
4.5
8.9
12.3
10.0
0.6
L210250V184****
2.7
9.7
16.5
25.2
22.5
0.8
L210250V275****
0.22
4.8
9.3
12.3
10.0
0.6
L210250V224****
3.3
10.6
17.4
25.2
22.5
0.8
L210250V335****
0.27
5.3
9.7
12.3
10.0
0.6
L210250V274****
3.9
10.9
19.2
25.2
22.5
0.8
L210250V395****
0.33
5.5
10.7
12.3
10.0
0.6
L210250V334****
10.0
16
24.4
30.2
27.5
0.8
L210250V106****
2
CL21
400V〔200VAC〕
电容
量
电容器外形尺寸 Capacitor
dimensions
520V〔200VAC〕
电容量
电容器代码
Part number
CAP
T
H
W
P
Φd
0.010
3.9
6.9
9.8
7.5
0.6
L210400V103****
0.015
4.4
7.5
9.8
7.5
0.6
0.022
3.9
7.5
9.8
7.5
0.033
4.5
8.1
9.8
0.047
4.9
8.6
0.068
4.7
0.10
CAP
电容器外形尺寸 Capacitor
dimensions
电容器代码
Part number
T
H
W
P
Φd
0.010
3.6
7.2
9.8
7.5
0.6
L210520V103****
L210400V153****
0.015
3.9
7.5
9.8
7.5
0.6
L210520V153****
0.6
L210400V223****
0.022
4.2
7.7
9.8
7.5
0.6
L210520V223****
7.5
0.6
L210400V333****
0.033
4.9
8.5
12.3
10.0
0.6
L210520V333****
9.8
7.5
0.6
L210400V473****
0.047
5.4
8.9
12.3
10.0
0.6
L210520V473****
9.1
12.3
10.0
0.6
L210400V683****
0.068
5.2
12.8
12.3
10.0
0.6
L210520V683****
5.4
9.9
12.3
10.0
0.6
L210400V104****
0.10
6.0
12.9
17.5
15.0
0.6
L210520V104****
0.15
5.4
10.6
17.5
15.0
0.6
L210400V154****
0.12
6.4
13.2
17.5
15.0
0.6
L210520V124****
0.22
6.3
11.5
17.5
15.0
0.6
L210400V224****
0.15
6.7
13.4
17.5
15.0
0.8
L210520V154****
0.33
7.4
12.7
17.5
15.0
0.6
L210400V334****
0.22
6.9
13.7
17.5
15.0
0.8
L210520V224****
0.47
9.2
14.4
17.5
15.0
0.8
L210400V474****
0.27
7.4
14.3
17.5
15.0
0.8
L210520V274****
0.68
10.8
16.0
17.5
15.0
0.8
L210400V684****
0.39
8.5
15.1
17.5
15.0
0.8
L210520V394****
0.82
11.8
17.0
17.5
15.0
0.8
L210400V824****
0.47
9.5
16.0
25.2
22.5
0.8
L210520V474****
1.2
9.9
18.3
25.2
22.5
0.8
L210400V125****
0.56
10.1
16.7
25.2
22.5
0.8
L210520V564****
1.5
11.0
19.4
25.2
22.5
0.8
L210400V155****
0.68
10.5
17.2
25.2
22.5
0.8
L210520V684****
1.8
10.8
19.1
30.2
27.5
0.8
L210400V185****
0.82
10.8
18.0
25.2
22.5
0.8
L210520V824****
2.7
12.5
22.4
30.2
27.5
0.8
L210400V275****
1.0
11.2
18.8
30.2
27.5
0.8
L210520V105****
3.3
13.9
23.8
30.2
27.5
0.8
L210400V335****
1.5
12.2
20.3
30.2
27.5
0.8
L210520V155****
3.9
15.1
25.1
30.2
27.5
0.8
L210400V395****
1.8
14.5
22.5
30.2
27.5
0.8
L210520V185****
4.7
16.7
26.6
30.2
27.5
0.8
L210400V475****
2.2
16.3
24.5
30.2
27.5
0.8
L210520V225****
630V〔220VAC〕
电容量
CAP
电容器外形尺寸 Capacitor
dimensions
630V﹝220VAC﹞
电容量
电容器代码
Part number
T
H
W
P
Φd
0.010
3.8
7.4
9.8
7.5
0.6
L210630V103****
0.015
4.0
7.7
9.8
7.5
0.6
0.022
4.5
8.2
9.8
7.5
0.033
5.2
8.9
12.3
0.047
6.0
0.068
电容器外形尺寸
CAP
电容器代码
Part number
T
H
W
P
Φd
0.68
11.4
18.2
25.2
15.0
0.8
L210630V684****
L210630V153****
0.82
12.5
19.3
25.2
15.0
0.8
L210630V824****
0.6
L210630V223****
1.0
11.6
19.9
30.2
27.5
0.8
L210630V105****
10.0
0.6
L210630V333****
1.2
12.6
22.0
30.2
27.5
0.8
L210630V125****
9.7
12.3
10.0
0.6
L210630V473****
1.5
14.1
22.5
30.2
27.5
0.8
L210630V155****
7.0
10.7
12.3
10.0
0.6
L210630V683****
1.8
15.5
23.8
30.2
27.5
0.8
L210630V185****
0.10
6.3
11.5
17.5
15.0
0.6
L210630V104****
2.2
17.1
25.5
30.2
27.5
0.8
L210630V225****
0.12
6.8
12.0
17.5
15.0
0.6
L210630V124****
0.15
7.5
12.7
17.5
15.0
0.8
L210630V154****
0.22
9.3
14.5
17.5
15.0
0.8
L210630V224****
0.27
10.2
15.4
17.5
15.0
0.8
L210630V274****
0.39
12.0
17.2
17.5
15.0
0.8
L210630V394****
0.47
9.7
16.4
25.2
22.5
0.8
L210630V474****
0.56
10.5
17.2
25.2
22.5
0.8
L210630V564****
3
CL21
1000V〔250VAC〕
电容
电容器外形尺寸
量
1000V﹝250VAC﹞
电容量
电容器代码
Part number
CAP
T
H
W
P
Φd
0.0010
4.0
8.5
9.8
7.5
0.6
L211000V102****
0.0012
4.3
8.7
9.8
7.5
0.6
0.0015
4.1
8.5
9.8
7.5
0.0018
4.3
8.7
9.8
0.0022
4.1
8.5
0.0027
4.4
0.0033
电容器外形尺寸
CAP
电容器代码
Part number
T
H
W
P
Φd
0.027
5.0
11.8
17.5
15.0
0.6
L211000V273****
L211000V122****
0.033
5.5
12.3
17.5
15.0
0.6
L211000V333****
0.6
L211000V152****
0.039
5.9
12.7
17.5
15.0
0.6
L211000V393****
7.5
0.6
L211000V182****
0.047
6.5
13.2
17.5
15.0
0.8
L211000V473****
9.8
7.5
0.6
L211000V222****
0.056
7.0
13.8
17.5
15.0
0.8
L211000V563****
8.8
9.8
7.5
0.6
L211000V272****
0.068
7.7
14.5
17.5
15.0
0.8
L211000V683****
4.3
8.7
9.8
7.5
0.6
L211000V332****
0.082
8.5
15.2
17.5
15.0
0.8
L211000V823****
0.0039
4.5
8.9
9.8
7.5
0.6
L211000V392****
0.10
9.7
16.6
17.5
15.0
0.8
L211000V104****
0.0047
4.8
9.3
9.8
7.5
0.6
L211000V472****
0.15
9.2
16.2
25.2
22.5
0.8
L211000V154****
0.0056
4.1
8.5
12.3
10.0
0.6
L211000V562****
0.18
10.1
17.1
25.2
22.5
0.8
L211000V184****
0.0068
4.4
8.8
12.3
10.0
0.6
L211000V682****
0.22
11.1
18.1
25.2
22.5
0.8
L211000V224****
0.010
5.0
9.4
12.3
10.0
0.6
L211000V103****
0.27
11.7
20.2
25.2
22.5
0.8
L211000V274****
0.015
5.6
10.8
12.3
10.0
0.6
L211000V153****
0.33
11.6
20.1
25.2
22.5
0.8
L211000V334****
0.022
6.7
11.9
12.3
10.0
0.6
L211000V223****
0.39
12.6
21.2
25.2
22.5
0.8
L211000V394****
1250V〔250VAC〕
电容
量
电容器外形尺寸 Capacitor
dimensions
1250V〔250VAC〕
电容量
电容器代码
Part number
CAP
T
H
W
P
Φd
0.0010
4.0
8.5
9.8
7.5
0.6
L211250V102****
0.0012
4.1
8.7
9.8
7.5
0.6
0.0015
4.1
8.5
9.8
7.5
0.0018
4.3
8.7
9.8
0.0022
4.1
8.5
0.0027
4.4
0.0033
CAP
电容器外形尺寸 Capacitor
dimensions
电容器代码
Part number
T
H
W
P
Φd
0.047
4.0
11.0
25.2
22.5
0.8
L211250V473****
L211250V122****
0.056
4.1
11.4
30.2
27.5
0.8
L211250V563****
0.6
L211250V152****
0.068
4.1
12.0
30.2
27.5
0.8
L211250V683****
7.5
0.6
L211250V182****
0.082
4.0
12.6
30.2
27.5
0.8
L211250V823****
9.8
7.5
0.6
L211250V222****
0.10
4.1
14.8
30.2
27.5
0.8
L211250V104****
8.8
9.8
7.5
0.6
L211250V272****
0.12
4.3
15.4
30.2
27.5
0.8
L211250V124****
5.1
9.1
9.8
7.5
0.6
L211250V332****
0.15
4.6
16.4
30.2
27.5
0.8
L211250V154****
0.0039
4.8
9.4
9.8
7.5
0.6
L211250V392****
0.18
5.0
18.3
30.2
27.5
0.8
L211250V184****
0.0047
5.1
8.7
12.3
10.0
0.6
L211250V472****
0.22
5.4
19.3
30.2
27.5
0.8
L211250V224****
0.0056
5.6
8.9
12.3
10.0
0.6
L211250V562****
0.0068
6.1
9.2
12.3
10.0
0.6
L211250V682****
0.0082
5.9
9.0
17.5
15.0
0.6
L211250V822****
0.010
6.4
9.4
17.5
15.0
0.6
L211250V103****
0.012
6.9
9.1
17.5
15.0
0.6
L211250V123****
0.015
7.5
9.5
17.5
15.0
0.6
L211250V153****
0.018
6.2
9.9
17.5
15.0
0.6
L211250V183****
0.022
6.7
10.3
17.5
15.0
0.6
L211250V223****
0.027
7.3
9.7
25.2
22.5
0.6
L211250V273****
0.033
8.4
10.1
25.2
22.5
0.6
L211250V333****
0.039
9.2
10.5
25.2
22.5
0.8
L211250V393****
4
CL21
■承认规格登记表 Size and specification
●尺寸(mm)(T*H*W)
Wmax---最大宽度
Hmax---最大高度
Tmax---最大厚度
P-----脚距±0.5
L-----脚长±2.0
●.规格 Specification:
序号
NO
客户料号
七星料号
规格型号
Customer NO
Spec NO
Specification
1
21X0250V104K05
BLAY**
CL21X-250V104K
2
21X0400V104K05
BLAY**
3
4
尺寸 Size T*H*W*P
线径
脚长
备注
Line
Length
Note
4.5*8.5*7.2*5.0
0.6
24
CL2X1-400V104K
5.0*10.5*7.2*5.0
0.6
24
21X0250V224K05
BLAY**
CL21X-250V224K
4.8*9.5*7.2*5.0
0.6
24
21X0400V224K05
BLAY**
CL21X-400V224K
6.5*12*7.2*5.0
0.6
24
5
L210250V104J10
BLBY**
CL21-250V104J
5.6*10.5*12.5*10
0.6
24
6
L210400V104J10
BLBY**
CL21-400V104J
5.3*10.5*12.5*10
0.6
24
7
L210250V224J10
BLBY**
CL21-250V224J
7.0*13*12.5*10
0.6
24
8
L210400V224J10
BLBY**
CL21-400V224J
7.5*12.5*12.5*10
0.6
24
9
L210250V474J10
BLBY**
CL21-250V474J
7.3*11.8*12.5*10
0.6
24
10
L210400V474K10
BLBY**
CL21-400V474K
7.5*12.5*12.5*10
0.6
24
5
CL21
■ 电容器编码说明 Capacitor coding specification
● 20 位电容器代码如下:The code of the 20-bit capacitor at the center is as follows:
额定工作电压
Vol tage
0050
50V
标称电容量
Multiplier
0063
63V
102=0.001μF
2
电容器系列代码
Capacitor series
cod
L21 = CL21
引线长
引线间距
S=短脚
Lead long
100V
103= 0.01μF
0250
250V
104= 0.1μF
Pitch
K=成型
C=3.5
0400
400V
105= 1.0μF
05=5.0mm
H=直编
Y=24
0630
630V
106 = 10μF
7A=7.5mm
Q=成型编带
A,B,C
0400
3
L=长脚
0100
L21
1
引线形状
4
5
6
V
7
8
104
9
10
额度频率
Line frequency
K
11
12
7A
13
14
B
S
B
15
16
17
电容量允许偏差
Tolerance
粉包颜色
Powder
color
18
引线直径
Wire diameter
直流
D C
V
F=±1%
B=红色
A=0.5mm
交流 A C
50/60 Hz
A
G=±2%
M=蓝色
B=0.7mm
H=±3%
N=绿色
T=镀锡铜线
电容器型号
TYPE
C
电容器
Caoacit
J=±5%
L
聚酯膜介质
Ployester
K=±10%
2
普通 ordinary
M=±20%
1
径向引线
Radial lead
粉末包封 Powder
coating
6
19
内部
特征
代码
CL21
■特性曲线图 Characteristic curve
电容量随温度变化的曲线﹝1KHz﹞
Is the temperature curve of the capacitance
电容量随频率变化的曲线
Capacitance may vary in frequency
损耗角正切值随温度变化的曲线﹝1KHz﹞
The curve of the tangent of loss Angle with temperature
损耗角正切值随频率变化的曲线
Curve of the change of the tangent value of the loss angle
with frequency
绝缘电阻随温度变化的曲线﹝1KHz﹞
The curve of insulation resistance to temperature
7
CL21
■性能及测试方法 Performance and test methods
No
项目 Item
性能与判据 Performance and criteria
1
电容量允许偏差
Capacitance tolerance
2
损耗角的正切
Tangent of the loss angle
tgδ≤0.010〔1KHz〕
tgδ≤0.015〔10KHz〕
tgδ≤0.030〔100KHz ,100
R≥15000MΩ,Cn≤0.33μF
IR≥5000S
Cn≤0.33μF
R≥5000MΩ,Cn≤0.33μF
IR≥1000S 0.33μF<Cn≤2.2
μF
测试方法 Test method
(IEC60384-2)
典型测量频率:1KHz
Typical measuring
frequency: 1KHz
1.4Ur 2sec
充电电压
Ur≤100V Charging voltage 10v
环境温度 20℃,测量时间 60S
充电电压
Ur>100V Charging voltage 100v
环境温度 20℃,测量时间 60S
锡炉温度 Soldre temperature
5
可焊性
Solder ability
Good quality of tinning
镀锡良好
245℃±5℃
浸渍时间 Immersion time
2.S±0.5S
初始测量 Initial
measurement
引线抗拉强度强度
Terminal strength
电容量与损耗 Capacitance & tgδ
〔10KHz〕
外观无可见损伤
There shall be no visible damage
6
拉力试验 Tension Ual:
拉力 Pull:
φd=0.5mm 5N
φd=0.6mm 10N
弯曲试验 bend Ub:
弯力 The qull of bend
φd=0.5mm 2.5N
φd=0.6mm 5N
端子应向每个方向弯曲 2 次
The terminals shall be bent
2times in each direction
耐焊接热
Resistance to solder heat
无可见损伤
260℃±5℃
浸渍时间 Immersion time
10.S±1S
初始测量
Initial measurement
ΔC/C≤±2%
相对于初始值 Relative to the initial
value.
tgδ≤0.015〔10KHz〕
电容量与损耗
Capacitance & tgδ〔10KHz〕
温度快速变化
Rapid change of temperature
外观无可见损伤
最后的测量
Final measurement
7
8
Θa= -55℃ Θb= +125℃
持续的时间= 30 分钟
5 个周期,
CL21
振动 Vibration
外观无可见损伤
碰撞 Bump
外观无可见损伤
最后的测量
Final measurement
ΔC/C≤±5%
相对于初始值 Relative to the initial value.
tgδ≤0.015〔10KHz〕
IR≥50% 规定值 of the rated value
初始测量
Initial
measurement
Bump times: 4000
Acceleration: 390m/S2
Duration of pulse: 6ms
电容量与损耗
+1250 C
持续 16 小时
+1250 C lasts for 16 hours
试验 Db, 严酷度 b,第一次循环
Test Db,Severity:b,the first cycle
干热
8
5cycles, Duration:=30min
频率:10 ~ 500HZ
振 幅 0.75mm 或 加 速 度 98m/S2
三个方向每个方向各 2h 共 6h
Ferequance10~500HZ
Amplitude0.75m;Acceleration98m/
S2 Amplitude 3 direction 2h per
direction Duration 6h
碰撞次数: 4000 次
加速度: 390m/S2
脉冲持持续时间 : 6ms
Dry heat
循环湿热
Damp
heat ,Cyclic
-55 C 持续 2h
-55 C lasts for 2 hours
寒冷 Cold
气候顺序
低气压
Climate
sequence
Low air pressure
在试验最后 1 分钟施加 Ur 时,不得有永
久性击穿或飞弧及外壳有害变形
There shall be no permanent
down ,flashover or other harmful
deformation when applying Ur at the last
1minute
循环湿热
Damp
heat ,Cyclic
最后的测量
Final
measurement
9
稳态湿热
Damp heat steady state
外观无可见损伤
There shall be no evidence of deformation
ΔC/C≤±5%
tgδ≤0.015〔10KHz〕
外观无可见损伤,标志清晰
And the marking shall be legible
ΔC/C≤±5%
tgδ≤0.015〔10KHz〕
9
150 C~350 C 大气压 8.5kpa
持续 1 小时
The pressure of 150 C~350 C air is
8.5kpa for 1 hour
试验 Db,严酷度:b,其余循环
试验结束后,施加 Ur 1 分钟
Test Db,Severity:b,the other cycles,
Applying Ur for 1minute after the
test finished
试验温度: 40 ± 2℃
相对湿度: 93 ± 2% RH
试验时间: 56 天
Temperature: 40 ± 2℃
Humidity: 93 ± 2% RH
Duration:56days
CL21
10
11
耐久性
Endurance
温度特性
Temperature characteristic
外观无可见损伤,标志清晰
ΔC/C≤±5%
tgδ≤0.015〔10KHz〕
试验温度:+85℃/+125℃±2℃
施加电压: 1.25×UR//1.25Uc
〔Uc=0.5 UR〕
试验时间:1000 h
Temperature: +85℃/+125℃±2℃
Voltage: 1.25×UR//1.25Uc
〔Uc=0.5 UR〕
Duration:1000h
在 b,d,f 点上进行电容量测量
静态方法:电容器应依次保持以下
在下限类别温度-55℃时的特性:
温度:
-10%≤(Cb 一 Cd)/Cd≤+10%
a﹝20±2℃〕,b〔-55±3℃﹞,d﹝20
在上限类别温度+105℃时的特性:
±2℃〕,f﹝+105±3﹞,g〔20±2℃〕
Static method :the Capacitors should
be kept at the following temperature
Measuring capacitance at test point b,d,f:
Characteristic at lower category temperature -55℃ in turn:
Characteristic at upper category temperature ±2℃〕,f﹝+105±3﹞,g〔20±2℃〕
+105℃
ΔC/C≤±5%
tgδ≤0.015〔10KHz〕
12
充放电
Charging and discharging
10
Times:10000
Duration of charging:0.5S
Duration of discharging:0.5S
Charging :rated voltage
Charging resistance: 220/Cr﹝Ω﹞
Discharging resistance:
R=10/Cr﹝Ω﹞or 20Ω
﹝whichever is the greater﹞
Cr: rated capacitance
充放电次数:10000 次
充电持续时间:0.5S
放电持续时间:0.5S
充电电压为额定电压
充电电阻: 220/Cr﹝Ω﹞
放电电阻:R=10/Cr﹝Ω﹞或 20Ω
﹝取较大者﹞
Cr:为标称电容量
CL21
■最大电压﹝Vr.m.s〕/频率表〔正弦波形/环境温度≤40°C﹞
MAX. VOLTAGE (Vr.m.s.) VERSUS FREQUENCY (sinusoidal wave-form / Th≤ 40°C)
Lead spacing 7.5 mm
Lead spacing 10 mm
11
CL21
Lead spacing 15 mm
12
CL21
Lead spacing 22.5 mm
13
CL21
Lead spacing 27.5 mm
14
CL21
15
CL21
■ 产品编带尺寸 Product tape size
● 外形图 The contour map
● 编带尺寸表 Taping Dimensions
名
称
电容器间距
Taping pitch
送带孔距离
Feed hole pitch
电容器与带孔位置
capacitor and hole location
引线直径
Wire diameter
引 出 线
成型间距
电容器侧面倾斜
The capacitor slopes
sideways
载体纸带宽度
Carrier tape width
热熔胶带纸宽度
Hold down tape width
送带孔位置
Hold position
胶带纸位置
Hold down tape sition
引线至孔中心高度
Height of component from
tape center
送带孔直径
Feed hole dia
编带总厚度
Tape thickness
引线剪断高度
Height of lead shearing
代
号
标准尺寸(mm)
允许误差(mm)
P
12.7
±1.0
Po
12.7
±0.3
P1
P2
3.85
6.35
±0.7
±1.3
φd
0.5/0.6
±0.05
F
5.0
+0.6
-0.2
ΔT
±2.0
W
18.0
+1.0
-0.5
W0
12.0
±0.5
W1
9.0
+0.75
-0.5
W2
0~3.0
Ho
16.0
±0.5
Do
φ4.0
±0.3
t
0.7
±0.2
L
≤11
16
CL21
● 径向编带包装箱尺寸 Box sizes for Ammo-pack
A=48±3; B=260±3; C=330±3
■ 波峰焊接 Wave soldering
电容器的内部温度必须
保持如下:
聚 酯: 预热温度+ 125°C
聚丙烯: 预热温度+ 100°C
单波峰焊接
焊接浴温度: T=260°C
停留时间: 5 秒
双波峰焊接
焊接浴温度:T=260°C
停留时间: 5 秒
由于不同的焊接工艺和
热量要求图形仅作为推荐
Internal temperature of the capacitor must
be kept as follows:
Polyester: preheating: T max. T 125° C
Polypropylene: preheating: T max. T 100° C
Single wave soldering
Soldering bath temperature: T 260 ° C
Dwell time: t
5 sec
Double wave soldering
Dwell time: St
5 sec
Due to different soldering processes and
heat requirements the graphs are to be
regarded as a recommendation only.
双波焊接的典型温度/时间图
Typical temperature/time graph for double wave soldering
17
很抱歉,暂时无法提供与“250V 104J P5”相匹配的价格&库存,您可以联系我们找货
