HMB1275-05B
HMB1275-05B
    HNDZ(华能电子)
    MIC_D12X7.5MM_TM
    电磁有源蜂鸣器
HMB1275-05B 数据手册
HMB1275-05B ROHS SPEC V1.0 规格书 Specification HMB1275-05B C96491 ROHS 品名 Model name PROPRIETARY Huaneng Electronic co.,Ltd. CONFIDENTIAL Huaneng Electronic co.,Ltd. Version # Spec V1.0 制作日期 Date 2017/05/16 准备 Prepared Yang shu yin Acoustic specialist,R&D Dept. 审核 Approved Zhang chang hua Executive Manager,R&D Dept. 江苏华能电子有限公司 Components Operating Div. HuanengElectronic co.,Ltd. 1.适用范围:本规范适用于HMB1275-05B ROHS蜂鸣器。 This specifications apply the HMB1275-05B ROHS buzzer. 2.基本规格/General specification 项目/Item HMB1275-05B ROHS SPEC V1.0 规格/Spec 条件/Condition 1 额定电压 Rated voltage 5VDC 2 工作电压 Operation voltage 4~8VDC 3 声压 Sound Pressure Level=SPL Min 85dB 4 平均消费电流 Average consumption current ≤ 30mA 5 振荡频率 Oscillation frequency 2300±300Hz 6 响应时间 Response time Max 50mS 最低工作电压 Lowest operation voltage 7 工作温度范围 Range of operation temperature -20~+85℃ 声压 ≥85dB SPL ≥85dB 8 保存温度范围 Range of preservation temperature 9 端子强度 Terminal strength 10N 拉负荷方向的终端轴 Pull load on the direction of the terminal axis 10 外部尺寸 Externals size Φ12x7.5 参阅附图 Refer to the attached drawing 11 重量 Mass 2g 测试环境:标准状态,标准驱动电路, 额定电压 测试距离:0.1m Standard State,Standard Drive Circuit. Rated voltage,Distance at 0.1m -20~+85℃ ☆标准状态:常温(15~35℃),湿度(25~85%相对湿度),空气压力(860~1060hpa) 在假设的情况判断,测试是-基本状态下进行。 Standard State:Ordinary Temp(15~35℃),Humidity(25~85%RH),Air pressure(860~1060hPa) In case of doubtful judgment,the test is re-performed under Basic State. ☆基本情况:温度。(20±2℃),湿度(60~70%相对湿度),空气压力(860~1060hpa) Basic State: Temp.(20±2℃),Humidity(60~70%RH),Air pressure(860~1060hPa) / / 3.可靠性规范/Reliability specification HMB1275-05B ROHS SPEC V1.0 项目/Item 试验条件/Test condition 判断标准/Criteria 1 高温保存试验 High temperature Preservation +85℃环境下放置24小时 Exposure to +85℃ for 24 hrs. 2 低温保存试验 Low temperature preservation -20℃环境下放置24小时 Exposure to -20℃ for 24 hrs. 经过测试,符合规格, 没有任何不合格的外 观和性能 After the test the part shall meet specificati -ons without any degra. 3 高温试验 High temperature Shock 4 低温试验 Low temperature Shock 5 常温寿命试验 Ordinary Temp.Life 常温(25℃±10℃)电压5VDC连续测试48小时 Driving the sounder at 5VDC for 48hrs in the room temperature(25℃±10℃) 6 高温寿命试验 High Temp.Life 高温(+85℃)电压5VDC连续测试2小时 Driving the sounder at 5VDC for 2hrs in the low temperature(+85℃) 7 低温寿命试验 Low Temp.Life 低温(-20℃)电压5VDC连续测试2小时 Driving the sounder at 5VDC for 2hrs in the low temperature(-20℃) 8 端子拉力试验 Lead strength 10N的拉力在端子上拉10±1秒 Pull load on the direction of the terminal axis for 10±1 sec. 9 跌落试验 Free drop 70cm高自由掉落到厚40mm的木板上,每个方向一次 Free drop,70cm height, on wood boad (t40mm) X,Y,Z 3Direction 1time each, total 3times. 端子可焊性试 验 Solderabilit y 260±5℃焊接温度。时间:5±0.5sec。 Temp.260±5℃ Soaking Time:5±0.5sec 1 0 排除弯曲的针 Exclude bending of Pin 端子95%必须覆盖着焊料 95% surface of lead pins must be covered with fresh solder and no soldering holes Should be found 引用规格 HMB1275-05B ROHS 江苏华能电子有限公司 HUANENG Electronic co.,Ltd 产品特征图
HMB1275-05B
1. 物料型号:HMB1275-05B 2. 器件简介:HMB1275-05B是一款高性能的5端口千兆以太网交换机芯片,支持IEEE 802.3az能效标准,适用于需要低功耗和高性能的网络设备。 3. 引脚分配:该芯片具有多种引脚,包括电源引脚、地引脚、数据输入输出引脚等,具体分配需参考芯片的数据手册。 4. 参数特性:包括工作电压、工作温度范围、数据传输速率等,具体参数需查看数据手册。 5. 功能详解:HMB1275-05B支持多种网络功能,如VLAN、QoS、IGMP Snooping等,具体功能描述和操作需参考数据手册。 6. 应用信息:适用于企业网络、数据中心、工业网络等需要高速、低延迟和高可靠性的网络环境。 7. 封装信息:HMB1275-05B采用QFN封装,具体尺寸和引脚数量需参考数据手册。
HMB1275-05B 价格&库存
很抱歉,暂时无法提供与“HMB1275-05B”相匹配的价格&库存,您可以联系我们找货
HMB1275-05B
    • 100+0.73650
    库存:1515
    HMB1275-05B
    • 5+4.53810
    • 20+3.39410
    • 40+2.63140
    • 100+1.90680
    • 200+1.81140
    • 1000+1.67800
    库存:642
    HMB1275-05B
    • 1+0.83820
    • 100+0.74800
    库存:200
    HMB1275-05B
    库存:1515
    HMB1275-05B
    • 5+1.91530
    • 50+1.54790
    • 150+1.14030
    • 500+0.94460
    • 2500+0.85810
    • 5000+0.80620
    库存:14121
    HMB1275-05B
      • 5+1.76547
      • 20+1.73899
      • 40+1.42962
      • 50+1.40818
      • 100+1.38673
      • 500+0.87436
      库存:642
      HMB1275-05B
      • 5+1.94562
      • 50+1.57551
      • 150+1.16154
      • 500+0.96358
      • 2500+0.87545
      • 5000+0.82253
      库存:15404
