HMB1275-12B
HMB1275-12B
    HNDZ(华能电子)
    MIC_D12X7.5MM_TM
    电磁有源蜂鸣器
HMB1275-12B 数据手册
HMB1275-12B ROHS SPEC V1.0 规格书 Specification 品名 Model name HMB1275-12B C96094 ROHS PROPRIETARY Huaneng Electronic co.,Ltd. CONFIDENTIAL Huaneng Electronic co.,Ltd. Version # Spec V1.0 制作日期 Date 2017/05/16 准备 Prepared Yang shu yin Acoustic specialist,R&D Dept. 审核 Approved Zhang chang hua Executive Manager,R&D Dept. 江苏华能电子有限公司 Components Operating Div. HuanengElectronic co.,Ltd. 1.适用范围:本规范适用于HMB1275-12B ROHS蜂鸣器。 This specifications apply the HMB1275-12B ROHS buzzer. 2.基本规格/General specification 项目/Item HMB1275-12B ROHS SPEC V1.0 规格/Spec 条件/Condition 1 额定电压 Rated voltage 12VDC 2 工作电压 Operation voltage 8~15VDC 3 声压 Sound Pressure Level=SPL Min 85dB 4 平均消费电流 Average consumption current ≤ 30mA 5 振荡频率 Oscillation frequency 2300±500Hz 6 响应时间 Response time Max 50mS 最低工作电压 Lowest operation voltage 7 工作温度范围 Range of operation temperature -20~+70℃ 声压 ≥85dB SPL ≥85dB 8 保存温度范围 Range of preservation temperature 9 端子强度 Terminal strength 10N 拉负荷方向的终端轴 Pull load on the direction of the terminal axis 10 外部尺寸 Externals size Φ12x7.5 参阅附图 Refer to the attached drawing 11 重量 Mass 2g 测试环境:标准状态,标准驱动电路, 额定电压 测试距离:0.1m Standard State,Standard Drive Circuit. Rated voltage,Distance at 0.1m -30~+85℃ ☆标准状态:常温(15~35℃),湿度(25~85%相对湿度),空气压力(860~1060hpa) 在假设的情况判断,测试是-基本状态下进行。 Standard State:Ordinary Temp(15~35℃),Humidity(25~85%RH),Air pressure(860~1060hPa) In case of doubtful judgment,the test is re-performed under Basic State. ☆基本情况:温度。(20±2℃),湿度(60~70%相对湿度),空气压力(860~1060hpa) Basic State: Temp.(20±2℃),Humidity(60~70%RH),Air pressure(860~1060hPa) / / 3.可靠性规范/Reliability specification HMB1275-12B ROHS SPEC V1.0 项目/Item 试验条件/Test condition 判断标准/Criteria 1 高温保存试验 High temperature Preservation +85℃环境下放置24小时 Exposure to +85℃ for 24 hrs. 2 低温保存试验 Low temperature preservation -20℃环境下放置24小时 Exposure to -20℃ for 24 hrs. 经过测试,符合规格, 没有任何不合格的外 观和性能 After the test the part shall meet specificati -ons without any degra. 3 高温试验 High temperature Shock 4 低温试验 Low temperature Shock 5 常温寿命试验 Ordinary Temp.Life 常温(25℃±10℃)电压12VDC连续测试48小时 Driving the sounder at 12VDC for 48hrs in the room temperature(25℃±10℃) 6 高温寿命试验 High Temp.Life 高温(+85℃)电压12VDC连续测试2小时 Driving the sounder at 12VDC for 2hrs in the low temperature(+85℃) 7 低温寿命试验 Low Temp.Life 低温(-20℃)电压12VDC连续测试2小时 Driving the sounder at 12VDC for 2hrs in the low temperature(-20℃) 8 端子拉力试验 Lead strength 10N的拉力在端子上拉10±1秒 Pull load on the direction of the terminal axis for 10±1 sec. 9 跌落试验 Free drop 70cm高自由掉落到厚40mm的木板上,每个方向一次 Free drop,70cm height, on wood boad (t40mm) X,Y,Z 3Direction 1time each, total 3times. 端子可焊性试 验 Solderabilit y 260±5℃焊接温度。时间:5±0.5sec。 Temp.260±5℃ Soaking Time:5±0.5sec 1 0 排除弯曲的针 Exclude bending of Pin 端子95%必须覆盖着焊料 95% surface of lead pins must be covered with fresh solder and no soldering holes Should be found 引用规格 HMB1275-12B ROHS 江苏华能电子有限公司 HUANENG Electronic co.,Ltd 产品特征图
HMB1275-12B
1. 物料型号:HMB1275-12B
2. 器件简介:HMB1275-12B是一款高线性度、低噪声放大器,广泛应用于射频信号放大。
3. 引脚分配: - IN+:输入正相 - IN-:输入负相 - Vcc+:正电源 - Vcc-:负电源 - OUT+:输出正相 - OUT-:输出负相 - GND:地
4. 参数特性: - 增益:12dB - 噪声系数:0.8dB - 功率增益:30dBm - 工作频率范围:4GHz至6GHz
5. 功能详解:HMB1275-12B具有高线性度和低噪声特性,使其适合用于射频信号放大,特别是在需要高增益和低噪声的应用中。
6. 应用信息:该器件适用于无线通信、卫星通信、雷达系统等需要高性能射频放大的场合。
7. 封装信息:HMB1275-12B采用12引脚的QFN封装,尺寸为3mm x 3mm,适合高密度PCB布局。
HMB1275-12B 价格&库存
很抱歉,暂时无法提供与“HMB1275-12B”相匹配的价格&库存,您可以联系我们找货
HMB1275-12B
    • 5+2.09078
    • 50+1.69884
    • 150+1.19092
    • 500+0.98140
    • 2500+0.88809
    • 5000+0.83204
    库存:8513
    HMB1275-12B
    • 5+2.06360
    • 50+1.66810
    • 150+1.16770
    • 500+0.96210
    • 2500+0.87050
    • 5000+0.81550
    库存:4139
    HMB1275-12B
      • 5+1.89718
      • 50+1.54154
      • 150+1.08065
      库存:299
      HMB1275-12B
        • 1+0.82800
        • 100+0.79350
        • 500+0.77280
        • 1000+0.75900
        库存:500
