X49SM1431818MSD2SC
X49SM1431818MSD2SC
    YXC(扬兴科技)
    HC-49S/SMD
    无源晶振 14.31818MHz ±20ppm 20pF -20℃~+70℃
X49SM1431818MSD2SC 数据手册
HC-49SMD Features . External dimensions: 11.4 x 4.8 x 3.8 mm. . Frequency range: 3.579545MHz ~ 64MHz. C YX XX X 12.0 . Surface mount type crystal units. . A great number of standard frequencies. . High frequency pullability and low equivalent series resistance. . Highly mass production capability. . Applications: PC, STB, LCDM and Cable Modem. Electrical Specifications Item / Type HC-49SMD Nominal Frequency Range 3.579545 ~ 64 MHz Vibration Mode AT Fundamental Load Capacitance 12 pF, 20 pF, or specify Frequency Tolerance (at 25 ℃) ±1 0 ppm, ± 20 ppm, or specify Frequency Versus Temperature Characteristics ± 20 ppm, or specify Operating Temperature - 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify Storage Temperature - 40 ~ + 85 ℃ , or specify Shunt Capacitance 7 pF Max. Level Of Drive 1 ~ 500 μW (100 μW typical) Frequency Aging (at 25 ℃) ± 3 ppm / year Max. Equivalent Series Resistance(ESR) 3rd Overtone Fundamental 3.579545 ~ 4 MHz 150 Ω Max. 20 ~ 25 MHz 100 Ω Max. 4 ~ 5 MHz 120 Ω Max. 25 ~ 64 MHz 80 Ω Max. 5 ~ 6 MHz 100 Ω Max. 6 ~ 7 MHz 80 Ω Max. 7 ~ 10 MHz 60 Ω Max. 10 ~ 27 MHz 40 Ω Max. Dimensions Units: mm 1/2 HC-49SMD ★ PART NUMBER GUIDE 部件号示例 Frequency Stability Overall (ppm) Quartz Crystal Resonator Dimensions Frequency Load Capacitance (Hz) (Pf) X 12M 49SM H C -4 9 SMD=11.4 × 4 .35 SMD SEAM TYPE e.g. X4 9 SM12MSD2SC S Pin Material Operating Temp. Range 2 S C D Frequency tolerance B ±10PPM D ±20PPM Load Capacitance (Pf) X 7.4pF G 12.5pF L 9pF 10pF M 12pF O P 15pF Operating temperature C -20~ +70 ℃ -40~ +85 ℃ I -40~ +125℃ A -40~ +105℃ F ★ REFLOW SOLDERING PROFILE 回流焊特性 Temperature (℃) 260℃ max 220℃ 180℃ ③ ① ② Times (S) Pb free reflow A ① Preheat 160~180℃ ② Primary heat 220℃ 60sec. max ③ Peak 10sec. max. 260℃ 2/2 120sec. max
X49SM1431818MSD2SC
物料型号为HC-49SMD,是一款ROHS标准的表面贴装型晶体振荡器。
以下是关于该物料的详细信息:
- 器件简介:HC-49SMD晶体振荡器具有多种标准频率,高频率拉取能力和低等效串联电阻,适用于PC、STB、LCDM和Cable Modem等应用。
- 引脚分配:文档中未明确提供引脚分配信息,但通常HC-49SMD有4个引脚,分别为电源、地、输出和输入。
- 参数特性: - 外部尺寸:11.4 x 4.8 x 3.8 mm - 频率范围:3.579545MHz ~64MHz - 负载电容:12pF, 20pF或指定 - 频率容差(25°C):±10 ppm, ±20 ppm或指定 - 频率温度特性:±20 ppm或指定 - 工作温度:-20°C ~ +70°C, -40°C ~ +85°C或指定 - 存储温度:-40°C ~ +85°C或指定 - 等效串联电阻(ESR):不同频率下有不同的最大值 - 功能详解:HC-49SMD晶体振荡器提供高频率稳定性和可靠性,适用于需要精确时钟信号的电子设备。
- 应用信息:适用于个人电脑、机顶盒、液晶显示器和有线调制解调器等。
- 封装信息:HC-49SMD封装,具有不同的尺寸和高度选项。
请注意,具体的引脚分配和封装细节可能需要参考具体的产品数据手册或联系制造商获取。
X49SM1431818MSD2SC 价格&库存
很抱歉,暂时无法提供与“X49SM1431818MSD2SC”相匹配的价格&库存,您可以联系我们找货
X49SM1431818MSD2SC
  • 1+0.49640
  • 100+0.46240
  • 300+0.42840
  • 500+0.39440
  • 2000+0.37740
  • 5000+0.36720
库存:390
X49SM1431818MSD2SC
  • 1+0.76480
  • 50+0.50990
  • 1000+0.46120
库存:959
