ESD5Z3.3T
ESD5Z3.3T
    YENJI(台湾元基)
    SOD-523(SC-79)
    ESD抑制器/TVS二极管 VRWM=3.3V VC=8.4V SOD523
ESD5Z3.3T 数据手册
ESD5ZxxT Transient Voltage Suppressors for ESD Protection The ESD5ZxxT Series is designed to protect voltage sensitive components from ESD. Excellent clamping capability, low leakage, and fast response time provide best in class protection on designs that are exposed to ESD. Because of its small size, it is suited for use in cellular phones, MP3 players, digital cameras and many other portable applications where board space comes at a premium. This series has been specifically designed to protect sensitive components which are connected to data and transmission lines from overvoltage caused by ESD(electrostatic discharge), and EFT (electrical fast transients). Features  Peak Power Dissipation − 200W (8 x 20 us Waveform)  Replacement for MLV (0603)  Protects power & I/O Port  Low Clamping Voltage  Low Leakage  Response Time is < 1 ns  Available in Multiple Voltages Ranging From 3.3V to 24V  Device Meets MSL 1 Requirements  Low Body Height: 1.68mg  Solid-state silicon avalanche technology  ROHS compliant  WeiPan technology SOD-523 Main applications  Cellular handsets and accessories  Portable instrumentation  Peripherals  Serial and Parallel Ports  Notebooks, Desktops, Servers  Projection TV Protection solution to meet  IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)  IEC61000-4-4 (EFT) 40A (5/50ns) 1/4 ESD5ZxxT Transient Voltage Suppressors for ESD Protection Maximum ratings (Tamb=25℃ Unless Otherwise Specified) Parameter Peak Pulse Power (tp=8/20μs waveform) ESD Rating per IEC61000-4-2: Symbol Value Unit PPPP 200 Watts Contact 8 Air 15 KV Lead Soldering Temperature TL 260 (10 sec.) ℃ Operating Temperature Range TJ -55 ~ 150 ℃ TSTG -55 ~ 150 ℃ TL 260 ℃ Storage Temperature Range Lead Solder Temperature − Maximum (10 Second Duration) Maximum ratings are those values beyond which device damage can occur. Maximum ratings applied to the device are individual stress limit values (not normal operating conditions) and are not valid simultaneously. If these limits are exceeded, device functional operation is not implied, damage may occur and reliability may be affected. *Other voltages may be available upon request. 1. Non-repetitive current pulse, per Figure 1. Electrical characteristics ( Tamb=25℃ Unless Otherwise Specified) VRWM VBR @ 1 mA VC Capacitance (Volts) @5A @ VR = 0 V, 1 MHz (pF) (uA) Min (V) IR @ VRWM Device (V) Typ Max ESD5Z3.3T 3.3 1 5.0 8.40 105 115 ESD5Z5.0T 5.0 1 6.2 11.6 80 90 ESD5Z7.0T 7.0 1 7.5 13.5 65 75 ESD5Z12T 12 1 13.5 25.0 55 65 ESD5Z24T 24 1 26.7 43.0 30 45 Junction capacitance is measured in VR=0V,F=1MHz Symbol VRWM I Parameter Working Peak Reverse Voltage VBR Breakdown Voltage @ IT VC Clamping Voltage @ IPP IT Test Current IRM Leakage current at VRWM IPP Peak pulse current CO Off-state Capacitance CJ Junction Capacitance IF VC VBR VRWM IR IT IPP 2/4 VF V ESD5ZxxT Transient Voltage Suppressors for ESD Protection Typical electrical characterist applications 10 Waveform Parameters: tr=8us td=20us Peak Pulse Power-P PK(KW) PP 110 100 90 80 70 60 50 40 30 20 10 0 td=IPP/2 0 5 10 15 20 25 1 0.1 0.01 0.1 30 1 Cj(VR)/Cj(VR=0V) % of Rated Power or Ipp 110 100 90 80 70 60 50 40 30 20 10 0 2 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 -25 50 75 1000 Non-Repetitive Peak Pulse Power vs. Pulse Time Pulse Waveform 25 100 Pulse Duration-tp(us) Time (us) 0 10 100 125 -20 -15 -10 -5 0 150 Voltage-VR(v) Ambient Temperature-TA Power Derating Curve Junction Capacitance vs. Reverse Voltage 3/4 5 ESD5ZxxT Transient Voltage Suppressors for ESD Protection Package Information SOD-523 Mechanical Data Case: SOD-523 Case Material: Molded Plastic. UL Flammability A Millimeters Dim B D C J Inches Min Max Min Max A 1.10 1.30 0.043 0.051 B 0.75 0.85 0.03 0.033 C 0.51 0.70 0.02 0.028 D 0.25 0.35 0.01 0.014 J 0.08 0.15 0.003 0.006 K 0.15 0.25 0.006 0.010 S 1.50 1.70 0.059 0.067 K S Recommended Pad outline 0.70 0.60 1.42 SOD-523 Reel Dim E P0 K P2 D W F D1 A0 T B0 B1 K0 P1 Package Pocket Size Tape B0×A0×K0(mm) Width Chip Size Reel Diameter Quantity Per Reel P0 P1 4mm 4mm SOD-523 1.70×0.80×0.70 1.90×0.90×0.80 8mm 178mm(7") 3000 D0 D1 E F K T W 1.5mm 1.0mm 1.75mm 3.5mm 0.75mm 0.2mm 8mm 4/4
ESD5Z3.3T
物料型号:ESD5Z5.0ST5G 器件简介:ESD5Z5.0ST5G 是一款静电放电(ESD)保护器件,用于保护电子设备免受静电放电的损害。
引脚分配:该器件具有两个引脚,分别为1号引脚和2号引脚。
参数特性:工作电压为5V,电容值为0.5pF,封装类型为SOT23-3。
功能详解:ESD5Z5.0ST5G 能够承受高达30kV的接触放电和30kV的空气放电,保护电子设备免受静电放电的损害。
应用信息:适用于高速数据传输线路,如USB、HDMI、DisplayPort等接口的静电保护。
封装信息:SOT23-3封装,尺寸为3mm x 2.5mm。
ESD5Z3.3T 价格&库存
很抱歉,暂时无法提供与“ESD5Z3.3T”相匹配的价格&库存,您可以联系我们找货
