SMF24CA
SMF24CA
    YENJI(台湾元基)
    SOD-123FL
    ESD抑制器/TVS二极管 VRWM=24V VC=38.9V SOD123FL
SMF24CA 数据手册
MMF5.0A/CA SMF5.0A/CA---SMF5.0A/CA--SMF190A/CA ---MMF190A/CA SMF190A/CA 200W Surface Mount Transient Voltage Suppressors Features z z z z z z z z z Working peak reverse voltage range – 5.0V to 190V. Peak power dissipation 200W @10 x 1000 us Pulse Low profile package. Excellent clamping capability. Glass passivated junction. Fast response time: typically less than 1 ns for Uni-direction. Typical IR less than 1uA above 10V. Plastic material has UL flammability classification 94V-O RoHS compliant in lead-free versions SOD-123FL Mechanical Characteristics CASE: Void-free, Molded Plastic over glass passivated junction.. Mounting Position: Any Polarity: by cathode band denotes uni-directional device. Qualified max reflow temperature: 260°C Maximum Ratings And Characteristics @ 25°C Ambient Temperature (unless otherwise noted) Parameter Symbol Value Units Peak Pulse Power Dissipation on 10/1000 us Waveform (Note 1, 2, FIG.1) PPPM Min 200 W Peak Pulse Current of on 10/1000us Waveform (Note 1, FIG.3) IPPM See Table 1 Amps TJ -55 to 150 °C TSTG -55 to 150 °C Operating Junction Temperature Range Storage Temperature Range Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25°C per Fig.2. 1/4 4/4 MMF5.0A/CA SMF5.0A/CA---SMF5.0A/CA--SMF190A/CA ---MMF190A/CA SMF190A/CA Electrical Specification @ Tamb 25°C Type Number Marking Reverse Breakdown Stand-Off Voltage Voltage Min. @IT Breakdown Voltage Max. @ IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRMW Uni Bi Uni Bi VRMW(V) VBR MIN(V) VBR MAX(V) IT (mA) VC(V) IPP(A) IR(uA) MMF5.0A SMF5.0A MMF5.0CA SMF5.0CA 5.0A 5.0CA 5.0 6.40 7.25 10 9.2 21.7 400.0 MMF6.0A SMF6.0A MMF6.0CA SMF6.0CA 6.0A 6.0CA 6.0 6.67 7.67 10 10.3 19.4 400.0 MMF6.5A SMF6.5A MMF6.5CA SMF6.5CA 6.5A 6.5CA 6.5 7.22 8.30 10 11.2 17.9 250.0 SMF7.0A MMF7.0A MMF7.0CA SMF7.0CA 7.0A 7.0CA 7.0 7.78 8.95 10 12 16.7 100.0 MMF7.5A SMF7.5A MMF7.5CA SMF7.5CA 7.5A 7.5CA 7.5 8.33 9.58 1.0 12.9 15.5 50.0 MMF8.0A SMF8.0A MMF8.0CA SMF8.0CA 8.0A 8.0CA 8.0 8.89 10.23 1.0 13.6 14.7 25.0 MMF8.5A SMF8.5A MMF8.5CA SMF8.5CA 8.5A 8.5CA 8.5 9.44 10.82 1.0 14.4 13.9 10.0 MMF9.0A SMF9.0A MMF9.0CA SMF9.0CA 9.0A 9.0CA 9.0 10.0 11.5 1.0 15.4 13 5.0 MMF10A SMF10A MMF10CA SMF10CA 10A 10CA 10 11.1 12.8 1.0 17 11.8 2.5 MMF11A SMF11A MMF11CA SMF11CA 11A 11CA 11 12.2 14.0 1.0 18.2 11 2.5 MMF12A SMF12A MMF12CA SMF12CA 12A 12CA 12 13.3 15.3 1.0 19.9 10.1 2.5 MMF13A SMF13A MMF13CA SMF13CA 13A 13CA 13 14.4 16.5 1.0 21.5 9.3 1.0 MMF14A SMF14A MMF14CA SMF14CA 14A 14CA 14 15.6 17.9 1.0 23.2 8.6 1.0 MMF15A SMF15A MMF15CA SMF15CA 15A 15CA 15 16.7 19.2 1.0 24.4 8.2 1.0 MMF16A SMF16A MMF16CA SMF16CA 16A 16CA 16 17.8 20.5 1.0 26 7.7 1.0 MMF17A SMF17A MMF17CA SMF17CA 17A 17CA 17 18.9 21.7 1.0 27.6 7.2 1.0 MMF18A SMF18A MMF18CA SMF18CA 18A 18CA 18 20.0 23.3 1.0 29.2 6.8 1.0 MMF20A SMF20A MMF20CA SMF20CA 20A 20CA 20 22.2 25.5 1.0 32.4 6.2 1.0 MMF22A SMF22A MMF22CA SMF22CA 22A 22CA 22 24.4 28.0 1.0 35.5 5.6 1.0 MMF24A SMF24A MMF24CA SMF24CA 24A 24CA 24 26.7 30.7 1.0 38.9 5.1 1.0 MMF26A SMF26A MMF26CA SMF26CA 26A 26CA 26 28.9 33.2 1.0 42.1 4.8 1.0 MMF28A SMF28A MMF28CA SMF28CA 28A 28CA 28 31.1 35.8 1.0 45.4 4.4 1.0 MMF30A SMF30A MMF30CA SMF30CA 30A 30CA 30 33.3 38.3 1.0 48.4 4.1 1.0 MMF33A SMF33A MMF33CA SMF33CA 33A 33CA 33 36.7 42.2 1.0 53.3 3.8 1.0 MMF36A SMF36A MMF36CA SMF36CA 36A 36CA 36 40.0 46.0 1.0 58.1 3.4 1.0 MMF40A SMF40A MMF40CA SMF40CA 40A 40CA 40 44.4 51.1 1.0 64.5 3.1 1.0 MMF43A SMF43A MMF43CA SMF43CA 43A 43CA 43 47.8 54.9 1.0 69.4 2.9 1.0 MMF45A SMF45A MMF45CA SMF45CA 45A 45CA 45 50.0 57.5 1.0 72.7 2.8 1.0 MMF48A SMF48A MMF48CA SMF48CA 48A 48CA 48 53.3 61.3 1.0 77.4 2.6 1.0 MMF51A SMF51A MMF51CA SMF51CA 51A 51CA 51 56.7 65.2 1.0 82.4 2.4 1.0 MMF54A SMF54A MMF54CA SMF54CA 54A 54CA 54 60.0 69.0 1.0 87.1 2.3 1.0 MMF58A SMF58A MMF58CA SMF58CA 58A 58CA 58 64.4 74.1 1.0 93.6 2.1 1.0 MMF60A SMF60A MMF60CA SMF60CA 60A 60CA 60 66.7 76.7 1.0 96.8 1.8 1.0 MMF64A SMF64A MMF64CA SMF64CA 64A 64CA 64 71.1 81.8 1.0 103 1.7 1.0 MMF70A SMF70A MMF70CA SMF70CA 70A 70CA 70 77.8 89.5 1.0 113 1.5 1.0 MMF75A SMF75A MMF75CA SMF75CA 75A 75CA 75 83.3 95.8 1.0 121 1.4 1.0 MMF78A SMF78A MMF78CA SMF78CA 78A 78CA 78 86.7 99.7 1.0 126 1.4 1.0 2/4 4/4 MMF5.0A/CA SMF5.0A/CA---SMF5.0A/CA--SMF190A/CA ---MMF190A/CA SMF190A/CA Type Number Uni Marking Bi Reverse Breakdown Breakdown Stand-Off Voltage Voltage Voltage Min. @IT Max. @ IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRMW Uni Bi VRMW(V) VBR MIN(V) VBR MAX(V) IT (mA) VC(V) IPP(A) IR(uA) MMF85A SMF85A SMF85CA MMF85CA 85A 85CA 85 94.4 108.2 1.0 137 1.3 1.0 MMF90A SMF90A SMF90CA MMF90CA 90A 90CA 90 100.0 115.5 1.0 146 1.2 1.0 MMF100A SMF100A MMF100CA SMF100CA 100 100C 100 111.0 128.0 1.0 162 1.1 1.0 MMF110A SMF110A SMF110CA MMF110CA 110 110C 110 122.0 140.5 1.0 177 1.0 1.0 MMF120A SMF120A MMF120CA SMF120CA 120 120C 120 133.0 153.0 1.0 193 0.9 1.0 MMF130A SMF130A MMF130CA SMF130CA 130 130C 130 144.0 165.5 1.0 209 0.8 1.0 MMF150A SMF150A MMF150CA SMF150CA 150 150C 150 167.0 192.5 1.0 243 0.7 1.0 MMF160A SMF160A MMF160CA SMF160CA 160 160C 160 178.0 205.0 1.0 259 0.7 1.0 MMF170A SMF170A MMF170CA SMF170CA 170 170C 170 189.0 217.5 1.0 275 0.6 1.0 MMF180A SMF180A MMF180CA SMF180CA 180 180C 180 198.0 230.4 1.0 292 0.6 1.0 MMF190A SMF190A MMF190CA SMF190CA 190 190C 190 209.0 243.2 1.0 308 0.5 1.0 Ratings and Characteristic Curves TA=25°C unless otherwise noted 3/4 4/4 MMF5.0A/CA SMF5.0A/CA---SMF5.0A/CA--SMF190A/CA ---MMF190A/CA SMF190A/CA Package Outline Dimensions and Pad Layouts SOD-123FL Dim Millimeters Min 4/4 Max Inches Min Max A 3.40 3.85 0.142 0.150 B 2.50 2.90 0.098 0.114 C 1.40 1.80 0.055 0.071 D 0.90 1.35 0.035 0.053 E 0.50 1.10 0.020 0.043 G 0.25 ------ 0.010 ---- H ------ 0.20 ---- 0.008
SMF24CA
物料型号:SMF5.0A/CA - SMF190A/CA
器件简介:200W表面安装瞬态电压抑制器,具有工作峰值反向电压范围5.0V至190V,峰值功率耗散200W @ 10 x 1000us脉冲,低轮廓封装,出色的钳位能力,玻璃钝化结,快速响应时间:典型值小于1ns(单向),典型IR小于1uA(10V以上)。
引脚分配:通过阴极带表示极性,单向装置。
参数特性:包括峰值脉冲功率耗散、峰值脉冲电流、工作结温范围、存储温度范围等。
功能详解:包括电气规格、反向立电压、击穿电压、测试电流、最大钳位电压、峰值脉冲电流、反向漏电流等。
应用信息:文档中未明确提供应用信息,但根据器件特性,可能用于电路保护。
封装信息:SOD-123FL,塑料材料具有UL阻燃分类94V-O,符合RoHS标准的无铅版本。
SMF24CA 价格&库存
很抱歉,暂时无法提供与“SMF24CA”相匹配的价格&库存,您可以联系我们找货
