UMW
R
UMW 1N60
HANNEL POWER MOSFET
NN-沟道功率 MOS 管// N-C
N-CHANNEL
TC=25
●最大额定值(TC=25
TC=25°°C)
(Tc=25
●Absolute Maximum Ratings
Ratings(
Tc=25°°C)
TO-92/251T/251S/252,SOT-22 3
单位
UNIT
参数
PARAMETER
符号
SYMBOL
额定值
VALUE
漏-源电压
Drain-source Voltage
VDS
600
V
Ω
11Ω
RDS(ON)=11
VGS
±30
V
ID=1.0A
ID
1.0*
ID
0.6*
A
IDM
4.0*
A
栅-源电压
gate-source Voltage
漏极电流
Continuous Drain Current
TC=25℃
漏极电流
TC=100℃
最大脉冲电流
Drain Current -Pulsed ①
耗散功率
Power Dissipation (TL=25°C)
PD
最高结温
Junction Temperature
Tj
TO-92:3
TO-251T/251S/252/126:28
150
存储温度
TSTG
-55-150
Storage Temperature
单脉冲雪崩能量
Single Pulse Avalanche
EAS
14
②
Energy②
*漏极电流由最高结温限制
*Drain current limited by maximum junction temperature
VDS=600V
A
W
°C
°C
mJ
SOT-223
Tc=25
Tc=25°°C)
●电特性(Tc=25
(Tc=25
Tc=25°°C)
Characteristics(
●Electronic Characteristics
符号
SYMBOL
测试条件
TEST CONDITION
最小值
MIN
BVDSS
VGS=0V, ID=250µA
600
ΔBVDSS/
ΔTj
ID=250uA, Referenced to
25°C
VGS(TH)
VGS=VDS, ID=250µA
漏-源漏电流
Drain-source Leakage Current
IDSS
VDS =600V,
VGS =0V, Tj=25°C
VDS =480V,
VGS =0V, Tj=125°C
跨导
Forward Transconductance
gfs
参数
PARAMETER
漏-源击穿电压
Drain-source Breakdown Voltage
击穿电压温度系数
Breakdown Voltage Temperature
Coefficient
栅极开启电压
Gate Threshold Voltage
www.umw-ic.com
VDS =40V, ID=0.5A ③
1
典型值
TYP
最大值
MAX
V
0.6
2.0
0.5
单位
UNIT
V/°C
4.0
V
25
µA
250
µA
S
友台半导体有限公司
UMW
R
UMW 1N60
HANNEL POWER MOSFET
NN-沟道功率 MOS 管// N-C
N-CHANNEL
参数
PARAMETER
栅极漏电流
Gate-body Leakage
Current (VDS = 0)
漏-源导通电阻
Static Drain-source On
Resistance
输入电容
Input Capacitance
符号
SYMBOL
测试条件
TEST CONDITION
IGSS
VGS =±30V
RDS(ON)
VGS =10V, ID=0.5A
③
Coss
反向传输电容
Reverse transfer Capacitance
Crss
关断延迟
Turn -Off Delay Time
栅极电荷
Total Gate Charge
栅源电荷
Gate-to-Source Charge
栅漏电荷
Gate-to-Drain Charge
二极管正向电流
Continuous Diode Forward
Current
二极管正向压降
Diode Forward Voltage
Td(off)
VGS = 0V, VDS = 25V
F = 1.0MHZ
trr
反向恢复电荷
Reverse Recovery Charge
Qrr
±100
nA
11
Ω
25
VDD=300V, ID =1.0A
RG= 25Ω ③
pF
ID =1.0A, VDS = 480V
VGS = 10V
③
13
ns
4.8
nC
0.7
nC
2.7
nC
IS
反向恢复时间
Reverse Recovery Time
单位
UNIT
5.4
Qgd
VSD
最大值
MAX
150
Qg
Qgs
典型值
TYP
8.5
Ciss
输出电容
Output Capacitance
最小值
MIN
Tj=25°C, Is=0.5A
VGS =0V
③
Tj=25°C, If=1.0A
di/dt=100A/μs
③
1.0
A
1.4
V
190
ns
0.53
uC
●热特性
●Thermal Characteristics
参数
PARAMETER
热阻结-环境
Thermal Resistance Junction-lead
热阻结-环境
Thermal Resistance Junction-ambient
符号
SYMBOL
最大值
MAX
单位
UNIT
TO-92
T/251S/252
TO-251T
TO-251
RthJL
41.67
4.46
℃/W
RthJA
140.0
110.0
℃/W
注释((Notes
Notes)):
① 脉冲宽度:以最高节温为限制
Repetitive rating: Pulse width limited by maximum junction temperature
② 初始结温=25oC, VDD =50V, L=30mH, RG =25Ω, IAS=1.0A
Starting Tj=25oC, VDD =50V, L=30mH, RG =25Ω, IAS=1.0A
③ 脉冲测试:脉冲宽度≤ 300μs ,占空比≤ 2 %
Pulse Test : Pulse width ≤ 300μs, Duty cycle ≤ 2%
www.umw-ic.com
2
友台半导体有限公司
UMW
R
UMW 1N60
HANNEL POWER MOSFET
NN-沟道功率 MOS 管// N-C
N-CHANNEL
● 特性曲线
图 1 输出特性曲线, Tc=25℃
Fig1 Typical Output Characteristics, Tc=25℃
图 2 输出特性曲线, Tc=150℃
Fig2 Typical Output Characteristics, Tc=150℃
图 3 归一化导通电阻与温度曲线
Fig3 Normalized On-Resistance Vs.Temperature
图 4 二极管正向电压曲线
Fig4 Typical Source-Drain Diode Forward Voltage
图 5 最大漏极电流与壳温曲线
Fig5 Maximum Drain Current Vs.Case Temperature
www.umw-ic.com
3
友台半导体有限公司
UMW
R
UMW 1N60
HANNEL POWER MOSFET
NN-沟道功率 MOS 管// N-C
N-CHANNEL
TO-92 封装机械尺寸
TO-92 MECHANICAL DATA
mm
单位::毫米//UNIT
UNIT:mm
最大值//max
符号//SYMBOL
最小值//min
A
4.30
5.30
b
0.30
0.55
c
0.30
0.50
φD
D
4.30
5.20
d
1.00
1.70
E
3.20
4.20
典型值//nom
e
2.54
e1
1.27
L
12.70
15.00
L1
1.50
2.00
www.umw-ic.com
4
友台半导体有限公司
UMW
R
UMW 1N60
HANNEL POWER MOSFET
NN-沟道功率 MOS 管// N-C
N-CHANNEL
T 封装机械尺寸
TO-251
TO-251T
T (IPAK) MECHANICAL DATA
TO-251
TO-251T
单位:毫米/UNIT:mm
最大值//max
符号//SYMBOL
最小值//min
A
2.10
2.50
A1
0.95
1.30
B
0.80
1.25
b
0.50
0.80
b1
0.70
0.80
c
0.45
0.70
c1
0.45
0.70
D
6.35
6.80
D1
5.10
5.50
E
5.30
6.30
e
2.25
L
7.00
9.20
H
0.35
0.45
W1
0.30
0.50
W2
0.20
0.40
典型值//nom
2.30
2.35
[S/L]
www.umw-ic.com
5
友台半导体有限公司
UMW
R
UMW 1N60
HANNEL POWER MOSFET
NN-沟道功率 MOS 管// N-C
N-CHANNEL
S 封装机械尺寸
TO-251
TO-251S
S (IPAK) MECHANICAL DATA
TO-251
TO-251S
单位:毫米/UNIT:mm
最大值//max
符号//SYMBOL
最小值//min
A
2.20
2.40
b
0.60
0.85
C
0.45
D
6.50
6.70
D1
5.10
5.50
E
5.9
6.20
e
2.18
L
11.00
12.40
L1
4.8
5.3
L2
3.5
4.2
www.umw-ic.com
典型值//nom
0.50
2.29
6
0.60
2.38
友台半导体有限公司
UMW
R
UMW 1N60
HANNEL POWER MOSFET
NN-沟道功率 MOS 管// N-C
N-CHANNEL
TO-252 封装机械尺寸
TO-252 MECHANICAL DATA
mm
单位::毫米//UNIT
UNIT:mm
最小值
最大值
min
max
0.85
1.25
符号
SYMBOL
A
最小值
min
2.10
最大值
max
2.50
符号
SYMBOL
B
b
0.50
0.80
b1
0.50
0.90
b2
0.45
0.70
C
0.45
0.70
D
6.30
6.75
D1
5.10
5.50
E
5.30
6.30
e1
2.25
2.35
L1
9.20
10.60
e2
4.45
4.75
L2
0.90
1.75
L3
0.60
1.10
K
0.00
0.23
www.umw-ic.com
7
友台半导体有限公司
UMW
R
UMW 1N60
HANNEL POWER MOSFET
NN-沟道功率 MOS 管// N-C
N-CHANNEL
TO-252 编带规格尺寸
TO-252 TAPE AND REEL DATA
mm
UNIT:mm
单位::毫米//UNIT
符号
SYMBOL
最小值
min
最大值
max
符号
SYMBOL
最小值
min
最大值
max
W
16.0-0.3
16.0+0.3
F
7.5-0.1
7.5+0.1
P0
4.0-0.1
4.0+0.1
D
1.5-0.0
1.5+0.1
P
8.0-0.1
8.0+0.1
P1
2.0-0.1
2.0+0.1
K
2.65
2.80
D1
1.5-0.0
1.5+0.1
使用供带方向/USER DIRECTION OF FEED
编带器件定位/UNIT ORIENTATION
www.umw-ic.com
8
友台半导体有限公司
UMW
R
UMW 1N60
HANNEL POWER MOSFET
NN-沟道功率 MOS 管// N-C
N-CHANNEL
SOT-22 3 封装机械尺寸
SOT-22 3 MECHANICAL DATA
www.umw-ic.com
9
友台半导体有限公司
很抱歉,暂时无法提供与“UMW 1N60G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.45900
- 20+0.41850
- 100+0.37800
- 500+0.33750
- 1000+0.31860
- 2000+0.30510
