UMW MB6S(0.8A)
UMW MB6S(0.8A)
    UMW(友台)
    DBS-4P_3.81X4.70MM_SM
    0.8Amp单相玻璃钝化桥式整流器50至1000伏
UMW MB6S(0.8A) 数据手册
UMW R UMW MB05S-MB10S Features • • • • 0.8Amp Single Phase Glass Passivated Bridge Rectifier 50 to 1000 Volts Surface Mount Package Glass Passivated Diode Construction Moisture Resistant Epoxy Case High Surge Current Capability Maximum Ratings • • MBS -1 Operating Temperature: -55°C to +150°C Storage Temperature: -55°C to +150°C ∼ MCC Catalog Number Device Marking MB05S MB1S MB2S MB4S MB6S MB8S MB10S MB05S MB1S MB2S MB4S MB6S MB8S MB10S Maximum Rccurrent Peak Reverse Voltage 50V 100V 200V 400V 600V 800V 1000V Maximum RMS Voltage 35V 70V 140V 280V 420V 560V 700V Maximum DC Blocking Voltage 50V 100V 200V 400V 600V 800V 1000V Electrical Characteristics @ 25°C Unless Otherwise Specified Average Forward IF(AV) 0.8A Note T A = 30°C Current Peak Forward Surge I 8.3ms, half sine 30A FSM Current Maximum 1.0V IFM = 0.5A; Instantaneous VF Forward Voltage TA = 25°C Maximum DC Reverse Current At IR TA = 25°C 10 µA Rated DC Blocking Voltage Typical Junction CJ 25pF Measured at Capacitance 1.0MHz, VR=4.0V Note1. Measured at 1.0 MHz and applied reverse voltage of 4.0 Volts Note2. On alum: substrate P.C.B with an rea of 0.8 x 0.8 x 0.25” ( 20 x 20 x 6.4mm ) mounte on 0.05 x 0.05 “( 13 x 13 mm ) solder pad. *Pulse Test: Pulse Width 300µsec, Duty Cycle 1% www.umw-ic.com 1 D B E ∼ + F C A Notch in case K M J G H N L          M         .252    .017 .090 .004 .021 .055 ---- .040 .008   .272    .029 .106 .008 .023 .065 .200  .050 .014   6.40    0.45 2.30 0.10 0.53 1.40 ---- 1.02 0.15  6.91    0.75 2.70 0.20 0.58 1.65 5.08  1.27 0.35    友台半导体有限公司 UMW R UMW MB05S-MB10S Figure 1 Typical Forward Characteristics Figure 2 Typical Reverse Characteristics 20 100 60 10 40 6 20 4 10 2 6 25°C Amps 1 4 .6 2 .4 µAmps 1 .6 .2 .4 .1 .2 .06 TA=25°C .1 .04 .06 .04 .02 .01 .02 .4 .6 .8 1.0 1.2 1.4 .01 20 Volts 40 60 Instantaneous Forward Current - Amperesversus Instantaneous Forward Voltage - Volts 80 100 120 140 Volts Instantaneous Reverse Leakage Current - MicroAmperesversus Percent Of Rated Peak Reverse Voltage - Volts Figure 3 Forward Derating Curve 1.2 Figure 4 Peak Forward Surge Current 1.0 60 50 .8 40 .6 30 Amps Amps .4 10 5 0 .2 Single Phase, Half Wave 60Hz Resistive or Inductive Load 0 0 40 50 75 100 125 20 150 175 1 2 4 6 8 10 20 40 60 80 100 Cycles °C Peak Forward Surge Current - Amperesversus Number Of Cycles At 60Hz - Cycles Average Forward Rectified Current - Amperesversus Ambient Temperature - °C www.umw-ic.com 2 友台半导体有限公司
UMW MB6S(0.8A) 价格&库存
很抱歉,暂时无法提供与“UMW MB6S(0.8A)”相匹配的价格&库存,您可以联系我们找货
UMW MB6S(0.8A)
  • 50+0.07950
  • 500+0.07155
  • 5000+0.06625
  • 10000+0.06360
  • 30000+0.06095
  • 50000+0.05936
