UMW
R
UMW MB05S-MB10S
Features
0.8Amp Single Phase
Glass Passivated
Bridge Rectifier
50 to 1000 Volts
Surface Mount Package
Glass Passivated Diode Construction
Moisture Resistant Epoxy Case
High Surge Current Capability
Maximum Ratings
MBS -1
Operating Temperature: -55°C to +150°C
Storage Temperature: -55°C to +150°C
MCC
Catalog
Number
Device
Marking
MB05S
MB1S
MB2S
MB4S
MB6S
MB8S
MB10S
MB05S
MB1S
MB2S
MB4S
MB6S
MB8S
MB10S
Maximum
Rccurrent
Peak Reverse
Voltage
50V
100V
200V
400V
600V
800V
1000V
Maximum
RMS
Voltage
35V
70V
140V
280V
420V
560V
700V
Maximum
DC
Blocking
Voltage
50V
100V
200V
400V
600V
800V
1000V
Electrical Characteristics @ 25°C Unless Otherwise Specified
Average Forward
IF(AV)
0.8A
Note T A = 30°C
Current
Peak Forward Surge
I
8.3ms, half sine
30A
FSM
Current
Maximum
1.0V
IFM = 0.5A;
Instantaneous
VF
Forward Voltage
TA = 25°C
Maximum DC
Reverse Current At
IR
TA = 25°C
10 µA
Rated DC Blocking
Voltage
Typical Junction
CJ
25pF
Measured at
Capacitance
1.0MHz, VR=4.0V
Note1. Measured at 1.0 MHz and applied reverse voltage of 4.0 Volts
Note2. On alum: substrate P.C.B with an rea of 0.8 x 0.8 x 0.25”
( 20 x 20 x 6.4mm ) mounte on 0.05 x 0.05 “( 13 x 13 mm )
solder pad.
*Pulse Test: Pulse Width 300µsec, Duty Cycle 1%
www.umw-ic.com
1
D
B
E
F
C
A
Notch in case
K
M
J
G
H
N
L
M
.252
.017
.090
.004
.021
.055
.040
.008
.272
.029
.106
.008
.023
.065
.200
.050
.014
6.40
0.45
2.30
0.10
0.53
1.40
1.02
0.15
6.91
0.75
2.70
0.20
0.58
1.65
5.08
1.27
0.35
友台半导体有限公司
UMW
R
UMW MB05S-MB10S
Figure 1
Typical Forward Characteristics
Figure 2
Typical Reverse Characteristics
60
10
40
6
10
2
6
25°C
Amps
1
4
.6
2
.4
µAmps 1
.6
.2
.4
.1
.2
.06
TA=25°C
.1
.04
.06
.04
.02
.01
.02
.4
.6
.8
1.0
1.2
1.4
.01
Volts
40
60
Instantaneous Forward Current - Amperesversus
Instantaneous Forward Voltage - Volts
80
100
120
140
Volts
Instantaneous Reverse Leakage Current - MicroAmperesversus
Percent Of Rated Peak Reverse Voltage - Volts
Figure 3
Forward Derating Curve
1.2
Figure 4
Peak Forward Surge Current
1.0
60
50
.8
40
.6
30
Amps
Amps
.4
10
5
Single Phase, Half Wave
60Hz Resistive or Inductive Load
75
100
125
175
1
2
4
6
8 10
60 80 100
Cycles
°C
Peak Forward Surge Current - Amperesversus
Number Of Cycles At 60Hz - Cycles
Average Forward Rectified Current - Amperesversus
Ambient Temperature - °C
www.umw-ic.com
2
友台半导体有限公司
很抱歉,暂时无法提供与“UMW MB10S(0.8A)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07791
- 500+0.06996
- 5000+0.06466
- 10000+0.06201
- 30000+0.05936
- 50000+0.05777
