UMW
R
UMW AO3400A
N-Channel Enhancement Mode
Features
SOT–23
VDS (V) = 30V
ID = 5.8 A (VGS = 10V)
RDS(ON)
28m
(VGS = 10V)
RDS(ON)
33m
(VGS = 4.5V)
RDS(ON)
52m
(VGS = 2.5V)
1. GATE
2. SOURCE
3. DRAIN
Absolute Maximum Ratings Ta = 25
Symbol
Rating
Unit
Drain-Source Voltage
Parameter
VDS
30
V
Gate-Source Voltage
VGS
Continuous Drain Current
TA=25
TA=70
P u l s e d D r a i n Cu r r e n t *
Power Dissipation
ID
IDM
TA=25
TA=70
PD
12
V
5.8
4.9
A
30
1.4
1
W
Thermal Resistance.Junction- to-Ambient
RthJA
125
/W
Thermal Resistance.Junction- to-Case
Rthc
60
/W
TJ, TSTG
-55 to 150
Junction and Storage Temperature Range
* Repetitive rating, pulse width limited by junction temperature.
www.umw-ic.com
1
友台半导体有限公司
UMW
R
UMW AO3400A
Electrical Characteristics Ta = 25
Parameter
Symbol
Drain-Source Breakdown Voltage
VDSS
Zero Gate Voltage Drain Current
IDSS
Gate-Body leakage current
Gate Threshold Voltage
IGSS
VGS(th)
Testconditions
ID=250
Min
On state drain current
RDS(ON)
ID(ON)
Forward Transconductance
gFS
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Gate resistance
Rg
Total Gate Charge
Qg
Max
30
A, VGS=0V
1
VDS=24V, VGS=0V ,TJ=55
5
VDS=0V, VGS=
12V
100
A
nA
1.1
1.4
22 . 8
28
32
39
VGS=4.5V, ID=5A
27 . 3
33
m
VGS=2.5V, ID=4A
43 . 3
52
m
VDS=VGS ID=250
0.7
Unit
V
VDS=24V, VGS=0V
A
VGS=10V, ID=5.8A
Static Drain-Source On-Resistance
Typ
VGS=10V, ID=5.8A
TJ=125
VGS=4.5V, VDS=5V
30
VDS=5V, ID=5A
10
m
A
15
823
S
1050
VGS=0V, VDS=15V, f=1MHz
99
VGS=0V, VDS=0V, f=1MHz
1.4
3.6
9.7
12
pF
pF
77
VGS=4.5V, VDS=15V, ID=5.8A
V
pF
nC
Gate Source Charge
Qgs
1.6
nC
Gate Drain Charge
Qgd
3.1
nC
Turn-On DelayTime
tD(on)
3.3
Turn-On Rise Time
tr
Turn-Off DelayTime
tD(off)
Turn-Off Fall Time
VGS=10V, VDS=15V, RL=2.7
tf
,RGEN=3
5
ns
4.8
7
ns
26.3
40
ns
4.1
6
ns
Body Diode Reverse Recovery Time
trr
IF=5A, dI/dt=100A/
s
16
ns
Body Diode Reverse Recovery Charge
Qrr
IF=5A, dI/dt=100A/
s
8.9
12
nC
Maximum Body-Diode Continuous Current
IS
2.5
A
1
V
Diode Forward Voltage
www.umw-ic.com
VSD
IS=1A,VGS=0V
2
0.71
友台半导体有限公司
R
UMW
UMW AO3400A
■ Typical Characterisitics
25
10V
3V
VDS=5V
16
4.5V
2.5V
15
12
ID(A)
ID (A)
10
VGS=2V
5
2
3
4
VDS (Volts)
Fig 1: On-Region Characteristics
5
0.5
1
1.5
2
2.5
VGS(Volts)
Figure 2: Transfer Characteristics
3
Normalized On-Resistance
1.8
50
VGS=2.5V
40
30
VGS=4.5V
VGS=10V
1.6
VGS=4.5V
1.4
VGS=10V
1.2
VGS=2.5V
1
10
0.8
10
15
1.0E+01
60
1.0E+00
ID=5A
50
1.0E-01
IS (A)
125°C
40
30
50
75
100
125
150
175
125°C
1.0E-02
1.0E-03
25°C
1.0E-04
25°C
Temperature (°C)
Figure 4: On-Resistance vs. Junction
Temperature
ID (A)
Figure 3: On-Resistance vs. Drain Current and
Gate Voltage
RDS(ON) (mΩ)
25°C
4
RDS(ON) (mΩ)
125°C
1.0E-05
1.0E-06
10
4
6
8
0.0
10
0.4
0.6
0.8
1.0
1.2
VSD (Volts)
Figure 6: Body-Diode Characteristics
VGS (Volts)
Figure 5: On-Resistance vs. Gate-Source Voltage
www.umw-ic.com
0.2
3
友台半导体有限公司
R
UMW
UMW AO3400A
5
1200
Capacitance (pF)
4
VGS (Volts)
1400
VDS=15V
ID=5A
3
2
1
1000
Ciss
800
600
400
Coss
200
4
6
8
10
Qg (nC)
Figure 7: Gate-Charge Characteristics
1ms
1.0
10ms
1s
DC
1
10
100
30
0.1
1
10
100
1000
Pulse Width (s)
Figure 10: Single Pulse Power Rating Junction-toAmbient (Note E)
VDS (Volts)
Figure 9: Maximum Forward Biased Safe
Operating Area (Note E)
ZθJA Normalized Transient
Thermal Resistance
25
TJ(Max)=150°C
TA=25°C
0.1
10
10s
0.1
15
30
100µs
0.1s
10
40
TJ(Max)=150°C
TA=25°C
RDS(ON)
10.0 limited
5
VDS (Volts)
Figure 8: Capacitance Characteristics
Power (W)
ID (Amps)
100.0
Crss
D=Ton/T
TJ,PK=TA+PDM.ZθJA.RθJA
RθJA=90°C/W
In descending order
D=0.5, 0.3, 0.1, 0.05, 0.02, 0.01, single pulse
1
PD
0.1
0.01
0.00001
Ton
T
Single Pulse
0.0001
0.001
0.01
0.1
1
10
100
1000
Pulse Width (s)
Figure 11: Normalized Maximum Transient Thermal Impedance
www.umw-ic.com
4
友台半导体有限公司
UMW
R
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
www.umw-ic.com
UMW AO3400A
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
5
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
友台半导体有限公司
很抱歉,暂时无法提供与“UMW AO3400A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.18975
- 10+0.17325
- 30+0.16995
