UMW AO3415A
UMW AO3415A
    UMW(友台)
    SOT-23
    SOT-23塑料封装MOSFET
UMW AO3415A 数据手册
UMW R UMW AO3415A SOT-23 Plastic-Encapsulate MOSFETS UMW AO3415A P-Channel 20-V(D-S) MOSFET V(BR)DSS ID RDS(on)MAX SOT-23 50mΩ@-4.5V 60mΩ@-2.5V  -20 V -4A 1. GATE 73mΩ@-1.8V 2. SOURCE 3. DRAIN FEATURE z Excellent RDS(ON), low gate charge,low gate voltages MARKING APPLICATION z Load switch and in PWM applicatopns Equivalent Circuit D G AFHV S Maximum ratings (Ta=25℃ unless otherwise noted) Parameter Symbol Value Drain-Source Voltage VDS -20 Gate-Source Voltage VGS ±8 Unit V Continuous Drain Current (t≤10s) ID -4.0 A Maximum Power Dissipation (t≤10s) PD 0.35 W RθJA 357 ℃/W TJ 150 ℃ TSTG -55 ~+150 ℃ Thermal Resistance from Junction to Ambient Operating Junction Temperature Storage Temperature www.umw-ic.com 1 友台半导体有限公司 UMW R UMW AO3415A SOT-23 Plastic-Encapsulate MOSFETS Ta =25 ℃ unless otherwise specified Parameter Symbol Test Condition Min Typ Max -0.56 -1 Units Static Parameters Drain-source breakdown voltage Gate threshold voltage V(BR) DSS VGS = 0V, ID =-250µA -20 VGS(th) VDS =VGS, ID =-250µA -0.3 Gate-body leakage current IGSS Zero gate voltage drain current IDSS Drain-source on-state resistance(note1) RDS(on) VDS =0V, VGS =±8V ±10 VDS =0V, VGS =±4.5V ±1 VDS =-16V, VGS =0V -1 VGS =-4.5V, ID =-4A 0.037 0.050 VGS =-2.5V, ID =-4A 0.045 0.060 VGS =-1.8V, ID =-2A 0.056 0.073 Forward transconductance(note2) gFS VDS =-5V, ID =-4A Body diode voltage(note2) VSD IS=-1A,VGS =0V 8 V µA Ω S -1 V Dynamic Parameters (note3) Input capacitance Ciss Output capacitance Coss Reverse transfer capacitance Crss Gate resistance Rg 1450 VDS =-10V,VGS =0V,f =1MHz 205 pF 160 VDS =0V,VGS =0V,f =1MHz 6.5 Ω Switching Parameters Total gate charge Qg Gate-Source charge Qgs Gate-drain charge Qgd 4.5 Turn-on delay time (note3) td(on) 9.5 Turn-on rise time(note3) Turn-off delay time(note3) Turn-off fall time(note3) 17.2 VDS =-10V,VGS =-4.5V,ID =-4A 1.3 tr VDS=-10V, VGS=-4.5V 17 td(off) RGEN =3Ω, RL=2.5Ω, 94 tf nC ns 35 Notes: 1. Repetitive rating,pulse width limited by junction temperature. 2. Pulse Test : Pulse width≦300µs, duty cycle≦2%. 3. These parameters have no way to verify. www.umw-ic.com 2 友台半导体有限公司
UMW AO3415A 价格&库存
很抱歉,暂时无法提供与“UMW AO3415A”相匹配的价格&库存,您可以联系我们找货
UMW AO3415A
    • 1+0.34500
    • 100+0.32200
    • 300+0.29900
    • 500+0.27600
    • 2000+0.26450
    • 5000+0.25760
