UMW
R
UMW SI2300A
UMW SI2300A
N-Channel 20-V(D-S) MOSFET
V(BR)DSS
ID
RDS(on)MAX
25mΩ@4.5V
20 V
SOT-23
6A
34.5mΩ@ 2.5V
1. GATE
2. SOURCE
3. DRAIN
FEATURE
z TrenchFET Power MOSFET
APPLICATION
Load Switch for Portable Devices
z
DC/DC Converter
z
MARKING
Equivalent Circuit
C009T
Maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
±12
Continuous Drain Current
ID
6
Continuous Source-Drain Current(Diode Conduction)
IS
0.6
Power Dissipation
Unit
V
A
W
PD
Thermal Resistance from Junction to Ambient (t≤5s)
RθJA
℃/W
312.5
Operating Junction
TJ
150
Storage Temperature
TSTG
-55 ~+150
www.umw-ic.com
1
友台半导体有限公司
UMW
R
UMW SI2300A
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Units
Static
Drain-source breakdown voltage
V(BR)DSS
VGS = 0V, ID =10µA
VGS(th)
VDS =VGS, ID =50µA
0.40
Gate-body leakage
IGSS
VDS =0V, VGS =±8V
±100
nA
Zero gate voltage drain current
IDSS
VDS =20V, VGS =0V
1
µA
Gate-threshold voltage
Drain-source on-resistancea
Forward transconductance
rDS(on)
a
Diode forward voltage
1
VGS =4.5V, ID = 6 A
0.021
0.025
VGS =2.5V, ID =5.2A
0.028
0.034
gfs
VDS =5V, ID =3.6A
8
VSD
IS=0.94A,VGS=0V
0.74
1.2
7.7
10
V
Ω
S
V
Dynamic
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
2.1
Ciss
574
Input capacitance
b
Output capacitance
b
Reverse transfer capacitance
Switching
Coss
b
VDS =10V,VGS =4.5V,ID =3.6A
VDS =10V,VGS =0V,f=1MHz
0.32
70
nC
pF
60
Crss
b
Turn-on delay time
Rise time
Turn-off delay time
Fall time
td(on)
tr
td(off)
tf
VDD=10V,
RL=5.5Ω, ID ≈3.6A,
VGEN=4.5V,Rg=6Ω
78.7
128
ns
453
80.9
Notes :
a.
Pulse Test : Pulse width≤300µs, duty cycle ≤2%.
b.
These parameters have no way to verify.
www.umw-ic.com
2
友台半导体有限公司
UMW
R
UMW 2300A
Typical Characteristics (TJ =25℃ Noted)
www.umw-ic.com
3
友台半导体有限公司
UMW
R
UMW 2300A
www.umw-ic.com
4
友台半导体有限公司
很抱歉,暂时无法提供与“UMW SI2300A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.23800
- 20+0.21700
- 100+0.19600
- 500+0.17500
- 1000+0.16520
- 2000+0.15820
- 国内价格
- 1000+0.07694
- 3000+0.07098
