DC-005-2.5A-2.5-SMT
DC-005-2.5A-2.5-SMT
    XKB(中国星坤)
    SMD
    DC电源插座 卧贴 触点内径:2.5mm 触点外径:6.5mm
DC-005-2.5A-2.5-SMT 数据手册
PRODUCT SPECIFICATION Part Number Product Description Doc Number   A Rev DC-005-2.5A-2.5-SMT DC Power Jack, Thru-Hole, Horizontal, w/Locating Pegs, Ø2.00mm DC-005-2.5A-2.5-SMT AO Prepared VJ Checked                             www.helloxkb.com www.helloxkb.cn Date 12/06/15 Page 1  Approved ST PRODUCT SPECIFICATION Part Number Product Description Doc Number   A Rev DC-005-2.5A-2.5-SMT DC Power Jack, Thru-Hole, Horizontal, w/Locating Pegs, Ø2.00mm DC-005-2.5A-2.5-SMT AO Prepared Checked VJ Date 12/06/15 Page 2  Approved ST 1.0 SCOPE. DC Power Jack, Thru-Hole, Horizontal, w/Locating Pegs, Ø2.00mm. 2.0 PRODUCT NAME AND PART NUMBER. DC Power Jack, Ø2.00mm: DCJ200-10. 3.0 PRODUCT SHAPE, DIMENSIONS AND MATERIAL. Please refer to drawings. 4.0 RATINGS. Current rating ………………………. 5 Amp Max Voltage rating ……………………… DC 20 Volts Max. Operating Temperature Range …… -20°C to +70°C Storage Temperature………………. -25°C to +80°C Storage Humidity…………………… Relative Humidity: ≤80% 5.0 TEST AND MEASUREMENT CONDITIONS. Product is designed to meet electrical, mechanical and environmental performance requirements. specified in Paragraph 6.0. All tests are performed at ambient environmental conditions unless otherwise specified. 6.0 PERFORMANCE. Item Test Condition Requirement Examination of Product Visual, dimensional and functional inspection as per quality plan. Product shall meet requirements of product drawing and specification.   www.helloxkb.com www.helloxkb.cn PRODUCT SPECIFICATION Part Number Product Description Doc Number   A Rev DC-005-2.5A-2.5-SMT DC Power Jack, Thru-Hole, Horizontal, w/Locating Pegs, Ø2.00mm DC-005-2.5A-2.5-SMT Prepared AO Checked VJ Date 12/06/15 Page 3  Approved ST 6.1 Electrical Performance. Item Test Condition Requirement Contact Resistance Measure contact resistance of mated connector using test current of 10mA max and 20 mV open circuit voltage. 30mΩ max initial In accordance with EIA-364-23. Measure by applying test potential between the adjacent contacts, and between the contacts and frame. Insulation Resistance 100 MΩ minimum @250V DC for 1 minute In accordance with EIA-364-21. Dielectric Strength Measure by applying AC 500V between the adjacent contacts, and between the contacts and frame for 1minute. There shall be no breakdown. In accordance with EIA-364-20. 6.2 Mechanical Performance. Item Test Condition Requirement (1). Contact resistance: 50mΩmax. Durability 5,000 cycles of operation at a rate of 20~30 cycles per minute. In accordance with EIA-364-09. Insertion and Extraction force Operation Speed: 25.4 mm/min. Measure the force required to mate connector. (2). Insertion and withdraw force: 3~30N. (3). Electrical characteristics and mechanical characteristics shall be satisfied. Without distinct damage.  Insertion and extraction force: 3~30N In accordance with EIA-364-13. Terminal Strength A static force of 20N being applied to the centre pin in the X axis direction for 10sec.     www.helloxkb.com www.helloxkb.cn There shall be no sign of damage mechanically and electrically. PRODUCT SPECIFICATION Part Number Product Description Doc Number     A Rev DC-005-2.5A-2.5-SMT DC Power Jack, Thru-Hole, Horizontal, w/Locating Pegs, Ø2.00mm DC-005-2.5A-2.5-SMT Random Vibration Prepared AO Checked Mate connectors and subject to: 5.35 Gs RMS. For a period of 15 minutes in each of 3 mutually perpendicular axes. In accordance with EIA-364-28D. Mechanical Shock Accelerate Velocity: 30Gs Waveform: Half-sine shock plus Duration: 11msec Three shocks in each direction applied along three mutually perpendicular planes for a total of 18 shocks. VJ Date 12/06/15 Page 4  Approved ST No electrical discontinuity greater than 1 µsec. shall occur. No damage to product. Contact resistance: 50mΩ Max No electrical discontinuity greater than 1 µsec. shall occur. No damage to product. Contact resistance:50mΩ Max In accordance with EIA-364-27 6.3 Environmental Performance and Others. Item Salt Water Spray Test Condition Requirement Air pressure of salt spray: 0.07 0.17Mpa; Salt Concentration: 5%; PH value:6.5-7.2; Temperature of salt-bath: 35+2Ԩ; Test time: 24H(continuous). Without excessive Corrosion or crack in appearance In accordance with EIA-364-26 Temperature Life (High) Subject Jack to 80±2°C for 96 hours, after test in normal condition for 30mins. In accordance with EIA-364-17 Humidity Test Subject Jack to 40±2Ԩ and humidity 9095% for 96 hours, after test keep in normal condition for 30 minutes. In accordance with EIA-364-31. Temperature Life (Low) Subject Jack to -25±2°C for 96 hours, after test in normal condition for 30mins. In accordance with EIA-364-59 Temperature Rise Measure the temperature rise of pin, when rated current is passed. Mated with plug: CUI PP3-002AH In accordance with EIA-364-70 Method 1.         www.helloxkb.com www.helloxkb.cn (1). Contact resistance: 50mΩmax. (2). Insulation resistance: 50MΩmin. (3). There shall be no sign of damage mechanically and electrically. 30°C Max PRODUCT SPECIFICATION Part Number Product Description Doc Number     A Rev DC-005-2.5A-2.5-SMT DC Power Jack, Thru-Hole, Horizontal, w/Locating Pegs, Ø2.00mm DC-005-2.5A-2.5-SMT Prepared AO Checked VJ Date 12/06/15 Page 5  Approved ST Solderability The tip of the terminals shall be dipped 2mm in the solder bath at a temperature of 240±5Ԩ for 3±0.5sec. A new uniform coating of solder shall cover a minimum of 95% of the surface being immersed. Resistance to Hand Soldering Heat The jack shall be hand soldered at the temperature of 350±5Ԩ in 3±1sec after which measurement shall be made. Electrical characteristics and mechanical characteristics shall be satisfied. Without distinct damage. Resistance to Soldering Heat. The jack shall be placed into the temperature of 260±5Ԩ in 5±1sec(Automatic soldering) Electrical characteristics and mechanical characteristics shall be satisfied. Without distinct damage.                                   7.0 PRODUCT QUALIFICATION AND TEST SEQUENCE   www.helloxkb.com www.helloxkb.cn PRODUCT SPECIFICATION Part Number Product Description Doc Number   A Rev DC-005-2.5A-2.5-SMT DC Power Jack, Thru-Hole, Horizontal, w/Locating Pegs, Ø2.00mm DC-005-2.5A-2.5-SMT Test Item Prepared AO Checked Date 12/06/15 Page 6  VJ Approved Group A B C D E F G H I Examination of Product 1,12 1,3 1,9 1,6 1,8 1,3 1,3 1,5 1,6 Contact Resistance 2,9 2,6 2,5 2,6 2,4 2,5 Insulation Resistance 3,10 3,7 3,7 Dielectric Withstanding Voltage 4,11 4,8 4 Durability 6 Temperature Rise 7 Insertion and Extraction force 5,8 5 5 Terminal Strength Humidity 2 2 Solderability Resistance to Soldering Heat 2 Resistance to Hand Soldering Heat 3 Salt Spray Temperature (Heat) 3 Temperature (Cold) 4 Random Vibration 3 Mechanical Shock 4 Revision details   www.helloxkb.com www.helloxkb.cn J ST PRODUCT SPECIFICATION Part Number Product Description Doc Number   A Rev DC-005-2.5A-2.5-SMT DC Power Jack, Thru-Hole, Horizontal, w/Locating Pegs, Ø2.00mm Prepared DC-005-2.5A-2.5-SMT AO Checked VJ Date 12/06/15 Page 7  Approved Revision Information Page Release Date A Specification Released - 12/06/2015   www.helloxkb.com www.helloxkb.cn ST
DC-005-2.5A-2.5-SMT 价格&库存
很抱歉,暂时无法提供与“DC-005-2.5A-2.5-SMT”相匹配的价格&库存,您可以联系我们找货
DC-005-2.5A-2.5-SMT
    • 5+2.50366
    • 50+1.97716
    • 300+1.75144
    • 600+1.32299
    • 2400+1.21014
    • 5100+1.14240
    库存:14
