WSD2068DN
WSD2068DN
    WINSOK(微硕)
    DFN6_2X3MM_EP
    MOS管 Dual N-Channel VDS=20V VGS=±12V ID=7.5A RDS(ON)=15.5mΩ@4.5V
WSD2068DN 数据手册
WSD2068 Dual N-Ch MOSFET General Description Product Summery The WSD2068 is the highest performance trench N-ch MOSFETs with extreme high cell density , which provide excellent RDSON and gate charge for most of the small power switching and load switch applications. BVDSS RDSON ID 20V 15.5mΩ 7.5A Applications The WSD2068 meet the RoHS and Green Product requirement with full function reliability approved. z Power Management in Notebook Computer, Portable Equipment and Battery Powered Systems. z DC-DC Power System Features z ESD:2KV z Advanced high cell density Trench technology DFN2X3A_EP Pin Configuration z Super Low Gate Charge z Excellent Cdv/dt effect decline z Green Device Available Absolute Maximum Ratings Symbol Parameter Rating Units VDS Drain-Source Voltage 20 V VGS Gate-Source Voltage ID@TA=25℃ ID@TA=70℃ IDM PD@TA=25℃ ±12 V 1 7.5 A 1 6.5 A 30 A 1.5 W Continuous Drain Current, VGS @ 4.5V Continuous Drain Current, VGS @ 4.5V Pulsed Drain Current 2 3 Total Power Dissipation 3 PD@TA=70℃ Total Power Dissipation 1.0 W TSTG Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ Thermal Data Symbol RθJA RθJA www.winsok.tw Parameter 1 Thermal Resistance Junction-ambient (Steady State) Thermal Resistance Junction-ambient 1 (t
WSD2068DN
物料型号:WSD2068 Dual N-Ch MOSFET
器件简介: - WSD2068是具有极高单元密度的高性能N沟道MOSFET。 - 它为小型功率开关和负载开关应用提供了出色的RDSON(导通电阻)和栅极电荷特性。 - 符合RoHS和绿色产品要求,并通过全功能可靠性认证。
引脚分配:DFN2X3A_EP封装,引脚配置为S2S2G2,其中S1和S2为源极,G1为栅极。
参数特性: - 绝对最大额定值包括20V的漏源电压(Vps),±12V的栅源电压(VGs),7.5A的连续漏电流(ID)等。 - 热阻包括120°C/W的结到环境热阻(ROJA)和83°C/W的结到环境热阻(RaJA)。
功能详解: - 包括先进的高单元密度沟槽技术、超低栅极电荷、优秀的Cdv/dt效应下降和绿色设备可用性。
应用信息: - 适用于笔记本电脑、便携设备和电池供电系统中的电源管理。 - DC-DC电源系统中的ESD(静电放电)等级为2KV。
封装信息:DFN2x3A-6_EP封装,提供了详细的尺寸信息和推荐的焊盘图案。
WSD2068DN 价格&库存
很抱歉,暂时无法提供与“WSD2068DN”相匹配的价格&库存,您可以联系我们找货
