US1A THRU US1M
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT ULTRA FAST RECTIFIER
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Ultra fast switching for high efficiency
0.110(2.80)
0.094(2.40)
0.067 (1.70)
0.039 (1.00)
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
0.177(4.50)
0.157(3.99)
High temperature soldering guaranteed
0.012(0.305)
0.006(0.152)
250 °C/10 seconds at terminals
0.096(2.42)
0.078(1.98)
Mechanical Data
0.059(1.50)
0.035(0.90)
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.002 ounce, 0.07 grams
0.008(0.203)MAX.
0.205(5.20)
0.188(4.80)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=125℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
at rated DCblocking voltage
Maximum reverse recovery time
TA=25℃
TA=125℃
(NOTE 1)
Typical junction capacitance (NOTE 3)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
VRRM
VRMS
VDC
MDD
US1A
MDD
US1B
MDD
US1D
MDD
US1G
MDD
US1J
MDD
US1K
MDD
US1M
UNITS
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
I(AV)
1.0
A
IFSM
30
A
VF
1.0
1.30
IR
trr
CJ
RJA
RθJC
TJ,TSTG
1.65
5
100
50
uA
75
15.0
55.0
11.0
-55 to +150
V
ns
pF
℃/W
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.P.C.B. mounted with 2.0x2.0”(5.0x5.0cm) copper pad areas.
3.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
http://www.microdiode.com
Rev:2024A3
Page :1
US1A THRU US1M
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
Instaneous Reverse Current(μ A)
1.2
Average Forward Current (A)
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
50
75
100
125
150
175
100
TJ=125°C
10
1.0
TJ=25°C
0.1
00
Case Temperature (°C)
80
100
120
140
40
Peak Forward Surage Current (A)
TJ=25°C
1.0
Instaneous Forward Current (A)
60
Fig.4 Maximum Non-Repetitive Peak
10
US1A~US1D
US1G
0.1
US1J~US1M
0.01
1.0
1.5
2.0
2.5
35
30
25
10
05
00
8.3 ms Single Half Sine Wave
(JEDEC Method)
1
Instaneous Forward Voltage (V)
100
Fig.6 Typical Junction Capacitance
100
Junction Capacitance (pF)
100
10
1
0.01
10
Number of Cycles
Fig.5- Typical Transient Thermal Impedance
Transient Thermal Impedance(°C/W)
40
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Forward Characteristics
0.001
TJ=25°C
10
1
0.1
1
10
t, Pulse Duration(sec)
100
0.1
1.0
10
100
Reverse Voltage (V)
The curve above is for reference only.
Rev:2024A3
Page :2
US1A THRU US1M
Packing information
unit:mm
P0
P1
d
Item
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
Symbol
Tolerance
SMA
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMA
REEL SIZE
7"
APPROX.
GROSS WEIGHT
(kg)
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
2,000
4.0
4,000
183*155*183
178
382*356*392
10,000
290*290*38
330
310*310*360
80,000
11.0
15,000
335*335*38
330
350*330*360
120,000
14.5
SMA
11"
5,000
4.0
SMA
13"
7,500
4.0
CARTON
SIZE
(m/m)
CARTON
(pcs)
80,000
16.0
Suggested Pad Layout
Symbol
Unit (mm)
A
1.68
0.066
B
1.52
0.060
C
3.93
0.154
D
2.41
0.095
E
5.45
0.215
Unit (inch)
Rev:2024A3
Page :3
很抱歉,暂时无法提供与“US1J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10757
- 500+0.08889
- 1500+0.07852
- 5000+0.05357
- 25000+0.04817
- 50000+0.04536
- 国内价格
- 50+0.10700
- 500+0.08820
- 1500+0.07780
- 5000+0.05310
- 25000+0.04780
- 50000+0.04500
- 国内价格
- 50+0.09860
- 400+0.08148
- 800+0.08026
- 2000+0.07197
- 国内价格
- 1000+0.04972
- 5000+0.03729
- 国内价格
- 1+0.16380
- 500+0.05481
- 2500+0.03654
- 5000+0.02993
- 国内价格
- 10+0.04860
- 100+0.04030
- 300+0.03570
- 2000+0.03460
- 国内价格
- 1+0.03915
- 30+0.03770
- 100+0.03480
- 500+0.03190
- 1000+0.03045
